Question about Dishwashers
I have a SMEG slimline dishwasher (about 5 years old). When I try to run a cycle, it makes all the right noises, except the sprinkler/jets dont come on and no water comes out of them. I can hear the water being pulled into the system but it doesnt kick in to actually start a wash cycle. Any ideas?
  • pboland Feb 24, 2009
    Thank you, Dipu007, thats a useful start.
    I have checked everything working from the sink back towatrds the dishwasher. What I have doesn't exactly match what you describe but let me explain.
    Just below the kitchen sink, above the Ubend, I have 2 plastic hose type swivel connectors where the plastic hoses from the dishwasher connect. I have tightened both plastic connectors (by hand) and then opened them both to check they are clear. They are clear. There is no valve as such.
    Then, there is a small tap. I am guessing this is the water in/not tap. I closed this tight. Just below the tap, there is a metal hose type swivel connector. This connects another plastic hose to the tap and beyond. I unscrewed this connector and there is a small filter inside. (there is also an electric box on this hose, like a pump or something). The filter was clean, but there was a lot of water in this pipe which wasnt coming through. I reconnected it and turned the tap again.
    This is the bit that doesn't follow what you've described. At the point where the hose enters the dishwasher I'm not sure what's going on. There is no visible connector. I gave it a tug and there is some give in it so maybe it is springloaded. Anyway, there isn't another garden hose adapter and no strainer to check.
    The dishwasher still isnt getting water (at least nothing spins/ sprinkles).
    So, I guess that leads us to the electric solenoid valve inside the base of the dishwasher. How do I approach this to check if it is working or not?
    Thanks for your help so far
  • pboland Feb 27, 2009
  • 77 Answers
Hiya
have you checked that the jets aren't blocked if they are not blocked i wud 100% says its the water pump that isnt working
Rik
Posted on Feb 27, 2009
  • 19,396 Answers
The valve is inside the machine and it is called inlet Valve.
On all filling problem test the water level switch, the one actuated by a floater sensor.
Ensure the floater is not stuck in up position, and that the switch is working.
If there is no water at all getting inside the machine, then your machine has probably a defective inlet valve. The valve must be tested and eventually replaced.
If there is water getting into the machine, but it is not spraying, then there is need to test and eventually replace the impeller pump, that pumps water on the spray arms.
Also control board must be tested, as that can cause any kind of problem.
Some of the test are complicate, some test for impeller and inlet valve for example require energizing the unit directly, and reading voltages inside the machine using a multimeter on live AC power, those kinds of tests should not be done by the home user.
Basically, if water is getting inside the machine but not spraying, check the impeller pump, that is first suspect.
Always unplug power cord or trip circuit breaker before working on your appliance.
Regards.
  • 564 Answers
Check the float switch inside the tub, it should move freely up and down.
Check the drain line it will be clogged . clean it .
I guess its like the drain pump is defective.
Disconnect the drain hose under the sink & place it in a bucket, start the dishwasher in a drain cycle.
If no water drains out, you will need to replace the drain pump.
Here is what you need!!! Click on the Above Link. Download Software!!!
Hope This Helps!!!  Please Don't Forget to Rate my Response!!! Thanks!!!
PREM
Posted on Feb 24, 2009
    President:
  • 2,110 Answers
You'll have to first ensure that the valve is open where the supply gets its water from the sink supply, and water is getting to the dishwasher. There is a garden hose type swivel adapter after the valve, right? Close the valve tightly- even if it scrapes the wood - and then unscrew that hose coupling and see if the hose is full of water. Look there for a strainer inside the hose that is clogged. Clean it. If that is good, reconnect and ensure it's tight.Open the valve. Now check the dishwasher to see if it's getting water. Then at the point where the hose enters the dishwasher is a spring loaded hose ring coupling, right? If not, and there's another garden hose adapter, remove that (after turning off the water again)and see if there's a strainer there. If water is supplied to the dishwasher okay, then it is probably the electric solenoid valve inside the base of the dishwasher.
  • 544 Answers
Thank you for choosing Fixya.com
Please check the motor of your Dishwaher.
  • Mark Milan silaran
    Mark Milan silaran Feb 24, 2009
    Hello their again,
    check if the un usual sound are coming to the motor?
    let me know after you check please.
Bosch dishwasher timer sticking
I have been told to replace the timer which I am looking to do the same to my machine!
Mar 24, 2009 | Bosch Dishwashers
Bosch dishwasher timer freezing
There is a recall on the control board of many of these models, butyour problem is likely not related. It sounds like a plugged drain system or a possible bad drain pump. That's why you are hearing the pump running constantly. I have written a guide to help. It is here. Thanks!
Mar 24, 2009 | Bosch Nexxt 300 Series WFMC2201UC
SMEG dishwasher - cycle buttons
What is the model of the dishwasher? Open the door and look down the right hand side for a sticker and repost please. As a rule number 3 is a normal wash :D
Mar 23, 2009 | Smeg 18 in. DWI410 Built-in Dishwasher
Smeg dishwasher not orking properly
if water is coming in the drain then you could have a bad check valve. when you open the dw at the end and there was no water it was because you were in the drying cycle and the eement was drying the water as it came in.
Jan 11, 2009 | Smeg CSU2001 Built-in Dishwasher
Loud Whirring Noises
very possible that it is indeed something stuck in the chopper assemble, remove the lower wash arm, from ther youll remove 4-5 torx15- screws and then under there you find another torx 15 screw , after removng the screw you can pry up hte cover form the right side and reveal the chopper assembly, i would refrain form removing the chopper if at all possible, its kinda a pain in the rear to put back in, buit you can cean any junk out if ness.
Jan 11, 2009 | Dishwashers
Neff built in dishwasher
these arms rotate only by water jetting out of angled jets at the end. it is likely that these jets are blocked - not always obvious
Nov 10, 2008 | Neff 24 in. S5456 Built-in Dishwasher
Smeg Slimline Integrated Dishwasher
Hello Jan
The manual in the link suggests your dishwasher is in Cold Pre-wash mode. Wavy line and two plates. It may be stuck on it, or prehaps your particular model has a setting to pre-wash until programmed to do otherwise.
First tip is always to disconnect from the mains for 20 minutes and start again.
Due to the age of your machine, it may be in warranty, as some have 1 year and some have 5 year. You could also contact them direct and ask their service department.
http://www.smeg.com/contact-us/
http://www.smeg.com.au/smeg_au/docs/user_manuals/DWA147X.pdf
Mar 01, 2017 | Smeg Dishwashers
Kenmore dishwasher
Mine eventually "fixed itself". I think some debris got caught and eventually (5 cycles or so) got ground up and sent through the drain. The noise changed each time it got closer "flushing out"
Apr 01, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
Smeg dishwasher
my hotpoint dish washer aquarius is 4 years old leaves a sandy grit all over dishes water not spraying the top,done all the usual stuff run out of ideas
Mar 09, 2008 | Dishwashers
SMEG DI 612CA. Dishwasher
Pisss!!! Comin from my asss!!
Mar 04, 2008 | Smeg Dishwashers
Dishwashers Logo
29 people viewed this question
Top Dishwashers Experts
