Question about iRiver H10 MP3 Player
Restore the system files, connect H10 to recovery tool
  • iRiver Master
  • 19,396 Answers
The procedure depends on what version you have.
Below there is the procedure for 20 GB , on other models procedure is the same, but you must find the right download for your model.
For 20 GB :
TO RESTORE "SYSTEM FILES MISSING" LOCKED PLAYER
--- This applies ONLY to the 20 gig version of the H10! ---
--- This procedure formats your H10 so all data will be erased on the player! ---
1. Power off H10 - 20gig unit.
2. Insert staple or other small object into reset hole to press reset button.
3. Connect player to USB cable.
3. Hold down Select key (labeled "O" - right button on front of player) while also holding down power key until player boots.
4. Unit must display "Emergency Connection."
5. Unit will now appear as a drive under My Computer. Right click on drive, select Format. No need to change anything, just proceed.
6. Download H10_20GB_System.exe. It is a self-extracting archive. Double click on it and unzip to c:\iriver.
http://www.iriveramerica.com/downloa...0GB_System.exe
7. Locate iriver directory, double click. You will see H10. Double click once again; you will see System.
8. Right click on system, select "Send to" and choose the directory of the player.
from System Files Missing
If you have the 5 or 6 GB see iriver - H10 5/6 GB Series Support
Posted on Feb 24, 2009
System files missing
oooh thats a tough one. lets see, if it will still connect to the computer, the iriver tools that are used to update firmware should work. try to put it into restore mode by holding the right front button immediately after reset (use a pin or toothpick to hit the button on top) and plug it into your pc. hopefully those files are still intact. doing a refresh of the firmware should work. if not i believe there are repair tools for the h10 on irivers support page. http://www.iriverinc.com/lounge/loungeView.asp?selectPart=02&findWord=&sno=685&page=1&cateCode=02 this is a link to the page that has recovery tools and firmware update tools. Hope this helps!
Apr 13, 2010 | iRiver H10 MP3 Player
It says files missing need h10 recovery tool
When the H10 comes up with the information "files missing", system files are missing on the player for proper functionality.
The recovery tool must be run to restore the player's functions.
When not having the tool available on disk it can be downloaded from
the iRiver site, starting here:
http://www.iriver.com/flash/index.asp?code=0302
In the second column next to GO, enter the word recovery in the bar.
Click on the upgrader, to see how to perform the recovery for the MTP version of this type of player.
MTP version indicates that the firmware on the player is suited for transferring media using Windows Media Player 10 or 11.
The version depends also on the region, the player has been sold. More info for checking the MTP or MSC version, see:
http://www.iriver.com/flash/popup/flash_pop.asp?board=faq&code=365
Need more help ? Just post a comment.
Dec 16, 2009 | iRiver H10 MP3 Player
System files are missing.....
hi Mr/Mrs.
my h10 mp3 sned the message" file system missing" .please tell me how can solve it.thank for your answer.
Jun 16, 2009 | iRiver H10 MP3 Player
I need to restore the system files for my H10 Iriver MP3 player
go to www.iriver.com people - what the f--- do you think it means?
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
May 04, 2008 | iRiver H10 MP3 Player
6 gb version of H10 displaying error message on start up
you need to upgrade firmware to version 2.51 using the mtp upgrader download found at www.iriver.com-support-ask.asp after doing this your player should work this upgrade is a recovery tool and works very well with all mtp version players
Dec 30, 2007 | iRiver H10 MP3 Player
Iriver (h10)
either find rockbox or iriver plus and do a firmware upgrade
Nov 12, 2007 | iRiver H10 MP3 Player
Iriver h10
Get recovery tool from iRiver website
Sep 06, 2007 | iRiver H10 MP3 Player
What do i do?
Does the device appear in "My Computer"? Download the H10 firmware from iRiver's website and install it.
Jun 13, 2007 | iRiver H10 MP3 Player
iRiver H10 MP3 Player Logo
650 people viewed this question
Top iRiver Audio Players & Recorders Experts
aliasger yq
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
