Question about Dell Inspiron 6000 Notebook
My dell laptop can not display anything on the lcd except for the
It only shows the backlight unless if l enter through safe mode picking the option of enabling VGA mode
Do u have a wirereliss internet
Posted on Feb 24, 2009
How do I get out of safe mode on my dell vastro 2521?
Once you have solved the problem that sets it in "safe mode", you can reboot the computer into normal mode.
Look in the Control Panel.
Pick device manager and look for a yellow balloon, which will show why it is still in safe mode.
Mar 06, 2015 | Dell Inspiron Computers & Internet
My dell laptop is not starting up,it will on but not display anything on screen
Please try to boot the computer to Safe Mode. Do to so
1. Turn Off the computer
2. Now, as soon as you turn On the computer, keep tapping the F8 key (this will show up the Advanced Boot menu)
3. Select Safe Mode using the down arrow key on your keyboard. and hit Enter
4. If you are able to boot to the computer then a system restore will work.
Thanks!
Oct 01, 2013 | Dell Computers & Internet
Dell laptop not detecting external display
Usually the external monitor and laptop screen toggles in one of three states.
LCD only
External monitor only
Both LCD and external monitor
Wait a couple of seconds between when you press Fn F8
This model laptop may not allow ectended display.
May 29, 2012 | Dell Latitude D830 Laptop Computer PC...
Dell XPS M1330 - Backlight not working
If you are having issues with a backlight I would check the lcd inverter first. It is usually 20 dollars on ebay. I would avoid contacting dell as they are no help to people that are out of warranty.
Jul 20, 2009 | Dell XPS M1330 Notebook
Dell inspiron... turn on and screen will not display anything, but slightly illuminates... plugged into desktop screen, running safe mode, computer will run, but cannot boot up normal on desktop screen and...
You could have a defective screen - a defective inverter or a CCFL lamp or simply the video cable needs reseating. After reseating the video cable and the problem is still there then :- To determine if you have a LCD screen or video card problem, read this and follow the instructions. Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case. The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills. Check out www.lcdparts.net for parts, repair service and DIY info.
Jun 11, 2009 | Dell Inspiron 6000 Notebook
Dell Vostro 1400 LCD Showing Black Screen
If you can't see it with an external monitor - it generally means the system board needs replacement. I hope that you still have a Dell warranty. Good luck.
Jun 09, 2009 | Dell Vostro 1400 Notebook
My HP Notebook first showed a black screen and then after a hard shutdown and restart it only shows a black screen with colored lines. It seems that it is starting up even though I can't see the screen.
Try this,Start in VGA mode.Once started,update your video drivers
To use a Safe Boot option, follow these steps:
  1. Restart your computer and start pressing the F8 key on your keyboard. On a computer that is configured for booting to multiple operating systems, you can press the F8 key when the Boot Menu appears.
  2. Select an option when the Windows Advanced Options menu appears, and then press ENTER.
  3. When the Boot menu appears again, and the words "Safe Mode" appear in blue at the bottom, select the installation that you want to start, and then press ENTER.
Safe Boot options loadTOCNode(2, 'moreinformation');
  • Safe Mode (SAFEBOOT_OPTION=Minimal): This option uses a minimal set of device drivers and services to start Windows.
  • Safe Mode with Networking (SAFEBOOT_OPTION=Network): This option uses a minimal set of device drivers and services to start Windows together with the drivers that you must have to load networking.
  • Safe Mode with Command Prompt (SAFEBOOT_OPTION=Minimal(AlternateShell)): This option is the same as Safe mode, except that Cmd.exe starts instead of Windows Explorer.
  • Enable VGA Mode: This option starts Windows in 640 x 480 mode by using the current video driver (not Vga.sys). This mode is useful if the display is configured for a setting that the monitor cannot display.
Please rate this a fixa
Feb 01, 2009 | Microsoft HP Pavilion DV6276US Notebook PC
Laptop won't boot (display problems)
If the diagnostics displays on the LCD screen but you get no display when Windows starts to load, it sounds like you have a video software driver problem. Try tapping the F8 key when you power on your laptop and boot in Safe mode. If it works in safe mode then you need to check you driver. You can also try connecting the laptop to an eternal monitor and see what happens.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Nov 08, 2008 | Dell Latitude D800 Notebook
Display is upside down
AN EASIEST WAY IS HOLD THE CTRL AND ALT KEYS,AND CLICK THE "UP" KEY
Jun 02, 2008 | Dell E173FP 17" LCD Flat Panel Monitor
Dell Inspiron 6000 Notebook Logo
50 people viewed this question
Alun Cox
