Question about Refrigerators
Small Fridge Problem
Light is on but hot inside!
  • leanne_miers Mar 06, 2009
    it is on the highest setting, it must be another problem :(
  • 27 Answers
Rotate clockwise the thermotat nob to increase cooling inside the frigde
Posted on Mar 06, 2009
Whirlpool fridge freezer
either the return air grill(small grill on the inside wall of fridge) is blocked with a loaf of bread or something, or it's the freezer drain is blocked, some fridges use the drain as a return air vent,after unpluging it from the power point, defrost the fridge a remove the back wall plate (interior) of the freezer , & push something down the drain line like whipper snipper cord etc. then poor really hot water down it, check the drain at the back of the fridge for water running, reassemble the fridge pug it in & you should be sweet
Jun 02, 2013 | Freezers
Freezer works but fridge doesn't for Doc Henn. I couldn't see your video but more common reason for this would be the small fan usualy behind the inside back panel of the fridge. The freezer is the pa
Check to make sure the light in the fridge shuts off when the door is closed. You'd be surprised how much heat is given off by that light. If it stays on either take it out or replace the switch.
Apr 02, 2013 | Refrigerators
I have a kitchen aid superba ksrg22fkss15 side by side fridge. Last night the freezer stopped working and I am still trying to determine if the fridge side is working. I pulled off the front and back and...
Can you hear if the compressor is running? The high pressure side of the compressor should be too hot to touch, over 140 F. I assume you mean the condenser fan motor at the bottom of the unit. Try to feel how cold the evaporator coil inside the refrigerator box is. A small capillary tube enters one end of the evaporator. That is the coldest spot. It should still feel at least 35 degrees or colder at the other end of the evaporator where the larger suction line is located. The whole evaporator should be cold. A small portion or none of the evaporator is cold means it is not working. The freezer evaporator should be near -30 F.
Oct 11, 2017 | Refrigerators
My Kenmore elite mini fridge turns on and the light on the inside comes on and the compressor is running and is pretty hot but the fridge is not getting slightly cool, what would cause this and how could i...
We had small fridge in our RV Travel Trailer.It would run to the tempure control setting,then it would shut off.Check it out,set it up high,then as is cools in about 12-24 hours then set it to 3-4 setting that should keep fridge Kool.Or you may need some fridgerant reinstall.Call your local repair man to quotes to recharge/fridge.Hope this help you out.
Aug 08, 2010 | Microwave Ovens
Leaking water inside refrigerator-model FRT18KC3BW2 I need know where to clean out the lines
you have to take the center bar down inside the fridge. It is the bar on top of the fridge compartment that houses the lightbulb. Unplug the fridge and unscrew the bar. There is one plug that must be unplugged, then you can pull it down. In the back is a small reservoir for water melting down from the freezer defrost, and a small tube stuck into a hole in the backof the fridge wall. pull the tube out, then flush hot hot water mixed with bleach into that hole. It will flush out anything stuck in the drain tube. If this doesnt work, you will need an external drain kit.
Nov 12, 2009 | Refrigerators
Frige gets hot and makes clicking noises.
Sounds like the compressor is not working very well the clicking is the compressor starter trying to start the compressor. May be low on freon or bad compressor. You can probaly buy one cheaper than fixing this one
Dec 26, 2017 | Haier Refrigerators
Started dripping inside fridge but now fridge is not cold freezer is cold but not as cold as it should be.
okay this is a defrost problem.You should find the timer in tp part of fridgr. there is a small hole size of a ballpoint pen You'll need a small flat screwdriver head to turn to advance until you hear a small click Then clear freezer and look for the faint glow of the defrost heater i will burn you if touched while hot.
Mar 14, 2009 | Refrigerators
Hot refrigertor
the fridge comes with condenser concealed inside body which removes heat from fridge & transfer to atmosphere hence it is found warmer than atm. temp.which is normal.the condenser is pipe in very long length to improve better heat transfer.this design also helps to remove sweating on body occured by cold air in fridge comp.u will find the hot effect is not everywhere on body because it is hot wherever the condenser pipe is there
May 22, 2008 | Samsung RS2630SH Side by Side Refrigerator
Refrigerators Logo
48 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
