Scanners
Problem for Scanners
Generic problem for all Scanners
Driver for Hp Scanjet4200c, for windows Vis...
By harald_hassl on Feb 24, 2009
Driver for Hp Scanjet4200c, for windows Vistasystem
Same Problem
May 18, 2009
-   HP apparently will not provide an updated 4200c driver for Vista/Win7, suggesting that the scanner is too old. Mine works fine under XP (which HP initially refused to support), but it seems silly that it should not work equally well with an appropriate driver in Vista. HP wants us to buy a new scanner, which I probably will to run Win7, but the new scanner will not be an HP. -   msl146
May 11, 2009
-   What a **** of solution is to found the seller web. There are no vista drivers there, but first thing I do when I have no driver is found on the seller web, after, I ask for it -   Guest
Apr 22, 2009
-   I haven't find any drivers to match HP Scanjet 4200c with Vista. And it appears that nobody else has. I've looked in so many pages, chatrooms and foros that I'm already tired and willing to buy a newer device. Wish you get lucky!-   attisheloisa
Apr 08, 2009
-   The Said Vista - This is only up to and including XP and it doesn't work at all it locks the scanner up at the end of scan and is still trying to strip the cog on the motor which continues to run. geeeeesh! -   dsbusby
Mar 11, 2009
-   I have an HP 4100c and OS Vista and computer keeps telling me that no scanner is installed on the computer. I downloaded Vuescan and it still tells me that there is no scanner installed, even though its plugged in. I wish someone would figure out a fix for this issue. Perfectly good scanner, won't work! Also, FYI, the above post gives a website to go to for drivers, but the request clearly states for VISTA and the link is for every OS BUT Vista! -   Guest
Solution #1
posted on Feb 24, 2009
Somewhat Helpful)
APremkumar
Rank: Guru
Rating: 86%, 421 votes
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=15211〈=en&cc=us&prodTypeId=15179&prodSeriesId=25270&taskId=135
Here is what you need!!! Click on the Above Link. Download Software!!!
Hope This Helps!!!  Please Don't Forget to Rate my Response!!! Thanks!!!
PREM
Was this helpful?
Yes
No
Popular Solutions for Scanners
Questions and Unsolved Problems for Scanners
Answer
I need a hendheld pen scan suitable for XP and editable on word, to save especially half of the... (More)
Answer
canon dr 2580c gives a small white stripe of 2 mm on a colour scan. Please give me an answer... (More)
Answer
Just installed this scanner and I have tried intelliscan and quickscan. No scan of the slid is... (More)
Answer
this problems about the image nothing 1/4 section in page, please sent the answer to my email:... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Scanners:
Top Scanner Experts
Rank: Guru Guru
Solutions: 744
Experience: 30 Years of professional repair and design.
Ask Me
Find more Scanner Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(972) 907-9771
Printronix, IBM, Tally, Genicom, TallyGenicom,...
Sinca Printers, Parts & Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
