Question about Toshiba Tecra 8200 PT820U-OFG8C801 Notebook
Laptop crashed my wife hasn't got a system disk for her lap top so need to download and copy one
  • 4 more comments
  • kennedyned48 Feb 24, 2009
    when computor is switched on the following appears on screen intel(r)boot agent version3.0.05, copyright(c)97-2000, intelcorporatin,pxe-61:,media test failure,check cable,pxe-mof:exitingintel pxerom. insert system disk in drive, press anykey when ready
    does this also work with windows xp
    still comes up insert system disk does your advice still work for windows xp professional
    computor still has origial hard disk we have changed nothing
  • kennedyned48 Feb 25, 2009
    we just turned the computor on one day and what i have described written on screen came up i have tried your suggestin to hold down zero before switching on but same message comes up to put system disk in
  • Shoaib Rais
    Shoaib Rais May 11, 2010
    is ur wife's laptop working doe it have OS right now if not how it crashed what do u mean by that u have changed some parts like hard disk or what pls tell me in detail in what way it crashed
    President:
  • 1,223 Answers
If u have not changed ur hard disk just want to restore ur system from a crashed windows u can do it as below without any cd actually a safe copy of OS is kept at a location in the original hard drive that came with ur laptop just try this and all will be ok
BEFORE TURNING ON THE LAPTOP, press and hold the 0 (zero) button on the keyboard, then turn on the computer while holding the 0 (zero) button down. When the Toshiba logo screen appears, you can release the 0 key.
it will install the operating system as it was the day u bought the notebook
pls rate me if u find me fixing ur problem
Posted on Feb 24, 2009
  • 4 more comments
  • Shoaib Rais
    Shoaib Rais Feb 24, 2009
    These instructions apply mostly to products pre-installed with
    Windows Vista. If the above method does not work, try a couple of
    times. If it does not work after several tries, you need to use the
    recovery discs for your computer in order to re-install Windows Vista.
    You should have burned these discs when you first started using the
    computer, however if you did not, you can obtain a copy of the discs by
    calling your computer's manufacturer.
  • Shoaib Rais
    pls answer me have u changed the hard drive or check in bios if ur hard drive is shown there it seems like ur hard drive is not responding to the bios MEDIA TEST FAILURE is hdd mal function pls clarify have tried this factory reset thing then this error appears or what
  • Shoaib Rais
    yes sure it will work if ur hard disk is not replaced and it is the orig that came with ur system
  • Shoaib Rais
    actually ur computer is unable to recognize the hard disk pls consider changing it , u have still not answered my question is this hard disk orig that came with this laptop , if yes then u should try re-seating ur hard drive take ur hard drive out by opening the screw beneath the laptop with a hdd sign on it open the compartment and then take ur hard drive out and then re fix it in the same manner see if it works , if it does not then u should email toshiba support explain ur situation they will send u a backup OS disk thru mail but they might charge u for that around 10 $ or 20 $ but it will solve ur problem , it seems like the health partition is also destroyed on ur hard drive that is y it is unable to restore the OS ,
    if restore disk doesnt help u then i am sure that ur hard disk has failed
    pls let me know if i can help u more on this
  • Shoaib Rais
    Shoaib Rais Feb 25, 2009
  • Shoaib Rais
    just check there should be no disk in ur DVD drive and also check in BIOS setup thru F2 see if ur disk is present in Drives list pls let me know
    if it is not recognized or found by the BIOS then my friend
    i am pretty sure that ur Hard Disk has FAILED , 100% just change hard drive and everything will be ok in this case u need to contact TOSHIBA SUPPORT in ur area u will find info on www.toshiba.com and get an OS backup Disk providing serial number of ur LAPTOP there is no other solution , it is clearly written in the error intelcorporatin,pxe-61:,media test failure,check cable,pxe-mof:exitingintel pxerom.
System recvery win 8
No you cannot do that as it is registered to another PC. If it is new, contact the seller or hp and ask them for a suggestion otherwise you are looking at formatting ans starting again. However, if you have the COA code, download Win8 and use your code to re form the OS.
Nov 11, 2013 | HP Pavilion Computers & Internet
My Lenovo lap 892229U 3000 c200 crashed and I do not have the installation cd. I loaded on the XP operating system but I am have problems loading on the drivers like the sound, wireless etc.
you probably have a secure partition. it will contain your recovery disks if you have not changed your partitions or changed disks. you may either have to create the disks from this partition or run a recovery program from this partition (drive)(folder).
Aug 23, 2011 | Lenovo Computers & Internet
How do ~I download photos that are on my lap top to a blank Sans Disk memory card?
put the card in a card reader plug the card reader into the usb port of the laptop, then drag and drop or copy/ paste the files to the laptop hard drive
Dec 29, 2010 | Dell Inspiron 6000 Notebook
My computer does not have a disk drive so how can i hook up my printer? I have a really small lap top and the printer came with a disk with instructions to insert and it would take me through the steps. I...
OKAY
1. COPY THE DISK TO A USB FLASH DRIVE AND THEN INSTALL IT.
2.TYPE IN THE FULL MODEL NUM ON GOOGLE,AND THEN DOWNLOAD THE APPROPIATE SOFTWARE FROM THERE
Jul 04, 2009 | Brother HL 2140 Laser Printer
Acer Aspire 5100series laptop - modem stopped working
Go to add and remove programs and delete updates. Then go to device manager and roll back your drivers for your modem. see if this will do the trick!!!
Darren
May 11, 2009 | Acer (91.AB193.021) Modem
Need to down load system disk for tecra 8200
I would suggest using a recovery disk, but if you need the data off of it I would take it to the a repair shop.
You can get a recovery disk here.
http://www.recovery-cds.com/laptop/search.asp?keywords=toshiba
Feb 24, 2009 | Toshiba Tecra 8200 PT820U-OFG8C801...
Now have disk
ya download a XP bootable torrent from www.torrentz.com thn burn it in to the CD thn load it in to the laptop..
Oct 07, 2008 | Computers & Internet
Toshiba Lap Top Model #PSAA2U-04E018
sounds really bad. hard drive crash scene most likely. You might want to boot from install disk to see if the rest of the machine is happy or not.
Feb 05, 2008 | Computers & Internet
Toshiba Tecra 8200 PT820U-OFG8C801 Notebook Logo
190 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
