Monitor model # EN7410e repeatedly flickers on and off when coming out of screen saver mode. Once it's on it stays on. Is this a fixable problem?
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Offhand, your description, specifically the flickers, indicates the inverter powering on/off while initiating. Technically, this could be caused by insufficient voltage from the power supply or the filter capacitor that has leaked and therefore does not provide the necessary 'boost' on startup (from standby condition). If the unit does still functions even intermittently, then it should be relatively an easy/minor repair involving minor parts replacement and/or cold solder re-soldering. While repairs would be relatively easy and quick, this would require familiarity with electronic components & circuitry, use of a DVM and a soldering iron. Access to a service manual or at the very least a schematic diagram would be to your added advantage.
Should you be uncomfortable performing a DIY (do-it-yourself), then perhaps your best bet would be to seek the services of a qualified professional. Pls reference the pages here and/or here of similar concerns.
Good luck and thank you for using FixYa.
Posted on Feb 24, 2009
    Guru:
  • 832 Answers
Hi there! thanks for using fixya!!
Please check your connections, cables that connected to your monitor from your pc and outlet.
Or do the following:
Turn off your computer.
Restart your pc and then press F2 Key.
F2 will take to Bios
and leave it for awhile and check if will going to flick again...
Or you may check the Video drivers...
regards!
  • Dennis Jambalos
    Dennis Jambalos Feb 24, 2009
    hi again!
    If the problem still there, I suggest that you should consult the service technician, so that he can further and accurately troubleshoot what really the problem is...might be electrical of some sort...
    regards!
  • 564 Answers
Thanks for Choosing FixYa!!!
  1. Turn the Computer Off.
  2. As Soon as you turn on keep tap the F2 Key.
  3. It Take you to bios Screen.
  4. Leave for 10 Minutes and Check whether its turn off or not.
  5. If not, Restart and As Soon as you turn on keep tap the F8 Key.
  6. Get in to safe mode and unistall Video Drivers.
  7. Get in to normal mode and install latest Video Drivers.
Hope This Helps!!!  Please Don't Forget to Rate my Response!!! Thanks!!!
PREM
    President:
  • 2,110 Answers
Try to change resolution to a lower value and change the frequncy little bit high....you can do it in graphics setting...
    Sergeant:
    Champion:
  • 289 Answers
Hi..it has nothing to do with graphic card or either cpu. It maybe because of loose plugs or the most common thing which is the push switch which turn on your monitor which is most probably located on your monitor might be loose and doesnt contact properly. check this out.. thank u..
  • 495 Answers
Check your connections, maybe they are just loose. when your comp is on and your montior is on move your wires around. that might be the problem. well i hope this helps a little.
  • Manoj Rout
    Manoj Rout Feb 24, 2009
    Why does a monitor may flicker ?
    A monitor may flicker and goes into rolling state due to dust, overheating after a long continuous usage, loose circuitry or due to some electromagnetic interference with other electrical equipments like tv , UPS, large speaker systems etc.
    FIX :
    Take appropriate precautions for these types of problems with
    your monitor. Keep it dust free and ensure proper heat dissipation.
    Keep your speakers, TV and speaker system etc. at a distance from the
    monitor.
    If you don’t think any above possible reasons for the rolling or
    flickering state of your monitor then we recommend you to get your
    monitor checked by the monitor company at their respective service
    center.
I have a dell studio 540 desktop, I need to restore to factory settings but my monitor will not stay open. It opens for a few seconds then immediately goes into power saver mode and turns off, how can
I see two things here, but need clarification;
1) Monitor goes to Power Saver Mode, then turns -> OFF?
Sure that monitor didn't go into Standby Mode?
2) Why are you performing a restore back to factory settings?
Pick up a virus?
Primer;
The monitor receives a signal. A video signal. The video signal comes from the computer.
If the monitor is NOT receiving a video signal, then the monitor will state No Signal.
This is for older monitors.
New monitors do not state No Signal anymore.
It's Power Saver Mode, or Sleep Mode.
If the monitor is truly OFF, the Power On button will Not be lit up.
