Question about Car Audio & Video
Trying to pair my n95 with the vaova bluetooth radio
Re Umax Vaova CR-260BT bluetooth radio, i need to pait my nokia n95 with the radio but have lost the instruction manual can i download it from you??
shanth
  • 108 Answers
SOURCE: Bluetooth pairing
1.Explore blue tooth devices from your motorola phone.
2.it will sure find your blue tooth headset.
3. Make sure your blue tooth headset is on
4.in pairing function select your blue tooth headset
Posted on Dec 22, 2007
SOURCE: Motorola Bluetooth® Headset H555
go to bluetooth on your phone and press''LOOK FOR DEVICE" but turn your bluetooth on
Posted on Feb 18, 2008
trillian_tx
  • 4 Answers
SOURCE: bh 101 bluetooth headset lost manual and forgot pairing code
Try this: 1. Ensure that your phone is switched on. 2. If the headset has not been previously paired with a device, switch on the headset. The headset enters the pairing mode, and the indicator light starts to flash blue quickly. If the headset has been previously paired with another device, switch off the headset, and press and hold the multifunction key until the indicator light starts to flash blue quickly. 3. Activate the Bluetooth feature on the phone, and set it to search for Bluetooth devices. See the user guide of your phone for instructions. 4. Select the headset from the list of found devices. 5. Enter the passcode 0000 to pair and connect the headset to your phone. In some phones, you may need to make the connection separately after pairing. You only need to pair the headset with your phone once. If pairing is successful, the headset appears in the menu of the mobile phone where you can view the currently paired Bluetooth devices. When the headset is connected with your mobile phone and ready for use, the indicator light of the headset slowly flashes blue.
Posted on Apr 14, 2009
  • 5 Answers
SOURCE: pairing
There are 3 codes to try for these units. 0000, 8888 and 1234. This from the manual after taking the thing apart and dinking around checking voltages. Also on some units with a joystick type button beware that the LED lens is a Button !! That threw me fits. Its all working now and, up to 30 ft away to boot. Nice unit.
BTW the small hole on top is a MIC. I stuck it with a pin thinking
it was a reset button : /
The manual is like 1/10th scale and very hard to read, its in Chenglish. I took mine apart, found the second button and pressed that to sync it thinking, hmm how am I going to turn it off once I put the cover back on ?
Put it back together and took a chance and pressed hard on the LED lens and Bingo ! It started its sync up. 0000 did NOT work, 8888 did for me on my Palm Treo 755P phone with Ptunes. Shows up as an R36.
Very good sounding unit. Just took me a while to fingure out.
God Bless Ya'All
G'luck with yours.
Posted on May 03, 2009
  • 5 Answers
SOURCE: Need to re-pair bluetooth to phone
Go to ur phones bluetooth settings - activate pair new device - at the same time press and hold the on button on your blue tooth head set for about 10-15 seconds - this will enter the device into pair mode - on your phone - click on pair with new device etc etc, the default access code is either 0000 or 1234
Posted on Jun 29, 2009
Got vaova freeview recorder, has frozen on one station, how can I un freeze it, thank you
I'm going to assume that power cycling does not fix anything for you, so I suggest you reboot and change the settings under Preferences Menu > Start-up Mode to Standby (then reboot the device again). This fixes it in most cases.
Apr 21, 2010 | Televison & Video
VAOVA twintuner DTR 250 GB not receiving anything since 1st October, not showing time in LED display segment, but is showing red & green lights (remote control receptors?)
Just fixed mine - replaced TIP31C (Q1 with heatsink) on power supply board. Also changed 100uF (E3) & 470uF (E4) capacitors, although probably not necessary.
Oct 08, 2009 | Televison & Video
Can't pair up Nokia N95 with Bluetooth BH-102
Your code is most likely 0000, with a small chance that its 1234.
Jun 30, 2009 | Nokia N95 Cellular Phone
I can not pair a particular bluetooth device to my n95 8 Gb phone, but i was able to pair nokia's model. is there any reason why other type bluetooth devices won work with n95 nokia 8 GB cell phone? How...
jus change th settings of ur bluetooth on ur device an on th other device an try to pair it.. so tat u may recover tis prob... kindly rate me.... thank you...
Pairing with Nokia N95
hi,
I posted the manual to this headset here
http://www.fixya.com/support/t526500-cannot_pair_aoem_bluetooth_headset_lg
Jan 29, 2009 | OEM Systems Bluetooth Headsets - Model...
I cannot pair my Nokia N95 with HBH-608 Akono headset
1)Turn on the blue tooth headset
2)Turn on bluetooth on your phone and search for devices.
3)When it finds the device select it and click connect.
Thats all.
Jul 14, 2008 | Sony Ericsson HBH-610a (Auto Pairing)...
Nokia N95 Bluetooth
I have just spoken with 3 as I had the same problem with my Nokia N95.
The solution is:
Menu
select Tools
select Bluetooth
at top option blue tooth on - select right hand navigation button
it will say (no paired devices) select Options and select new paired device this will then seach for other blue tooth devices.
Good luck everyone
Jun 09, 2008 | Nokia N95 Cellular Phone
Bluetooth problems
it's paired already, so try to use u'r n95 accessing other bluetooth fones ,or kit, if it works , u'r car kit is faulty..
Apr 20, 2008 | Nokia N95 Cellular Phone
N95 blue tooth pairing
remote sim (off)
That should be ON
Dec 14, 2007 | Nokia N95 Cellular Phone
To connect N95 with bleutooth headset LG HBM-550
1st switch on bluetooth for both devices!
2nd go to your bluetooth menu in your phone
3rd click on pair devices
make sure that your phone is visible to other bluetooth device
4th select the device and click on pair devices!
its done!
Dec 08, 2007 | Nokia N95 Cellular Phone
Car Audio & Video Logo
79 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
