Question about Sony VAIO M1 (VGCM1) PC Desktop
Cant read cd's or dvd's
The drive powers up and takes the disks in but nothing is readable
  • Sony Master
  • 13,433 Answers
Hey,
try a lens cleaner on the drive. dvd / cd lens cleaner.
you can also try blowing some canned air into the drive bay if theres dust.
most likely if this doesn't help you have a faulty drive or a failing drive. Suggest warranty repair or replacement.
Let me know if you need anythingelse.
Thanks,
Ekse
Posted on Feb 24, 2009
It's not reading cd, or DVD
Check for scratches on the disk surface - these can inhibit the player from reading a disk correctly.
Some players will read olny certain type(s) of disks. This is an issue mostly for disks created on a computer, not those that are prerecorded and available for purchase or rental that contain movies and music.
As stated above, dIsks created on a home computer may not always be readable on a home player. Re-writeable and recordable types that are not listed as being compatible will not work. Check your manual to see which types are acceptable and not. DVD types are: DVD-R, DVD-RW, DVD+R, DVD+RW and DVD-RAM CD Types are CD-R, CD+R and CR-RW. Older home CD and DVD players generally work with "-R" types and the newer players with both "-R" & "+R" types. "-RW" and "-RAM" types are the least likely to be readable in home players.
Additionally, most players require that disks created on a home computer be "finalized". This is an extra step that isn't required by most CD / DVD drives in computers. Just because it works in your computer doesn't mean it will work in your home player. If you're using compatible media and still not able to read disks, check your CD / DVD recording software options to enable finalization.
Jan 03, 2013 | Televison & Video
Dvd+rw nd-2100ad no disk in drive error
Can you see DVD-RW drives indicator busy when you insert that disk for a long time? if so, your drive may not going to read that disk. If it is in case of CD disk, sometimes DVD-RW just can't read it while very old CD-ROM can read! If this happens in case of other CD/DVD witch is readable by other DVD-RW, You may just try to clean the lens of your drive.
Jun 29, 2012 | HP Pavilion a620n (PC028A) PC Desktop
Machine doesn't read read games or movies kepts telling us to open disc. or disc is not readable
This can be caused by dirt on the laser lens, or a posible malfunction of it. CD/DVD lenses tend to loose power over time, when that happens, they cant read the discs anymore and you have to get them replaced.
But before you go that way, try cleaning the DVD drive with a disc cleaner, if problem persists, try to purchase a new, and compatible, dvd drive and change it yourself if you can, or take it to repair.
Mar 20, 2011 | Microsoft Xbox Console
I have a Zip 250 disk that will not read. When I insert the disk in the external disk drive, it will spin and stop a few times and that's it. When I try to access the disk/drive letter via "My Computer",...
If the disk is unreadable this means that the format or the files extensions on it are not readable in the operation system you use..either are damaged or the disk itself is damaged or it wasn't finalized like it should ...If other disks inserted run ok than the disk it is damaged and it is nothing wrong with the drive itself..When it says to insert a disk this means that it is not seeing the disk at all and it sounds like a drive problem ..but if other disks are ok ..than it is just a damaged disk or in a format unreadable ..beware if it a cd unit ..will not read dvd-es..or if it a dvd kind will not read large dvd-es (dual layer) or blue-ray disks..
May 29, 2010 | Iomega ZIP 250 External ZIP Drive
''A disk error has occured'' upon start up
You cannot. (Remove any media from the diskette-drive and from the CD drive, and try again to reboot.)
The message is indicating that the disk-drive containing Windows is *NOT* readable. So, nothing can be read from the disk-drive.
Take the computer, and the original "IBM System Recovery" set of CD-ROMs, to a computer-store, and get them to remove the "dead" disk-drive, and install a new one, and to re-install Windows from the IBM CDs.
Maybe, while Windows itself cannot be read from the "old" disk-drive, the computer-store *MAY* be able to recover your "data" files.
Nov 06, 2009 | Office Equipment & Supplies
My LG dvd drive not reads any disk in my system
please try change your drive, the lence is bad the only solution is to change your dvd drive. thanks
Jul 18, 2009 | Sapphire Technology PURE Innovation...
Combo drive not reading DVD
my combo drive also not reading dvd :(
Dec 23, 2007 | LG GCC4522B CD-RW/DVD-ROM Combo Drive
Not reading dvd r or rw as writable disk
It sounds like you are having issues with all DVD writable disks. From the specs I was able to find online about your DVD writer, DVD+RW discs may not be compatible with the the drive. Make sure you are using DVD-RW (note the minus instead of +). I think you might need to reinstall your DVD drivers. This should solve the issue.
Jul 27, 2007 | Pioneer DVR A03 DVD-RW Burner
Cd dvd wont play
Many of the older DVD and CD players will not play disks recorded on a computer. This has to do mainly with the laser optical response.
There were several manufactures that manufactured their laser unit with a built in filter that would not allow their player to read non pressed CD disks (disks burned with a home computer).
When buring DVD's or CD's, use the slowest possible speed for the burn to have the highest readablity and least data errors possible for the medium.
Jerry G.
Mar 09, 2007 | JVC KD-AVX1 Car DVD Player
Unable to read some of the DVDs......
It's possible that the drive has died. CD and DVD drives are notorious for short lives but then I've seen some last 5 years. The lens could be dirty, just a small piece of lint is enough to cause hassles. Try using a Lens cleaner, available from all good audio shops. Some machines don't like +R disks and a firmware upgrade is needed. I've done many Liteon Drives with terrific results but if the manufacturer hasn't put one out then you're lost. It's possible you've used the wrong upgrade to fix your problem. With the prices of drives today it's sometimes cheaper to replace it. Believe me they can die quickly, my record is a week from brand new to unuseable and that was a Sony. BMW
Jun 03, 2006 | Samsung SD 616E (729507925578) Internal...
Sony VAIO M1 (VGCM1) PC Desktop Logo
61 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
