Question about Keurig Platinum B70 Coffee Maker
Keurig coffee maker won't draw water from the resevoir
Seems as though no water is getting from the water chamber into the coffee maker. Machine says that it is brewing but no sound coming out just spits of water into the cup
  • 7 more comments
  • clyde2j2
    clyde2j2 May 11, 2010
    How long have you used this maker?
  • Anonymous Mar 14, 2014
    coffee maker is plugged, will not fill with water
  • Anonymous Mar 18, 2014
    coffee maker says brewing, but nothing comes out
  • Anonymous Mar 23, 2014
    I have keurig coffee maker that when I pour water in it it wont come out
  • Anonymous Mar 25, 2014
    it sounds like it is brewing but no coffee or liquid is coming out
  • Anonymous Mar 26, 2014
    coffee maker will not let water into the k-cup houser to make coffee.
  • Anonymous Mar 28, 2014
    nothing comes out coffee or water
  • Anonymous Mar 30, 2014
    Machine turns on and heats ,will not pump water or coffee
  • Helen Stevens
    Helen Stevens Jun 28, 2014
    This coffee maker is three years old
I just got mine to work by forcing water into the pump to force it to prime. I took a syringe for a meat injector and built a gasket so it would seal over the water intake. Then I forced several syringes of water into the pump till it finally picked up and caught its prime.
Posted on Mar 02, 2009
  • criscollects
    criscollects Nov 03, 2012
    I didn't have a turkey baster on hand, but if you pour white vinegar into the reservoir, open your Keurig like you normally would to get the liquid into the system and out of the reservior. Just let it sit there for a while. The vinegar will work it's way through. It's a slow process, but slowly it starts to get into the keurig and your keurig will evenutally start allowing the liquid to flow through. You have to keep letting it drip through, then brew. fill more vinegar, let it trickle through, then brew. It might take all day, but the vinegar breaks down the scales.
  • Susan
    Susan Dec 03, 2013
    Mine did the same thing. I tried removing the filter and running vinegar to no avail. Once I gave up and unplugged the machine, and after driving down to the closest McDonald's for some much needed coffee, I got online and started reading some of these fixes. Seemed unplugging is important because I plugged it back in and voila! it worked!
Making only a half cup of coffee - the rest of the water seems to be pouring back into the resevoir from the vent thing.
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
Sep 08, 2011 | Keurig Elite B40 Coffee Maker
My Keurig machine says, "brewing"
Aug 01, 2011 | Keurig Platinum B70 Coffee Maker
Water drips back into resevoir, only filling 1/4 cup. I have de-scaled, cleaned the holes, reset the resevoir, use only distilled water
Jul 08, 2011 | Keurig B100 Coffee Maker
The display always reads Not Ready. I have to turn the machine off for at least 10 sec now every time I make a new cup of coffee. It also sounds odd when it's drawing the water in to the heating...
There is air in the lines and it is blocking the water flow...
Here is a tip that will help you getyour Keurig to prime...
Keurig CoffeeBrewer will not prime
Jun 18, 2011 | Keurig Platinum B70 Coffee Maker
Won't draw water from the resevoir.
It's a known problem with keurigs pump. Call Keurig, they will have you send back the original cup from your machine in a padded envelope and they will send you a new machine and direct you to throw the old one out.
Jan 10, 2011 | Keurig B70 Coffee Maker
Our Keurig only dispenses a partial cup of coffee. We descaled as recommended and did the paperclip cleaning of the need,es and no improvement. When we press brew, it draws an appropriate amount of water...
Keurig coffee maker dispenses only part of a cup (about 5 ounces) after brewng one cup. Running a second clear cup (w/o K-cup) shows coffee grounds in cup of clear water. the maker will then brew a full cup of coffee. It appears that the top pin is too long and goes into the coffee after it punches through the top of the K-cup. Some of the gorunds appear to get stuck in the top pin.
Nov 10, 2009 | Keurig Platinum B70 Coffee Maker
No water.
I resealed the checkvalve coming from the resevoir.The valve is cylindrical and has a two piece exterior from the factory.Sealed it with a little expoxyand works fine.
Sep 12, 2009 | Keurig B100 Coffee Maker
Keurig Platinum B70 Coffee Maker Logo
8,199 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
