Question about Kenwood VR-405 Receiver
Kenwood KRA 5050 Reciever Crash!
The Reciever was working perfectly and was hooked to my xbox 360 via optical and all was well.
One day I disconnected the optical connection from my 360 and connected it to a Media Player (Western Digital Media Player), and the reciever just crashed! All the lights on the reciever stays on (LCD and LED's). All the buttons are non-responsive, including the standby button. Even if I take it out from the mains and switch it back on, I still get the same result.
Can anybody advise me what to do, or is my reciever now a large brick?
Thanks in advance.
5 Suggested Answers
SOURCE: Dolby Digital Has Stopped Working
there isn't such a button on the reciever... at least if there is, it's not obvious. Where would such a button be. There is a small red LED light that comes on when dolby digital is working. That's about it. There is no mention of THX anywhere on the receiver
Posted on Jan 11, 2008
VOTIT
  • 2071 Answers
SOURCE: Kenwood KRA 5050 No power
I think the movers mishandle your unit that why it happen like that.It needs to reheat or resolder because the solder holding the spare parts are loose or crack,so when it resolder already performance will come again .That all Txjay , just for now.
Posted on Jun 18, 2008
mlapres
  • 757 Answers
SOURCE: Got a Kenwood vr405 surround receiver, a Sanyo
If you would like to use high definition audio decoding, connect the HDMI from the blu ray player to the receiver. If that it not an option for you due to lack of equipment such as an additional HDMI cable to go from the receiver to the television for the video portion of the signal, then connect your optical cable again. After the optical cable is connected, make sure the Dolby Digital decoding is enabled on the receiver, and that the media you are playing also has a version of 5.1 surround sound. Then, enter the setup menu of the player (which I suspect this is actually where the problem might reside in your case) and make sure that Dolby Digital and DTS are not set to "downmix." Dolby Digital should be set to output Dolby Digital and so on and so forth...hope this helped.
Posted on Jan 14, 2010
Testimonial: "Thank you for the insight. I may have figured this out on my own eventually but this definitely got me situated much much faster. "
  • 744 Answers
SOURCE: show me a pictorial diagram of a dipole antenna connected to a stereo reciever
You didn't list your receiver model number, but here's a generic picture of how you would connect an indoor FM dipole antenna to a Kenwood receiver. These antennas should be available at most home improvement stores or from Radio Shack. They cost around $10.00, maybe less.
Depending on your model, you may have use some adapters. Ask the store staff for help.
Posted on Aug 18, 2012
My xbox 360 causes my hdtv screen to crash and display colored static. It only does this on the 'optimal display' of 1680x1050. I plugged in my laptop on the hdmi and it worked perfectly. Is t
Try manually choosing lower resolutions in your xbox display settings. My Insignia HDTV does that when switching resolutions like on Hulu in between commercials and then back to the show but only for a second or so. Also does this when going from the loading screens to the game screens for a few seconds when playing the game Split/Second
Jan 10, 2013 | Microsoft Xbox 360 Console
Hello, I recently hooked my Xbox 360 up to my surround sound system using a digital optical cable ran from the xbox to the TV (optical cable from 360 to sound system) Sound and video works great for...
HDCP is the "handshake" protocol used by the Xbox to communicate via HDMI to your TV. The optical cable wouldn't have anything to do with this error. So far the only solution that's been found to this issue is to ensure that the HDMI cable is properly plugged in and power off/on both devices and see if the handshake is restored. If this doesn't work you may need a new HDMI cable.
Jun 27, 2011 | Microsoft Xbox 360 Console
Xbox elite connected to TV thru HDMI works fine, but connected via bcs-fs500 receiver = no audio or video Cable tv through receiver works fine Have tried cable tv through receiver inputs HDMI 1 and 2...
Hook your Xbox to tv via HDMI, then hook TV to reciever through digital optical or composite cables. If you try to get your picture through receiver first, you may get picture and sound but, sound may be delayed and picture might not be the best. Bettter to run through tv first then provide sound to receiver.
Mar 31, 2011 | Pioneer Audio Players & Recorders
I can't get sound from my HDMI Cable.
check the system settings of your console and make sure everything matches what your tv supports. Also check the tv settings so that it reveives audio from the HDMI cable
Aug 09, 2009 | Yamaha HTR-6130 Receiver
Audio Issue
You may have tried this, but when you hook up audio out from TV to audio in on reciever, did you try the different input options for the reciever. Often times, audio in is an aux1 or aux2 setting on the receiver. If it is working with the DVD player, it is functional, you just have to get the wires hooked up and get the reciever on the correct setting. Also, even if you have TV audio out correctly configured to audio in AND on the correct input setting, the TV volume will have to be UP as well as the receiver volume. NOT ALL THE WAY UP (you'll blow your speakers), but up about 25% for you to hear it.
Jul 29, 2009 | Audio Players & Recorders
Yamaha HTR-6130 sound only from centre, rear or front speakers
its not how there connected its in your settings. rehook up all your speaker connections properly,then make sure you proram the reciever to recieve fiber optic,hdmi,digital coax etc in the reciver.
May 18, 2009 | Yamaha HTR-6130 Receiver
XBox 360 to Reciever to TV via HDMI no sound
I recently got the same receiver and had the same problem. Here's what I was told - and it worked for me:
Even though HDMI cables carry audio and video, for whatever reason this reciever won't accept audio through hdmi. Apparently only much more expensive recievers carry audio through hdmi. What you have to do is run optical audio cables from your xbox, cable box, dvd player or other video device to the optical inputs on the back of the reciver. Then you customize the scene buttons to match your video and audio inputs.
You can get these optical cables pretty cheap on line or even at target. Don't get ripped off by Best Buy for these cables. I love best buy, but they rip off on cables!
This receiver is great - once I got it all figured out and running right I've loved it! Hope everything works out for you!
Mar 09, 2009 | Yamaha HTR-6130 Receiver
Jun 18, 2008 | Kenwood VR-405 Receiver
No Sound when I play DVD's
The optical connection on the TV is most likely an input, not an output. You need to connect the Xbox to the receiver, then the TV. If the receiver does not have a HDMI input, use another audio or digital out from the Xbox to the receiver.
Sep 19, 2007 | Yamaha HTR-5940 Receiver
Kenwood VR-405 Receiver Logo
202 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
