Question about Kicker S15L7 Car Subwoofer
Specker reparir I have an Audiobahn amp and it went out taking my kicker S15L7 subwoofer out. can it be repaired and how
  • 15,935 Answers
As an authorized Kicker Retailer - i can tell you that kicker will NOT recone any subwoofer that is out of warranty!!
The only sub you can repair is the soloX.
The cone assembly is proprietary, and there is NO company that can make the repairs because kicker does not sell the parts.
(although i have heard stories of people having an IN or knowing somebody working at Kicker to get a new assembly, but its 1 in a million that it will happen.)
Sorry.
Thanks for using FixYa - a FixYa rating is appreciated!!
Posted on Feb 25, 2009
  • blueextc3221
    blueextc3221 Feb 25, 2009
    Thanks for trying? I gave you the correct answer - there IS no repair available for your speaker!!!
    Please reconsider raising the rating - as a "thanks for trying" severely lowers our percentage rating, and is tantamount to saying your question was not answered.
    Most experts do not even attempt to answer free questions because of askers giving ratings like this.
    Some is the fault of FixYa not wording the rating correctly. IMO there should be NOT HELPFUL, HELPFUL, AND FIXYA.
    I took the time to answer your question correctly. Because it is not the answer you were expecting doesnt make it wrong.
    A "helpful" rating is not detremental and appreciated.
    Thank you.
Amp powers up red then turns green for a few seconds then shuts off power alltogether
My specker was working fine then the am went to on protection mode and backs power mode but my specker doesnt work but on when my volume is low
Sep 23, 2011 | Kicker (ZX750.1) Car Audio Amplifier
I have two audiobahn aw1500 15" subowoofers and i was trying to figure out how to wire them so that they come to 2 ohms. I have a Kicker 400.1 amp that is 2 ohm stable.
What is their ohms at the moment. If they are 8 ohms the will become 4o hms in parallel, 4 ohms will become 2 ohms in parallel. Since your audiobahns are dual four ohms coils one speaker wired in parallel gives you 2 ohms and both wired together in parallel will give you 1 ohms. You will need to wire them in series parallel to to keep two ohms and that is a waste of power. Kickers are good amps, with a little extra cooling the amp should sustain the 1 ohm capability of your parallel connection or trade in for a 1ohm stable amp
Apr 02, 2011 | AudioBahn AW1500 Car Subwoofer
How to bridge two l7 kickers
It depends on the end ohm load you are trying to achieve. If your amp is rated at 2 ohms stable, then wire for 2 ohms, if 1 ohm stable wire for 1 ohm. EX. A dual 2 ohm woofer can be wired with the positive of 1 coil connected to the negative of the other coil, then connect the amp to the other two open terminals. This cuts the load of that speaker down to 1 ohm. When connecting the other speaker in the same manner, the two speakers a 1 ohm each add together to produce a 2 ohm load at the amp. NOTE- a 2 ohm amp running a speaker wired for 1 ohm will not have enough resistance to limit the power coming from the amp and runs a high chance of burning the amp up.
Oct 30, 2010 | Kicker S15L7 Car Subwoofer
Need An amp for 2, 4ohm Kicker 12" L5
i bought two Audiobahn A2300hcx on ebay for a little over 400. look around on ebay you can really score sometime dirt cheap........ Check out audiobahn amps, never did me any wrong...........
May 06, 2010 | Kicker Solo-Baric L5 Car Subwoofer
What wires do i need to hook up 2 kicker solobaric s15l7 to a car
You will need the amp wires. Red Positive to battery, Black negative from amp ground to unpainted car body surface, and the blue remote wire that goes from amp to remote wire on back of cd deck.
Then you will need the rca cables from rear output of cd player to the amp.
Then just the positive and negative wire from speaker to amp. Use Speaker Positive wire to Amp Right Channel Positive
And speaker negative wire to amp Left Channel Legative wire.
That is it.
Nov 17, 2009 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Where can i buy a kit for s15l7 and how much its cost
Well what kind of kit are you looking for. A sub, amp, wiring kit all together, or a recone kit? cuz a whole kit I would go to ebay or to hifisoundconnection.com
Jun 13, 2009 | Kicker S15L7 Car Subwoofer
Help me with my system
More information is required to start solving your problem. (ie. your make and model of "1500W amp", the voicecoil configuration of the kicker and Audiobahn 15's, and why you want to encorprate 2 crossovers in your system)
Seems as If you have a system without a plan.
Head unit?
More info necessary to give you the best use of your components.
Jan 14, 2009 | KEF Audio PSW 2150 Speaker
What amp size do I need
If the subs are going to be wired at 2 ohms you will need a class d amp that is 1200 watts at two ohms rms i would say you should probably be running zero gauge wire and at least a two fared cap
Feb 22, 2008 | Kicker S15L7 Car Subwoofer
Install these
Here is the link to the user guide and installation guide; http://www.kicker.com/06/tech-support/manuals/manuals/2006/2006%20L7%20Sub%20b01%20WEB.pdf page 2 should tell you what you need to know - if not, please ask again Hope this helps :)
Apr 11, 2007 | Kicker S15L7 Car Subwoofer
Kicker S15L7 Car Subwoofer Logo
207 people viewed this question
Top Kicker Car Audio & Video Experts
Professor_V
Professor_V
Tygh Duval
Tygh Duval
hoyzee1
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
