Question about HP Compaq d530 SFF PC Desktop
Power supply problem
My computer power supply has a problem and it doesn't pwer up when i put on so woild you mind to hepl me solved this problem
  • 46 Answers
Check the voltages of cable coming out of ups , if cable is faulty replace cable
next try to check your smps by sharting green & black cable
Posted on Feb 24, 2009
Power Supply bad working. Blue led doesn't light.
Hi, I'm having the same problem with one of mine M1 Active 620. Please have you found out characteristics of D5 Zener diode, voltage?
Nov 13, 2012 | Alesis M1-Active-MK2 Powered Studio...
How do I bypass the power switch on a Gateway DX4822-01 PC
I went through this same scenario.Motherboard,power supply, ram, Couldn't figure it out.Turns out it was the Power button itself.Put all the components in a new case an viola everything works
Feb 18, 2012 | Gateway DX482201 (PTGA002002) PC Desktop
The only thing i know that the power supply shows 300w max. computer is about 3 years old & will no longer turn on. there is no noise to indicate that it is working or getting power
These use a standard Power Supply that you can get from almost any computer shop
Better to get one slight higher rated so maybe a 350 or 400w PSU
you can replace these yourself as the connections are pretty easy to follow and only four screws around the supply hold it in
It is a common e-machine issu so long as it has not taken out anything on the motherboard you should be fine.
I have seen the emachines pwer supply take out the main board on occasion although it is quite rare
Feb 04, 2011 | eMachines D3123 Desktop Computer With AMD...
Persario will not power up with switch, I unplug the power cord from the wall. wait about 5 mins, then plug the power cord back into the wall. the computer powers up without the power switch then shuts off...
IS THAT A Relic CRT monitors/?? wow.
the PSU is dead if the power button acts dead
no fans right ? no sounds, the 2 or 3 fans do not spin and blow
1: bad PSU
2: or objects plugged into the mobo are shorted,
3: mobo dead (Motherboard)
do the jump test?
Jan 24, 2018 | Compaq Presario 4410US (470027-053) PC...
Optiplex GX280. A,C lights remaining yellow and B,D lights remaining green
you either have a bad proccesor, or memory, one other thing come to mind is that the pwoer supply may need to be cleaned out use a hair drier and point it at the power supply open the case and do the same for the whole inside pluse the insde holes of the pwer suppply
Jun 25, 2010 | Dell Optiplex GX280 (99301) Motherboard
Any luck? I need the power supply cord too.
hello there:
If you have a thrift store or a goodwill store around your area they are a great place to get power supply cords and speakers and keyboards and power cords for these items ok:
please dont forget to give my solution a rating this really helps me out so i can help you out ok ?
best regards michael
Aug 19, 2009 | Harman Kardon HK595 Computer Speakers
Remval of power supply from hp d530 compact desktop
there are 4 screws on the back of your computer that will release the powersupply at that point you should be able to just slide it out keep mind were you unplug things
Company site
Jun 18, 2009 | HP Compaq Business d530 Ultra-Slim PC...
Will not pwer up. Greenlight blinking on back
The green blinking light can mean there is a problem with the power supply.
Try unplugging the computer from the wall, and turning on the pc on switch.
After a few minutes, try plugging it back in.
If that does not start things up, you may have a bad power supply.
If the power supply is bad, these models take standard power supplies. You should get an ATX 350Watt or higher power supply.
They are easy to replace, unplug the power from the wall, disconnect all the cables inside the computer. Unscrew the four phillips screws outside the back of the computer where the power supply is attached to the case.
Remove and replace.
If you don't feel comfortable with this, a good local computer shop can help you out.
Apr 13, 2009 | HP Compaq Presario SR1330NX (PP161AA) PC...
Gateway 838gm no video
Are any fans running? If not take the power supply to a reputable computer repair person. They can test it while you wait. If the power supply is good or the fans are working then I would remove that new RAM. My guess is the power supply is bad.
Good luck
Mar 22, 2009 | Gateway 838GM (RB838GM) PC Desktop
HP Compaq d530 SFF PC Desktop Logo
94 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
