Cannot access my external E drive
When I try getting into my Local Disk (E:) I get
WDWD Pas.spo 12/24/2048 12:00am
THUMBS. D 360,498kb 10/20/2008 12:00am
When I click on WDWD Pas.spo I receive the following error message:
E:\WDWD Pas.spo refers to a location that is unavailable. It could be a hard drive on this computer, or on a network. Check to make sure that the disk is properly inserted, or that you are connected to the internet or your network, and then try again. If it still cannot be located, the information might have been moved to a different location.
This drive worked fine till 9:30pm on Sunday evening. When I went to use it on MOnday morning I was unable to call the drive up.
Is it possible to recover the data on the drive?
Thank You
  • 365 Answers
Have you tried anything which is used to lock the folders,i mean FOLDER LOCK software
Posted on Mar 11, 2009
Usb removable disk is suddenly showing as local disk
Check that the safety switch is not on the USB. Some of them have a simple on off switch that gets turned off. I have made that mistake myself even knowing they are there. If there is not one of these switches I would try the device in another computer and see if it comes up the same way again.
Feb 04, 2014 | Transcend 640GB Transcend StoreJet 25D3...
Disc not accessible ,error performing in page operation
Go to Control Panel-> Administrative Tools-> Computer Management-> Storage-> Disk Management. See how many drives are visible. You should see your regular C Drive listed as "Disk 0" and your external hard drive as "Disk 1" (if Windows recognizes it.)
If it's Online, then right-click on Disk 1, and click on "Properties". Then click on the "Tools" tab, then click on the "Check" button.
If Disk 1 is listed as Offline, then right-click on the box that reads "Disk 1", then click "Online". Then, try to do a disk check as I noted above. Post back how it works out .
Jan 04, 2014 | Seagate Computers & Internet
I was moving a zip file from a stick to the WD External Hard Drive, and an error message came up. Now, only this is visable: "Name WDWD Com.bo Date modified 11/26/2031 11:00 PM Type BO File Size...
Give Recuva a try its good at recovering lost files http://www.piriform.com/recuva
But I'm sensing you may have a damaged drive. If so and you need data recovery help this guy does it remotely and works for donations. http://FreeDataRecovery.us
Jul 20, 2011 | Western Digital (WDXB1200BBRNN) 120 GB...
Hello, I have allmost full wd passport 160Gb disc, computer don't recognise disk *** passport (it's writen "local disk" in folders section in explorer) say it's not accessible and...
Hi there and welcome to Fixya!
This error indicates that the processor is not able to communicate with your External Hard Disk.
I'm pretty sure you've already tried connecting the External Hard Disk to a different computer. If not, this is the best time to do it to isolate the issue. If you're having the same issue with other computers, then the problem lies with the External Hard Disk. There's a possibility that it's damaged, corrupted or infected by a virus. If it's still under warranty, get assistance with the manufacturer. If it's not, try checking the cable for any physical damaged, or better yet try a known good working cable.
Also, try restarting the computer when the External Hard Disk is connected to see if the computer can check its volume during the reboot. If the External Hard Disk failed to load after restarting, it is a possible virus issue. I would suggest running the most up-to-date antivirus software that you can find to scan your system and the external hard disk itself.
Jun 29, 2011 | Western Digital Passport 160GB External...
Hitachi SimpleDrive Mini-red wine USB 2.0 Portable Drive - 250GB SDM/250RW This external drive is not recognized by my pc- i'm running windows XP but have tried it on a Vista too, and also beeps once...
If you have tried it on two PCs with the same result, the hard drive is most likely defective. If so, the computer may recognize it being plugged in with a beep but will not recognize it at all as an accessible device.
One thing you can check is if the hard drive was never initialized, meaning that there is empty space but the empty space isn't configured for the operating system to recognize and use. To do this:
- Go to "Start" and "Run" and type in "diskmgmt.msc" and hit "Enter".
- A list will pop-up listing all hard drives on computer. Each row is a physical hard drive.
