Question about Toshiba Computers & Internet
Has anyone upgraded the memory on a toshiba satellite 1900-603
I opened the area containing the existing memory chip and fitted a new 512 Mb one, according to Toshiba there should be 2 such memory slots, I could only find one, but when I rebooted the machine it told me my memory had increased from 512 to 768, so where is the other 256 chip located??? The old memory was rated at 512 and I wanted to upgrade this to 1Gb so purchased 2 chips to acieve this.
  • Anonymous Mar 18, 2014
    location of memory chip for cmos on toshiba l505
    President:
  • 1,223 Answers
It should be beneath the slot u installed the memory on both slots are next to each other one on top the other beneath i fu dont find it tell me exact model number to help u more in this
Posted on Feb 24, 2009
Can I upgrade memory to only one gb of memory or install 2 512 mb on a toshiba satellite m35x series
http://www.shopping.com/xPF-Toshiba-Toshiba-Satellite-Notebook-PC-M35X-S114
Looking at the specs, the max is 2gb for your Toshiba. According to this website, its only a 256mb ddr sdram. So my guess is you only have 1 slot for the ram. I'd go with a 2gb ram if you can afford it, 1gb just don't cut it in todays technology.
I believe its the PC2700 model, so find a 1gb or 2gb PC2700 @ 333mhz and you should be set.
Sep 09, 2009 | Toshiba Satellite M35X-S114 Notebook
What is the max ram for toshiba laptop model #
Hi Fhiken!
That modell comes with 256mb rab and supports up to 512mb ram.
The ramtype on it is SDRAM
I hope the info helped you
Nic
Aug 20, 2009 | Toshiba Computers & Internet
Toshiba Satellite 1805-s253 memory upgrade
Usually this means it supports 512 mb of "Single sided" ram, which is rarer and more expensive... the usual ram you buy now is double-sided.. which will often only see one of the sides in older machines.
Mar 13, 2009 | Toshiba Satellite 1805-S253 Notebook
Toshiba satellite a205 s5825 memory upgrade
what my audio setting suppose to set to step by step on my Toshiba satellite A205-S5880
Jan 29, 2009 | Toshiba Satellite A205-S4617 Notebook
Adding memory to Toshiba A75-S211
you buy the memory here for a great price or anywhere online instructions are on the page
it replaces the 512
http://cgi.ebay.com/1GB-DDR-333-for-Toshiba-Satellite-A75-S211-Memory-RAM_W0QQitemZ250353026446QQihZ015QQcategoryZ158897QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
  • Memory Card for Toshiba Satellite A75-S211 Memory RAM- Designed and Optimized
  • Toshiba Satellite A75-S211 Memory RAM Memory Upgrade -Easily installed
  • More Memory Equals - More Speed for your APPS
  • The Toshiba Satellite A75-S211 Memory RAM has a memory card slot or slots, that allows you to add more memory to your Toshiba Satellite A75-S211 Memory RAM, giving you enhanced performance and speed. You will see the Immediate speed increase in your computers performance.
    Stop waiting for programs, and functions to happen, STOP WAITING!!! Start enjoying technology as you should.
    We work directly with our memory card manufacturer to insure perfect compatibility with the Toshiba Satellite A75-S211 Memory RAM. Only using the highest quality memory chipsets for our memory cards, so you are assured compatibility and performance. All of our memory cards are Designed and Optimized for Toshiba Satellite A75-S211 Memory RAM . Technical specialists have personally verified our memory cards compatibility with the Toshiba Satellite A75-S211 Memory RAM.
    Worry Free Installation: Just Follow these Steps Desktop and Laptop instructions below.
    Desktops
    1. Unplug Power cable
    2. Remove Case
    3. Slide memory card in Open slots- the memory card will only fit in one way
    4. Snap the side clips in place
    5. Close Case and Power Up
    6. You are ready to go.
    Laptop
    1. unplug and remove Battery from laptop
    2. Open memory compartment on bottom using Philips screw driver
    3. inset memory in open slot, if no open slot remove current memory by pinching metal clasp on side of memory
    4. Close compartment and power up you are off and running.
    Jan 26, 2009 | Toshiba Satellite A75-S211 Notebook
    I have a Satellite 2405-S221 and I was wondering if the max memory i can install is 512K, is there a way to update the bios, or ANYTHING to increase that amount to at least 1 gig??
    Toshiba Satellite 2405-S221 Laptop takes the PC2100 DDR SDRAM SODIMMs Memory Type, and comes installed with 256 MB (removable) of Memory. You can upgrade your Toshiba Satellite 2405-S221 Laptop to up to a maximum of 512 MB Memory, the system has 2 sockets to install Memory, already with 256 MB (removable) standard Memory installed.
    In short.... yeah, 512k is the max.
    Doesn't appear to a bios limitation. It is a hardware issue that is limiting the amount.
    Jan 24, 2009 | Toshiba 2405-S221 Notebook
    Toshiba Satellite Pro M15-S405 Memory upgrade problem
    This usually happens when the laptop is not able to take more then a certain amount of memory, as the system BIOS does not support higher. By saying ACPI as the blue screen, that tells me that the power subsystem does not 'like' having more then 512MB of RAM. I am 95% sure this is your BIOS because of that information. Check and see if you can find a BIOS upgrade for your computer model, and that might fix the issue, if an update is available.
    Jan 21, 2009 | Toshiba Satellite Pro M15-S405 Notebook
    512 MB memory boards do not work in my Fujitsu Lifebook S2020
    frquance is not set and it is not recommand that 2 different friquance ram is not working propaties
    Jan 09, 2009 | Fujitsu LifeBook S2020 Notebook
    Hard drive and memory
    the laptop should pick up a 20gb or 60gb ide hard drive with no problem
    Memory Upgrade for Toshiba Satellite 2775XDVD Laptop, the Toshiba Satellite 2775XDVD Laptop takes the PC100 SDRAM SODIMMs Memory Type, and comes installed with 64 MB (non-removable) of Memory. You can upgrade your Toshiba Satellite 2775XDVD Laptop to up to a maximum of 192 MB Memory, the system has 1 socket to install Memory, already with 64 MB (non-removable) standard Memory installed. For best Laptop performance use the maximum amount of allowed Memory per slot for your Laptop.
    Choose the following Memory Upgrade for Toshiba Satellite 2775XDVD Laptop
    Dec 01, 2008 | Toshiba Satellite 2775XDVD Notebook
    Ram upgradation
    The system uses shared video memory, so it will always show less memory than actually installed.
    It's a good machine, but needs all memory it can get for Vista.
    Good luck
    Dec 08, 2007 | Toshiba Satellite A135-S2266 Notebook
    Computers & Internet Logo
    98 people viewed this question
    Top Toshiba Computers & Internet Experts
    Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