Or the Power On LED light on the monitor.
Monitor power on LED is lit, or Power On button is lit?
Monitor is not receiving a video signal;
Use a monitor cable from a KNOWN to be working monitor, for a temporary test.
OR,
Use a Known to be working monitor, and it's monitor cable.
Need to find out if monitor cable is good.
Monitor cable checks out good?
Then problem is computer.
The two leading issues with desktop computer failure, is;
1) Computer is dirty inside
2) Power Supply inside computer is bad.
Please post back in a Comment.
Regards,
joecoolvette
Mar 27, 2013 | Computers & Internet
Screen stays on for about 20 minutes than shuts off after that..if you turn off and turn back on..it comes on then immediately shuts back off Its item #1704FPT 17" Monitor for 4700 Dimension...
On your Desktop, Right Click the mouse and Select Properties.
Click Screen Saver tab and Select Power. Change Turn Off Monitor
to Never. Your monitor should stay ON forever, until you turn its
power OFF.
Jul 21, 2011 | Computers & Internet
Lg monitor - ''Analog Power Saver Mode''
Kindly check the power supply inside your system, when you power on does the fan rotates. if not then you need to replace the power supply of the system.
i hope this will resolved the issue
May 25, 2010 | Computers & Internet
My averatec lcd won't stay on
Can you try your monitor on another computer to see if it does this there as well? Usually this happens only when video is not detected coming from the PC. It could be as simple as a short in the monitor cable. If you have it connected to a laptop you'll also want to check you control panel power setting rules and then the screen saver under display.
Apr 14, 2010 | Averatec D1133 (D1133AH1E-1) PC Desktop
Steady orange light above the battery looking symbol
it sounds like you might have a bad board or memory card. If you dont hear the normal sounds from the computer as it boots up, its an internal problem.
Apr 15, 2009 | E-Machines eMachines Desktop PC
Monitor is in sleep mode
  1. right click on desktop
  2. click properties
  3. click screen saver tab and adjust the settings
  4. click 'power settings'
  5. adjust the settings
Jan 25, 2009 | Computers & Internet
Screen saver
CONTROL PANEL
THEN DISPLAY
THEN SCREEN SAVER
You will find your settings in there
and will be able to set your screen saver then if you click settings at the top then power you'll be able to set when your hard drive and monitor shut off if you need more info just let me know
Jan 14, 2009 | Dell Inspiron 530 Desktop Computer
Screen does not stay on it just flashes on every four sec
Sounds like the refresh rate of your video adapter is set incorrcetly, especially if the monitor is new to the system. CRT monitors could handle a wider rate range than the current LCD's.
The next time it starts working correctly, go to "display settings" and check the "monitor" tab. For a LCD monitor, the refresh rate should be between 60 and 72. Experiment with the different rate settings to optimize your display.
Hope this helps
Nov 19, 2008 | Compaq Presario SR1120NX 2.66GHZ Tower w/...
I have a Toshiba Satellite P100 laptop which I bought in New Zealand. I think the model comes from the USA. Part of my screen is flickering. It runs vertically from the top to the bottom of the screen and...
Good morning, Kevin!
Sounds like an LCD problem. You can verify this by hooking up an external monitor. The external monitor will probably show a good display.
After verification of the problem,you may want to try to replug the LCD cable at both ends, just to see if that corrects the situation.
If that resolves things, all is well and good. If not, you may need a replacement LCD.
If the external monitor shows the same display, you may have a motherboard problem.
Hope this information is of some help.
Ron-
May 09, 2008 | Computers & Internet
Is this a Software/Config/Hardware Problem ?
hmmm..sounds like a sleep or screen saver conflict...try booting up on Safe mode(F8) on turn on, and then see how that works. Set your screen saver for Never, and see what happens.
You may be hitting a thermal issue with your video circuitry.
Feb 18, 2008 | Dell Dimension 4600 PC Desktop
Open Questions:
Computers & Internet Logo
Brian Sullivan
Brian Sullivan
joecoolvette
joecoolvette
