Mess storag centreno 2 pcg-3c1m
Keurig is blowing grounds all over
You are likely overfilling your pod with coffee. I had the same issue until I realized that to get a good cup of coffee without the mess I should only use 1/2 full pods. If you are having this mess with factory sealed K-cups then I don't know what your issue could be.
Sep 06, 2016 | Keurig Black K-Cup Storage Dispenser Set...
Sony vaio pcg 3c1m
You should first check the jack by physically inspecting it for any damage. Has the laptop been dropped while plugged in? If you see no physical damage, then you can use a voltmeter to measure the output power of the adapter to make sure it is putting out the power it's supposed to.
Nov 05, 2013 | Computers & Internet
I can't find my mass storage controller driver
You can try downloading the drivers again and re-installing them from here
http://esupport.sony.com/US/perl/swu-list.pl?mdl=PCG-K35
And select Notebook Control & Utilities,Download and install everything,Because sometimes they're not a seperated driver for Mass Storage and usually coupled up with something else like graphics or audio.Hope this helps...
Aug 27, 2010 | Sony VAIO PCG-K35 Notebook
Sony vaio pcg-3c1m does not start
recharge your battery or run the laptop while being connected to the AC adapter power
Mar 14, 2010 | Computers & Internet
Unhappy fan noise vaio pcg 3c1m
Only do this if you feel competent in doing so.
Pulling apart laptops is not for the faint of heart.
If you really must do it there are some
good guides here.
An alternative is to get a can of compressed air used to clean computers. Put the nozzle on and spray it in every hole you can see without putting the nozzle itself inside the laptop.
Do this outside with glasses on.
You may also want to remove the hard drive and ROM drive.
Take a
peek here for more ideas of what is involved.
There are a few are tips for various things in there.
DON'T touch the CPU cooler unless you know what you are doing and have some thermal grease for CPUs to hand.
To make newer laptops last longer between cleaning a good 3 fan cooling pad is suggested.
Never use a laptop on soft surfaces as the ventilation can act as a mini vacuum cleaner and encourage dirt build up.
Soft surfaces also block the vents causing fans to run more and burn out sooner.
Hope this gives you the information you need
Nov 23, 2009 | Sony Computers & Internet
Computers & Internet Logo
173 people viewed this question
David Payne
David Payne
