Question about Indesit 18 in. D41 Slim-Line Free-standing Dishwasher
I have a indesit idl 40 dishwasher but heater not working changed heater + thermostat still not working
  • 75 Answers
If you have changed the heater then you will find that either the connection from the heater to the control module behind the control panel is poor and may have damaged connections soldered to the module
Posted on Aug 02, 2009
5 Suggested Answers
SOURCE: Indesit idl 535 dishwasher not heating up,I have
Hi,did you find out what was wrong with your dishwasher,as i have the same problem.steve
Posted on Mar 14, 2010
SOURCE: Indesit IDL 530 Dishwasher
Switch off, turn off power, turn off water, disconnect water inlet hose, check for blockages, remove filters, clean filters, refit filters, check water supply, reconnect water supply, reconnect power, turn on - problem solved.
Posted on Apr 13, 2008
localwonder
  • 6784 Answers
SOURCE: My indesit dishwasher won't heat the water. I
HI. this is actually a control issue. your element is ok. replace the control board or timer module asap.
Posted on Aug 27, 2009
heatman101
  • 43501 Answers
SOURCE: Indesit IDL 40 slimline dishwasher does not drain
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems -
Water will not drain out
heatman101
Posted on Jan 06, 2011
How do i change thermostat on a indesit model idl55 dishwasher?
First step: Find the thermostat. You will find documentation online that should tell you where to look.
Second Step: Using documentation and perhaps the failing thermostat, order a replacement. There are numerous suppliers online.
Third Step: When the replacement arrives, install it where the old thermostat was mounted, connecting electrical lines as required. Note: Disconnect Power before installing replacement!
Fourth Step: Verify the new unit corrected the original problem.
Good Luck,
Pete
Sep 22, 2014 | Indesit Dishwashers
Our dishwasher idl 40 indesit has 1 and 3 flashing lights on the panel seems to be a problem
I have had this problem also and no longer take anything apart take out the filter plate pour boiling water into the well leave for 20 mins put on a 25 min fast wash and hey presto works every time. Mine seems to block up about every 4 weeks and the lights come on but this solution always works
Mar 06, 2012 | Indesit 18 in. D41 Slim-Line Free-standing...
Indesit IDL 40 slimline dishwasher does not drain completely
heatman101
Jan 05, 2011 | Indesit 18 in. D41 Slim-Line Free-standing...
Water is not heating up
It could be heater element fault. Thermostat fault. Lastly check circuit, not switching the heater function.
Sep 30, 2010 | Indesit 24 in. D63 Free-standing...
Indesit idl 40 2&3 lights flash
The problem is lack of water. Check that the water is turned on at the stop **** and make sure that the hose hasn't been traped if the dishwasher has been pulled out from it resess as happened to mine.
Jan 21, 2009 | Indesit 18 in. D41 Slim-Line Free-standing...
IDL 700
A10 2 & 4 Heating element Open circuit heater
info from idl service manuall
Feb 29, 2008 | Indesit 24 in. IDL700 Built-In Dishwasher
Indesit IDL 40 Slimline flashing lights
the problem you have got with the flashing lights is that its the rinse aid or in need of more salt, hope thats sorts it for you
Dec 12, 2007 | Indesit 18 in. D41 Slim-Line Free-standing...
Indesit IDL40 Slimline Dishwasher - Won't start cycle
indesit idl 40 not pumping water out properly, ends with flashing light no 4 and plates dry but water still in machine -have to pump out using start stop button but within 2 hours base filled up with water. Can't afford massive call out prices as lady on my own.....
Nov 12, 2007 | Indesit 18 in. D41 Slim-Line Free-standing...
Indesit 18 in. D41 Slim-Line Free-standing Dishwasher Logo
236 people viewed this question
Top Indesit Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Eric Taylor
Are you an Indesit Dishwasher Expert? Answer questions, earn points and help others
