Question about SimpleTech Pininfarina 80GB External USB 2.0 SP-UE25/80 (SPUE2580) Hard Drive
Simple Tech SP U25/60 external hard drive
My PC with Windows 2000 doesn't recognize my Simple Tech SP U25/60 external hard drive
  • Anonymous Mar 12, 2009
    Simple Tech SP U25/60 external hard drive donĀ“t work in win2000
  • 4 Answers
Almost nothing is supported on Win 2000 because it had shuch a short life span. most new tech made in the last 2-3 years only runs onXP or Vista. Every once in a while some will work back to 98.
p.s. did it say it was compatable with 2000? look on the box
Posted on Feb 25, 2009
My computer will not recognize the drive. Does it have to be connect to a power supply? I have it connected to a usb port
Windows 7 does not recognize SimpleTech 250GB external USB drive ...
answers.microsoft.com/...does-not-recognize-simpletech-250gb/f7ceccd0...
Just bought a new computer, running Win 7. Drive worked fine on Win XP. ... Windows 7 does not recognize SimpleTech 250GB external USB drive ... I find it hard to believe that a external USB 2.0 drive can't work with Win 7. There must be ...
SimpleTech dvi hdmi pc Hard Drives Questions & Answers ...
www.fixya.com > Forum > Tags > dvi hdmi pc > Hard Drives
Question about SimpleDrive 160 GB External USB 2.0 Hard Drive ... Question about250GB USB2.0 7200 RPM External 250 GB IDE Hard Drive ... my PC does not recognize the external drive 96300-40001-001 Driver Problem: Check whether ..
Dec 18, 2015 | SimpleTech SimpleDrive 250 GB External USB...
How to solve simple tech 160GB EXTERNAL USB HARD DRIVE
I was having a problem on Windows 7 with the SimpleTech 160GB drive not being recognized, went to the SimpleTech site and could not find any drivers - Went to MajorGeeks and found a driver update program - watch when you install it, do custom install so as not to get new homepage or toolbar. But it scanned and found where my drivers were deficient. Updated driver and drive is now recognized
Jul 14, 2014 | SimpleTech SimpleDrive 160 GB External USB...
Is my simple tech 60GB compatable with windows 7 the disk said for windows 2000 and xp
Most portable hard drives work with any operating system
Plug and Play is a simple Windows controller that enables your Windows computer to recognize and adjust to hardware changes and devices plugged on your computer such as hard drives, memory cards and USB and Firewire-powered devices with little or no input from a user. If your system is not recognizing plugged-in hardware, the plug-and-play device may be disabled and may cause instability on your system. Enabling this feature is simple.
Click "Start" on your computer screen and then click "Run." Type in services.msc on the run window and hit "Enter." Scroll down the services window and right-click "Plug and Play." Click "Properties" on the pop-up menu. Select "Automatic" under start-up type if it is disabled. Click "OK" to save the changes. Click "Start" on your screen and click "Control Panel." Double-click "System" and click the "Hardware" tab. Click the "Device Manager" button and then right-click the plug-and-play device you want to enable, then click "Enable." Close the device manager. Hope this helps.
Dec 23, 2012 | SimpleTech SP-U25/60S 60 GB USB 2.0 Hard...
LaCie d2 200GB on my Pc (windows xp) via USB 2.0 doesn't show
the situation here is ahppening to all external sata or Esata drives what happens is the external closure has a usb controller when this dies the drive doesn ot spin up or does not reconise simple solution buy a external drive encloser and transfer the drive to it and that will work. thanks and please rate.
Nov 24, 2009 | LaCie d2 (300769) 200 GB Hard Drive
The computer does not recognize the Simpletech external hard drive. I plugged in a different external hard drive into the same USB port and the computer recognized it right away. What is wrong with the...
not all usb devices work on all machines
You need to find a driver or ask simple tech what the issue is i had the same issue with My WDC drive Western Digital gave me a driver after emailing them
Aug 13, 2009 | SimpleTech 750 GB USB Hard Drive
My Hp Slimline won't recognize my new Simple Tech Mini-Drive
I`m David ncc student , question is about the characteristics of various network computers (NCs) currently on market? please help me
Mar 08, 2009 | HP S3120N Pavilion Slimline Desktop...
Simpletech hard drive not working
I have that problem similiar to yours. My simple tech stopped working for like two years so i decided to open up my simple tech and removed my HD away from the old enclosure so I can try building my own external hard drive for the first time. I bought another new 3.5 enclosure, IDE/ATA for the old HD. I put it in the new enclosure and it worked!
It's the only solution you can have. No need to retrieve data or re-format your HD. You can leave it the way you like...if you wanna reformat it...up to you.
Jan 27, 2009 | SimpleTech 250GB USB2.0 7200 RPM External...
Simple tech problem
windows 2000 detects the driver for plug n play drives for it self and if it doesnt then try driverguide.com for drivers of the disk.
Nov 08, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
Problems
One thing to remember is the some of the Simple drives requires the USB mini to conect to the drive and the TWO USB connects to be plugin to the computer.
Jan 15, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
EXTERNAL HARD DRIVE BY SIMPLE TECH 500 GG
First, check the warranty status. They should give you a replacement. The following will probably void your warranty... This external drive probably houses a standard hard drive used in a desktop computer. If you don't mind voiding your warranty, you could disassemble the protective "shell" and check to see that the cabling to the drive is properly attached. I've seen a external drive which the interface cable was partially unattached. If all looks OK here, you could remove the actual hard drive and try hooking it up to a standard desktop computer. If you or a friend is reasonably tech savvy, such is a plus. It could be set as a secondary drive, and then you could see if files could be accessed. If nothing above works, then your outlook is bleak. There are businesses specializing in file recovery from a dead drive, but it is expensive.
Aug 08, 2007 | SimpleTech SimpleDrive Portable USB 2.0...
Computers & Internet Logo
517 people viewed this question
Top SimpleTech Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Lyle Siemens
Lyle Siemens
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
