Question about Dell Multifunction Laser Printer
LIne on scanned documents
When I scan documents they have a line on them from when someone ink on the scanner. How can I clean this?
  • 39 Answers
Hi Pascuatm,
First of all, dont break out any harsh cleaners, like bleach, or acetone.
I would suggest using a mild soap, like dawn. Don't get the glass on the scanner overly wet, and try not to press to hard.
Also, use a cloth, something soft, nothing that could scratch the glass.
Once you've gotten all the ink off the scanner, wipe the soap off with some paper towel.
Best of luck,
LazarusElite
Posted on Feb 24, 2009
I get a black line when scanning, ( not when printing)how do i fix it
This is commonly caused by a mark on the scanner plate. If you place your document to scan on the scanner plate (Lift the lid and place it on the glass plate) and scan or copy the document does it come out clean? If you feed the document through the Auto Document Feeder doe the line appear?
If when place on the plate it is clean but fed through the ADF there is a line, then when you lift the lid on the scanner you will see a narrow glass plate at the end (Normally the left end) of the scanner plate. Give this glass a clean and your mark will go away.
If the scan or copy is lined when using the Flatbed scanner and the ADF then the problem will be in the scanner lamp which will be probably uneconomical to fix.
Oct 09, 2014 | Brother MFC 6490CW InkJet Printer
Vertical Black Line
Probably there is nothing wrong with that scanner, just open and clean document feder with alcohol or glass cleaner.
Mar 29, 2013 | Canon PIXMA MX870 Wireless Office...
Everytime I fax something on my HP Officejet 5610 all in one, the recipient receives the document with a line going down the left side of the page. How do I get rid of the line?
Lines on scanned and copied documents is usually caused by something on the scanner glass such as ink, correction fluid or trash. Open the top of the printer and clean the scanner glass surfaces with windex and paper towels. See this article for more details:
http://www.ccl-la.com/blog/index.php/lines-on-scanned-or-copies-pages/
Jun 26, 2012 | HP LaserJet 3050 All-In-One Printer
Black line in paper
On what operation are you receiving the black line in your paper?
This problem usually appears when you try to scan or copy using your ADF (automatic document feeder).
To remove this black line in your paper, clean the ADF platen glass in your printer and do as well in the flatbed scanner glass. This ADF platen glass can be found right below where the documents in the ADF goes through. Its a glass about 1 inch in with and beside the flatbed scanner glass (the one where your documents is lay down for copying and scanning. Dried ink or paper residue sticked in the glass can cause this line in the paper. Clean it with a a clothe and spray some windex on it.
Feb 10, 2011 | Panasonic KX-FLB801 All-In-One Laser...
My scanner is now adding a page with a black line that runs from top to bottom of the page and the actual document scanned is page 2. But the document is fine with no line through it. Does this mean that...
Check your scanner software settings. It is probably set at duplex ever time you start to scan. That is why you get two pages for every pass, the front and the back. You must place the document in the feeder in a way that the front side of the document is page 2. You may want to flip it next time you scan. So the main question is why there is black line from top to bottom? That is because there is a piece of dirt stuck on the glass of the scanner. You see, this scanner actually does two scanning when a page runs through it: the front and the back in duplex mode. So there are two scanners in side the box. The front page scanner apparently is dirty and needs to be cleaned with clean cloth and lens cleaner.
Aug 31, 2010 | Canon DR 3060 Path-Through Scanner
Black line in the middle of the output - scaned document
A black line down a scanned page indicates a dirty scan glass. Lift the top of you scanner like you would putting a page or book down to scan. On the end of the scanner that has the document feeder you should see a thin piece of glass the is separate from the larger glass pane. This is the document feeder glass. Now check it over for a very small mark of ink or dirt. You can use regular glass cleaner to wipe this glass just spray it on a piece of cloth not the scanner then wipe. You may have to wipe and then try scanning several times if the ink or marker is died on. while you are cleaning you should also clean the main glass pane, it will make the scans clearer and crisper.
I hope this helps, if so please rate our solution.
buddy
Corporate Computer
www.ccl-la.com
tech@ccl-la.com
Nov 05, 2009 | Xerox DOCUMATE 510 Flatbed Scanner
Kodak I260 large black line.
It may be inside see this website for how to fix an Hp which is similar http://www.willshak.com/scanner/
Apr 20, 2009 | Kodak I260 Captiva IA-Express Path-Through...
Black line scanning on digital sender
Yes. There will be an access cover / lid where the document goes in.
Open the cover, and you will see a thin glass, called the 'scan glass'.
Look in the middle of the glass. You will most likely find a glob of white-out, or ink on it.
Use rubbing alcohol to clean off the culprit.
Welcome to scanner / fax / copier troubleshooting 101!
Jun 18, 2008 | HP 9200c Flatbed Scanner
Line on Scanned Documents
There is a spot on the thin strip of glass that sits next to the large scanner glass. Because you are moving the paper when using the feeder, a spot appears as a line. Shining a flashlight on the glass can help you locate it. You can scrape it off with a finger nail or clean it with a damp cloth.
May 09, 2008 | Office Equipment & Supplies
Horizontal line appears in scanned document
open the scanner and remove the clips, move the lense up and clean it. it is very easy to clean.
Feb 13, 2007 | Visioneer Strobe XP 200 Path-Through...
Dell Multifunction Laser Printer Logo
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
