Question about Dayton (4LX41) Heater
Dayton Furnace - Pilot Light Goes Out but Fan keeps running?
I have a Dayton Heater Model 3E233,and the pilot light keeps going out ,but the fan keeps running .any ideas how to correct the problem?
Thank you
Mike
  • Anonymous Mar 13, 2014
    red light keeps flashing and the furnace doesnt heat fan still runs no heat
  • 137 Answers
Pilot lighted furnaces have a thermocouple made from disasimilar metals that when heated create electricity to actuate a relay that alows the gas to flow to the furnace.
When the thermocouple gets coated with carbon from the pilot lights constant burning it acts as an insulator and keeps the thermocouple from getting enough heat to generate electricity, a very good safety factor.
What you have to do is locate the thermocouple it should be located over the pilot light, you will see a gray substance around the thermocouple it will be hard like cement, take a knife and scrape away as much of the gray material as possible then sand the themocouple with a medium sandpaper until it shines, use one of you wifes emery boards, this should solve your problem.
Posted on Feb 24, 2009
Pilot light on my heater keeps going out an I have a hard time lighting it. It's a Royal Jet serial no. Is 55FG385412 Model FG355 help if u can
Get the pilot light sensor replaced as the burn down with use and if they are just out of spec the sensor cools and shuts off the gas flow for safety
Dec 05, 2015 | Dayton Gas Furnace Heater
I have a hanging Dayton in garage pilot lights fine furnace fires up runs 6or7 min. then burner and pilot go out
Does unit fan come on ??? Is flue clear as most units have a safety klixon if exhaust not venting properly.
Nov 24, 2012 | Dayton Gas Furnace Heater
Pilot does not light
Check spark electrode is clean and in the right postion , check flame sencer is clean . check pressure switch hose are not split , jump out pressure switch see if it lights. you could also check over heat try jumping that out see if it lights , pilot may need cleaning if standing pilot.
Feb 25, 2012 | Dayton (4LX44) Gas Heater
Dayton gas furnace model 3e385 works and lights but as soon as fan comes on the unit shuts off and lights again wondering what was wrong
Check heat exchanger for cracks or holes which will cause the fan to blow out the flames. The flame sensor on the pilot or burners has to be in constant contact with flame to operate normally. If the flame is put out by a cracked exchanger the exchanger or furnace needs to be replaced.
Nov 22, 2011 | Dayton Gas Furnace Heater
How to light pilot on Dayton furnace and then start furnace
If this is a standing pilot system, turn the gas valve to pilot position. push in the knob & hold while lighting pilot...keeping holding knob down for a minute... this will pick & hold the gas valve. Let go of the knob & see if the pilot stays lit, if it does, then turn the knob to on position & the furnace should start if there is a call for heat from the thermostat
Sep 15, 2011 | Dayton Gas Furnace Heater
The pilot light will stay lit. Go to turn on heater and stays on briefly and goes out The heater wont stay lit.
If the fan comes on and blows out the pilot light then you need a new furnace because that's the sign of a crack in the heat exchanger. Need a little better description. Do the burners light then the fan come`s on and then it goes out completely?
Nov 24, 2010 | Heating & Cooling
Garage furnace (standing Pilot) pilot stops after 30 mins.
it sounds like the afc the fan control not working could be dust on the afc
Jan 10, 2010 | Dayton Gas Furnace Heater
Pilot light
Hi the thermocouple is a long copper wire that goes back to the gas valve from the pilot .
i would clean the flame senser first , then check the pressure switch jump this out , then check the fan control or snap disc jump this out see if it runs if you need A THERMOCOUPLE then honeywell universal will do
Apr 07, 2009 | Dayton (4LX41) Heater
Why does a pilot light go out,but the fan keeps running?
some heaters use a timer to bring fan on as opposed to some which use temp
Feb 24, 2009 | Dayton (4LX41) Heater
Dayton (4LX41) Heater Logo
824 people viewed this question
Top Dayton Heating & Cooling Experts
Paul Carew
Mack Baxter
Dan Webster
Dan Webster
Are you a Dayton Heating and Cooling Expert? Answer questions, earn points and help others
