Question about Dell Vostro 1500 Notebook
80G Hitachi IDE only 34xxxMB has been formatted
Hi, i got a new 80G Hitachi IDE hard drive, the BIOS was able to detect the correct capacity but when i run WinXP setup, only 34xxxMB was detected. it says the 34xxxMB is unpartitioned, would you like to partition/format/setup. i wonder where is the other half now? what will i do to be able to use the entire 80G?
I will appreciate any information you can offer.
  • emvals4 Mar 02, 2009
    i did continue with the winxp installation but i was never able to see the rest of the partition.
  • 202 Answers
Click on START, right click on My Computer and then click on Mange. When the management window opens, look down the left side until you find **** Management. Click that and on the right side you will see the drives installed. Your HDD should be labeled Disk 0. The size of the drive will be listed. To the right of that you will see a display of the partitions. Yours will probably show the 34xxMB C: partition with and unused area to the right. Right click on the unused area and you should get a prompt to create a new partition in the unused area. Say YES and follow the prompts to create adn format the new partition. You can label it if you like. When that completes, you will be able tosee and access the remainder of the drive in Windows Explorer or any other application.
Good luck and please let me know how it works out for you.
Posted on Mar 03, 2009
    President:
  • 1,223 Answers
Actually the 34XX mb is unpartitioned may be u will find the other half after install dont worry install xp and then see there will be 2 partitions
Posted on Feb 24, 2009
Mine hitachi hard disk is 80GB SATA i cant able to install OS because it is showing error some virus found and u r not able to formate this. first when i put OS CD in drive it will install some files and...
The problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS anddisable the SATA drive (enable IDE emulation), this will make XP think it is aIDE/PATA hard disk. Then you can install XP normally. When Windows hasbeen installed then install all the device drivers (including the SATA driver),then shut down and boot up and got into the BIOS and enable the SATA drive.
Apr 15, 2011 | Hitachi (14R9464-20PK) 250 GB Hard Drive
I have few 80GB Hdd Model # ST380020ACE IT DETECT IN BIOS BUT IT SHOW 0 MB SIZE IN BIOS AND EVEN I CANNOT RUN FDISK PROCESS PLEASE GUIDE ME IF YOU HAVE THE SOLUTIONS. Note : if i use this drive as slave...
Since you mentioned slave, I'm going to assume this is a IDE hard drive (with the 2" wide ribbon cable).
Check the sticker on the back of the hard drive for the correct position to place the jumper on. Often hard drives require different settings depending on whether they're the master, slave, or the only drive on that IDE cable.
Note: generally it's a bad idea to mix optical (CD/DVD) devices and hard drives on the same IDE cable.
Mar 01, 2011 | Seagate U Series (ST380020ACE) Hard Drive
I am not able to instal OS in my home PC. Asking me to install scsi drive. my hard disk seagate. where download this flopply disk bios drive software
hi
Checked the Bios Setting and check whether the Hard drive is recognizing or not -
Check the Boot sequence
Check Boot from the CD Drive
Format the Hard drive
it will work
Feb 23, 2010 | Seagate 500GB Maxtor Diamondmax21 SATA2...
Sata hdd not detected in bios
Tried a differant SATA power inout into it? Is it making a clicking sound?
Feb 18, 2009 | Samsung SpinPoint T HD501LJ 500 GB SATA...
New hard drive required for v20
The hard drive that is installed in the V20 laptop is a 30 Gb IDE capacity hard drive.
The smallest IDE hard drive that you can purchase today is in the order of 80 to 100 Gb capacity. The BIOS in the V20 may not be able to support a hard drive this large.
If you install a hard drive of this capacity the BIOS may not detect it or it won't allow you to access the full capacity of the hard drive.
Jan 21, 2009 | Samsung V20 XVC 2400 Notebook
Hard disk drive not detected
firstly check your cable connections, then log onto your bios setup menu during startup and check whether the Hard drive is detected by your bios, if it is then you can try to format the harddrive using the ntfs system (use the long formatt) if you are using windows xp or later if using any earlier os then formatt with the FAT32 system.
If your HDD is not detected by the bios then try to download bios updates for your motherboard and install thed in windows. is this does not work then its time to get a new HDD. thanks
May 27, 2008 | Hitachi hts548080m9at00 80 GB Hard Drive
Dell Dimension 5000
you problem is most likely that your bios is out of date. download the latest bios updates for your motherboard and then when you install windows format you HDD with the ntfs system (using the long formatt system not the quick format). Then you should install the bios update. then your mboard shoud no longer have the problem of recognising your large capacity HDD. thanks
May 18, 2008 | Computers & Internet
I am try to put a ide hitachi deskstar in my pc but cant get it to boot help
have you tried to enter in bios?..if not, go to bios and find out if your hard drive is detecting or not...then if your hard drive is not detecting, try to change your ide cable..^^
Mar 10, 2008 | Computers & Internet
Problem maxtor hard drive
What type of Computer are you installing this 80g drive on? How old is it? I need to know some specifics, because in older machines the BIOS are not setup to recognize large capacity HD, in addition you may have recieved a bad Drive. Please advise! I may have an answer for you!
Nov 26, 2007 | Maxtor Hard Drive
Hardisk cant be detected
hard disk can't detected by bios.i also can't format my laptop because of it can't detect my hard disk
Sep 21, 2007 | HP/Maxtor 40GB 3.5 IDE/ATA Hard Drive...
Dell Vostro 1500 Notebook Logo
50 people viewed this question
Alun Cox
