Question about Dell XPS One Desktop
Will not turn on
It acts like it is coming on and then it shuts off and repeats it self over and over again. this started after I came in to use (was on sleep mood) than a big box came up and files lost and press F12. I did and than it came on put was making a very funny noise so I turned it off and then turn it back on and now it is doing what i said in the first sentence. Also when it shut off the printer was still on and that usually goes off when the computer does.
  • Gay Beaston Feb 25, 2009
    I will try this I have tried everything else.
  • Gay Beaston Feb 26, 2009
    I tried what you suggested but it did not work. Now I can only turn on the computer with the remote but it does not stay on long. It still comes on all and than off. It only comes on for less than a minute.
  • 78 Answers
Switch on the pc then press the F8 Button until a screen appears then try booting in windows safe mode and this should reset the situation. then jsut shutdown and restart windows.
Posted on Feb 24, 2009
  • Mr fix.it Feb 25, 2009
    ok let me know how it goes so that I can help you further.
    Thank you.
  • Mr fix.it Feb 26, 2009
    I think it might be related to the power supply or maybe something with
    the actual board since it is going off and not restarting. It must be
    a hardware fault. When this happens what is present on the screen. is
    there a microsoft windows logo ?
My Canon camera turns it self off when I press the start button. the lens comes out & then the camera shuts down. When I restart it the lens retracts 3/4 & then comes right out & shuts down again. the lens...
hi, the camera must also be giving a lens error and must be making a whirring sound when turned on, hold the camera with camera off bang it with flat of hand , a few times , if this does not work , repeat it with camera on, even if this does not, when turning the camera on gently apply pressure on the front of the lens, do this just once , all the above fails , camera has to be service , lens unit may have to be changed
Aug 27, 2016 | Canon Cameras
Flat panel TV comes on by it's self
It sounds that the voltage output from its internal power regulator board is not proper. Check it.
Feb 04, 2013 | Samsung UN19D4003 TV
I have a WS-65907 tv, it wont turn on
Mitsubishi self check: MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ON FOR A MOMENT AND GOES OFF.
PRESS AND HOLD "device"(input) and "menu" buttons on front of tv for at least 5 seconds and then release both together.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protect the Convergence IC or IC's is blown---set will detect no voltage to convergence IC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES AND THEN TO GET IT TO REPEAT MORE YOU HAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
let me know what you find--hope that you find 2 blinks, a pause and two blinks--this is the most common and easiest to fix.
Oct 30, 2012 | Mitsubishi WS-65907 65" Rear Projection...
My 52" plasma doesn't turn on. The green light comes on for about 2 seconds and then shuts off. It acts like it wants to boot up but goes right back off. It did this once about 2 months ago but then came...
Local service repair man fixed my Soniq 42" Plasma TV with same problem for $180 Australian.
He said it was the start up / power up circuit board and lucky I didn't keep trying to use it or it could have damaged the secondary circuit board as well.
Feb 18, 2010 | Televison & Video
Computer shut on and off repeats over and over again
hi,
take out the power cable from the system press and hold the power button for 15 seconds and then put in the power cable and try to start, if does the same behaviour again you should contact dell technical support because it might require multiple steps of troubleshooting
Further Queries are welcome
If you find my solution helpful please do rate me
Feb 23, 2009 | Dell XPS 420 PC Desktop
Montior Repeatedly Shuts Off/Goes Black
i have the same problem .
already know what it is .
its the cfl power inverters which are build into the power supply
easy way to see is let the computer start up hold a flashlight up to the screen you should see your desktop .if so its the inverters/powersupply .
just started looking for a replacment for mine the closest i have found is around 25 bucks plus shipping wont know if it will work till monday when i can call them to match up the one i have
Jan 27, 2009 | Sceptre X9G-NagaIV 19" LCD Monitor
Fuel pump relay & fuel pump
when you turn the key on the pump should run to purge the system . so now you have fuel pressure for starting. this stage lasts about 10 seconds then the fuel pump doesnt turn on again till the computer see's oil pressure then turns the pump on. if the inertia switch has been activated it wont send the first amount of fuel.
Jul 26, 2008 | 1996 Ford F150 Regular Cab
Overload
No, one of your speakers is damaged (could be an amp channel went bad, but speaker is more likely). Unplug all spkrs, then plug one in and see if it acts normal when turned up. Repeat this until all speakers are hooked up or the culprit spkr is found.
Sep 25, 2007 | JVC RX-6018V Receiver
Dell XPS One Desktop Logo
87 people viewed this question
Alun Cox
