Question about Hotpoint Freezers
Fridge/Freezer combo - Freezer working fine but fridge is not
Hotpoint FF200E Frdige Freezer.
Freezer is working fine.
Fridge is not getting cold. The frdige lights comes on when opening the door bu it is not getting cold.
  • 3 Answers
There is a duct between the freezer and refrigerator. Sometimes this duct blocks off with ice and won't allow airflow. Open your refrigerator door and check for air flow if there is none the duct needs to be defrosted. turn off freezer/ refrigerator and defrost.
Posted on Feb 27, 2009
  • ian jones
    ian jones Dec 05, 2013
    does this stop the fan working
Hotpoint fridge freezer ff200 tx displays error code A1?
These tempratures are pretty cold should be around 0 deg. but it sounds like you might have a bad defrost timer or defrost thermostat the frost should not come back if defrost system is working
Jul 26, 2014 | Hotpoint Freezers
Fridge works freezer does not Zannussi
the fridge will soon stop to! all cooling goe to the freezer first! look to see if there is frost in back of the freezer if not it might be low on charge
Apr 11, 2010 | Freezers
Hotpoint fridge freezer icing up freezer and fridge does not work
Does your model have independent thermostats for the fridge & freezer???
If not, could be that you will need to change the Thermostat.
These are not expensive - around £10 if you buy on the Internet.
Easy to fit yourself...just turn off the power, remove the power plug from the wall, then unscrew the 'stat unit from inside near the top of the fridge (some are attached to the interior light) and remove the screw holding the thermostat tube to the rear wall.
Often the thermostat gets a small hole somewhere in the long tube, which then lets all the gas escape, making the stat useless.
You can see these small holes in the pipe if you use a magnifying eyeglass, like the kind Jewellers use.
Nov 17, 2009 | Freezers
Amana BR18 Doesn't get cold
Mine is doing the same thing
Jul 05, 2009 | Amana Freezers
The fridge is cold but the freezer won't freeze
It has seperate cooling circuits as you describe the problem can be a leak of refrigerant in the freezer circuit.if there is no heating up in the freezer condensing coil.It has to be check for the leakage.
Jul 01, 2009 | Freezers
Frezer does not seem to be working in the cold
s it should the ambient temperatures that you said are way to cold to expect the freezer to operate properly. move it indoors and or contact the manufacture and see if the have a kit to put on the unit to work properly.
Jan 10, 2009 | Freezers
Hotpoint rfa70 fridge seems not to be staying cold
just give it time as the freezer has to come down to temp first
Jun 05, 2008 | Freezers
Fridge not cooling
Three most common problems are bad evaporator fan motor, defrost problem, or damper motor.
Sep 30, 2007 | Freezers
Freezers Logo
843 people viewed this question
Top Hotpoint Freezers Experts
christian nielsen
Victor Nwachukwu
Victor Nwachukwu
Ken Wieczorek
Ken Wieczorek
Are you a Hotpoint Freezer Expert? Answer questions, earn points and help others
