Question about Canon MultiPASS F50 All-In-One InkJet Printer
COLOR PRINTING NOT WORKING - BLACK IS OK - Canon MultiPASS F50 All-In-One InkJet Printer
  • 39 Answers
Hi Wrbaffi,
Is it possible that you are out of color ink?
Best of luck,
Lazaruselite
Posted on Feb 24, 2009
My Canon MP830 prints only colors, not blacks?
have you checked the ink levels? sometimes the black runs out before other colors because it is used more commonly.
it could be that the device is unable to detect that it has no black ink and therefore will not notify you that it has run out.
i suggest trying a replacement ink and seeing if that solves the problem, if not, then there is a problem with the hardware of the printer.
Nov 07, 2011 | Canon PIXMA MP830 All-In-One InkJet...
How does one 'colour test' please.
Clean the Printhead & Print a test page by doing the ff:
1. Press the Ink button press the Up or down arrow key to select Test Print, then select Print Quality press OK and press Black or Color START. Check all the colors including the black & check if there are any missing dots and if there are any colors not printing correctly.
2. Press the Ink button on the control panel and select CLEANING press OK.
3. Press the up or down arrow key to select Color press ok and press Black Start.
*After the cleaning process the printer will ask you if the quality is OK, press up or down to select yes or no, and it will ask you whether black or color is ok, once you have selected you're answer press Black or Color START to print another test page. Compare the 1st and 2nd test page if it's improving, you may need to do this 3-5 times or until you get a better quality
Hope this helps Please rate if it worked Thanks!
Apr 03, 2011 | Brother MFC 490cw Color Inkjet...
My Brother inkjet printer (DCP-585CW) is not printing yellow colour.
If the yellow ink is not printing here's what you can do:
1. Press the Ink Management button press the Up or down arrow key to select Test Print, then select Print Quality press OK and press Black or Color START. Check all the colors including the black & check if there are any missing dots and if there are any colors not printing correctly.
2. Press the Ink Management button on the control panel and select cleaning press ok
Hope this helps.
Rate if it worked Thanks!
Apr 03, 2011 | Brother DCP585cw AllInOne InkJet Printer
Cyan ink is coming out purple. Tried putting in brand new toner but still have the same problem!
If the cyan or the blue ink is printing out in purple here's what you can do:
Mar 31, 2011 | Brother DCP 165C Compact Color Inkjet...
Hp 2110 won't let me print
You have to change the Print -> Settings -> Preferences
O Print in color (this means color inclufing B&W)
O Print in Black (this means print in black only)
Select the Print in Black
When the printer says replace the color cartridge, just close the window instead of saying Yes or OK.
This is not the official HP trouble shooting solution. But, it often works
Good luck
luciana44
Jan 07, 2010 | HP Office Equipment & Supplies
HP 3200 Photsmart Printer will not print properly.
You can always perform the print nozzle cleaning procedure through your printer's software. If it is new, then the black cartridge has malfunctioned. Take it and your receipt to exchange it for another. I'll bet this is the problem since your color is working OK and your text is grayscale (partially working).
Jul 19, 2009 | HP PhotoSmart 1215 InkJet Printer
Printing color is ok but no black
printer is probably too old . buy a new one
or just print everything out in blue or sumtin other than black.
(thats what i do when my black ink is out)
Jun 30, 2009 | Brother MFC 420CN All-In-One InkJet...
Copies and prints in color are black procesed, but in black are ok
Using CMY Color produces a Processed Black.
Using only K will produce a Black.
In the print driver on a PC change your default setting to Black, from the machine you can set it to use only black as well.
That Patch is on the transfer belt. which it will alwyas do, that is what color machines do.
Install the print driver twice and set one driver s Color Mode to color and one to greyscale. This setting can be accessed by right clicking on the print driver and selecting Printing Preferences, click on the Color tab and set the Color Mode appropriately.
Oct 23, 2008 | Sharp AR-BC260 Color Copier
Black won't print
I have this same model printer and had this same problem. I solved it by running the cleaning cycle repeatedly (30 times or more). It nealy drained the black cartridge, but they're cheap compared to a new printer ($100 for the mfc240c that replaced it). Press the ink button to the left of the display. Select "test print" and "print quality from the menus, then hit print. After printing, the display will ask if quality is ok. Press 2 for no. It will ask if the black was ok, press 2 for no, if the color looks ok, then press 1 when it asks if color is ok, then press 1 when it asks to start cleaning. In a minute or so, it will beep and tell you to press start. Once the sheet prints again, repeat the same sequence. I didn't even wait for the display, I would just press 2,2,1,1, each time it printed. At first the black section was blank, the one dash appeared, then two or three. I gradually gained on it until I had most of them working again, then let it set overnight and ran a few more cycles the next day and it finally all started working.
Jun 22, 2008 | Brother MFC 210C All-In-One InkJet Printer
Canon MultiPASS F50 All-In-One InkJet Printer Logo
old marine
old marine
