Question about Brother CS-100-T Computerized Sewing Machine
I have a Brother CE5000PRW sewing machine , I broke the buttonhole foot to it # XC2691031. I can't find a replacement anywhere, I called Brother the person I talked to says its discontinued. I just bought that machine at Walmart last September. If anyone has an extra buttonhole foot they will sell or knows where I can buy, I would be very grateful. Thanks, Sharon
Try this, Buttonhole Foot (A), Babylock, Brother # XC2691051 just put it in your google search box.... its $12.95 plus 2 to 5 dollars for shipping
Posted on Nov 18, 2010
I lost the cord to make the machine turn on
Posted on Jun 01, 2009
Instructions for making a buttonhole
The method will depend on your make & model machine, although the vintage sewing machine buttonhole method will work on all zig-zag machines (just requires manually measuring and adjusting the stitch length & width during the process):
How to Use an Automatic Buttonhole Foot
Sew Buttonhole in 4 Steps on your Singer Sewing Machine
Sewing Buttonholes Without Buttonhole Foot
How to Sew Buttonholes with Regular Foot Sewing Tutorial with Alison Smith
How to sew buttonhole with an old machine
How to Sew Button hole tutorial
Sew Buttonhole without Buttonhole Foot by Create Kids Couture
Be sure there is a stabilizer between the fabric where the buttonhole is located so the fabric will not stretch or tear.
Jan 09, 2017 | Sewing Machines
I have a brother star 110 how do I sew a buttonhole
Here is what you may need to do. It is in the video. Your sewing machine is similar enough to this particular one. https://www.youtube.com/watch?v=x9yn2mqLjjY
Mar 24, 2015 | Brother Sewing Machines
Brother ce5000prw e1 code
Presser foot sensor/switch is either stuck or broken.
Jul 19, 2014 | Brother Sewing Machines
E1 flashes on the message window of my brother sewing machine
Brother Computer Codes
  • E1: Make sure the presser foot is lowered before sewing.
    E2: You chose a stitch other than a buttonhole stitch or a bar tack stitch and you tried to sew with the buttonhole lever in the lowered position. Raise the buttonhole lever.
    E3: If you selected the buttonhole or tack bar stitch and start to sew with the buttonhole lever raised, you will get the E3 code. Lower the buttonhole lever.
    E4: You hit the reverse button while the bobbin winder shaft was moved over to the right. Move the bobbin winder shaft to the left.
    E5: On automatic sewing machines, the start/stop button was pressed while the foot controller was plugged in. Unplug the foot controller if you are using the automatic function.
    E6: This code tells you that the motor locked up because the thread is tangled. Untangle the thread, make sure the machine is threaded properly and that the proper tension is set before continuing.
Oct 03, 2012 | Brother CS-6000
Brother sewing machine cs2000i botton hole problem as follows the foot stays in place and does not feed. I have changed the thread, looked at the video, clean any clogs. What is it?
it does not specify if this machine is electronic or mechanical, but electronic sewing machine,,like mine have what is called a buttonhole lever & unless that buttonhole lever is pulled gently down the buttonhole maker will not work.
that may be the problem with the machine
or it maybe the feeddogs may not be working,,check the feeddog knob or lever to see what position it's in,,up position is for sewing & down position is for darning
Feb 01, 2012 | Brother Sewing Machines
When i turn on my sewing machine and press the foot control my machine beeps and e2 error appears
bar tack stitch was selected and the foot controller was pressed (or the start/stop button was pressed if the foot controller is not connected) while the buttonhole lever is lowered.
Raise the buttonhole lever before continuing the operation.
Jun 26, 2011 | Brother CS-6000
Can't get buttonhole setting
To the left of the presser foot, there is a plastic button hold guide that must be puled down in order to sew a button hole. Make sure the arm is pulled completely down and placed behind the guide on the foot. There's pictures in the manual, or you can find the manual on-line at brother.com. I hope that helps!
Mar 30, 2009 | Brother CS-8072 Computerized Sewing...
Brother CS-100-T Computerized Sewing Machine Logo
736 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