- The main hard drive for your computer should be listed as "Disk 0" and the local disk in it should be "C:".
- Assuming you have no other hard drive besides the external, the next row should be "Disk 1" and say "Unallocated", which means the hard drive was never initialized. In this case, right-click on it and select "Format". Click next through everything and the external HDD will be formatted so that Windows can recognize it.
- MAKE SURE NOT TO FORMAT LOCAL DISK C:!
- After that, the external HDD should be recognized fine and pull up in "My Computer".
Otherwise, if no other hard drive is listed, the external HDD is most likely defective and you will need to purchase a new one.
Feb 28, 2011 | Hitachi SDM/250RW 250 GB USB 2.0 Hard...
Cannot access / view hard drive from my PC.
Try connecting it to a different USB port on your computer.
Try connecting it to a USB port on a different computer.
If the problem continues, then one of the two major components inside the enclosure:
* disk-drive
* USB-to-disk-drive adapter
have failed.
Open the enclosure, and remove the disk-drive, and connect it as a "slave" disk-drive in a desktop computer, to see if the disk-drive, by itself, still is accessible. If not, then you could buy a new disk-drive, and "transplant" it into the enclosure, to "resurrect" your external enclosure.
Is the disk-drive still under warranty? If so, contact Seagate, and exercise the warranty, to get a replacement.
Oct 12, 2010 | Seagate 160GB 3.5" External USB Drive 160...
Can't get my lap top to open the bl--dy thing Lap top see's it but won't open it up can any one help before i put a hammer to it i've had it for about 2yrs now but haven't been able to access it now for at...
Try to connect the external disk-drive to a different computer.
If you still cannot access any files, then either:
* the USB-to-disk-drive adapter inside the case is malfunctioning,
* the disk-drive inside the case is malfunctioning.
Read the serial-number of the external disk-drive from the case, and access the manufacturer's web-site, and check to see if the "warranty" for the device is still available. If so, the manufacturer will replace the device -- you might have to pay "shipping" to send your device to them.
If the warranty has expired, open the case, remove the disk-drive, and connect it as a "slave" disk-drive in some desktop computer, to see if the USB-to-disk-drive device was the problem.
While the case is open, you could purchase a new disk-drive to fit into the case, and then close the case, and once again have a working "external" disk-drive.
Aug 16, 2010 | LaCie (300770) 250 GB Hard Drive
My pc now recognizes the drive as a local drive, but the drive cannot be read. Is it possible to restore the drive without deleting the files on it? They are some extremely important.
There are several things to try:
1) Disconnect all USB devices and restart the computer. Then plug in your external Hard Drive. In some cases, this has worked to enable external devices as there's a conflict between some USB devices. Once working, you can add any other USB devices you have.
2) Since the drive is recognized by XP, right click on it and if you have access to Tools, try to check the volume for errors. It may ask you to reboot and do a scan disk on startup. Sometimes although the computer recognizes the volume, it hasn't sufficient information as to how to access it. Running a scan disk can cure that problem.
3)Re-assign the drive letter; Occasionally XP can't access a path to the external drive; if it assigns a letter, in turn it will gain access
Change Drive Letter
The link above provides step by step instructions to change the drive letter
4) Run Windows Update and install SP3; Service Pack 3 addresses issues with external devices that weren't fixed in either SP1 or SP2
I do hope one of these answers provides a solution to your problem. Please post back with any other questions or just to let me know how you made out. Unfortunately, you have a common problem but no one FIX has been identified by Windows to solve it.
Best of luck!
Greg
Nov 06, 2009 | Western Digital My Book Essential Edition...
Flash disk 2G type kingston
are u gujju
just format and get it done
Jul 25, 2008 | Computers & Internet
Misreading as local disk
can you give more details
such as, what drive letter does it assign it, what error do you get when you try to read it, does it say 120GB when you look at it on "My Computer" and so on.
Jan 15, 2008 | Western Digital Passport WDXML800UE...
Computers & Internet Logo
88 people viewed this question
David Payne
David Payne
