I am trying to install Kaspersky internet security 2009, but It will not install, Because of AVG8 needs to be uninstalled even after I uninstalled AVG8 I keep getting the same message. How do I completely uninstall AVG8 from my computer.
AVG Uninstall Tool
Instruction for removal AVG Antivirus and other similar AVG products.
1. Download and install Uninstall Tool.
2. Find AVG Antivirus in the programs list (you can use search filter, just type "avg" to find it immediately).
3. Double click on the found item in the list and wait while uninstall process is finished. Carefully follow all uninstaller instructions.
4. Uninstall Tool will remove all leftover traces afterwards (using Uninstall Wizard technology).
5. Reboot.
Hope This Helps!!! Please Don't Forget to Rate my Response!!! Thanks!!!
PREM
Hi..still you might not have deleted some of the
folders,that's why you are not able to install it.
uninstall it completely.
check it out..
thank u..
rate me..
To quickly and completely uninstall AVG program from computer, you can use an Automatic Uninstall Tool. If you are good at dealing with computer problem, you can try the manual way to completely uninstall the unwanted program. The relevant steps are as follows:
Step 1. Uninstall AVG with Windows Add or Remove Programs.
Step 2. Uninstall the program using its default uninstaller.
Step 3. Delete the files and folders related to AVG.
Step 4. Clean the registry entries via Registry Editor.
http://guides.mightyuninstaller.com/how-to-completely-uninstall-avg-pc-tuneup-from-computer
The best way to uninstall AVG 8.0 Utilities totally within minutes is to download a powerful and advanced uninstall tool as fast as you can. The powerful and advanced uninstall tool can provide you with absolutely professional solution to uninstall AVG 8.0 Utilities completely and efficiently within minutes.
