Car SUBARU 2005 Outback. Kenwood CD player has been isolated as cause of 0.25 amp battery drain with ignition off, causing flat battery after 3 or 4 days without driving. HELP!
SOURCE: Kenwood car radio/cd player Model No KDC-3027
Do you like need the colors codes for the harness like speakers and and all?
SOURCE: Wiring for a kenwood kdc 1020 cd player
if you have the wire connector it's easy.....give the negative conection to the body of the player..find the wire from the battery with has the power supply even when the switch is off..and connect it to the yellow wire.that is for the memory...find the wire which has the power when the switch is on ,and connect it to the red wire from the player....what i mean by switch is the ignition switch... u can easily find the speaker connections...most speaker wires comes as blue,ash,green,white...there are two wires from each colour......
SOURCE: need the un-lock code for a kenwood kdc-422 car cd player
KENWOOD SECURITY CODE CLEAR procedure
Your radio will require one of the following procedures.
Type 1
During
the code request mode, while holding the DISP key depressed, press and
hold the Volume UP or DOWN key for 3 seconds (so that “…” disappears).
Then using your remote enter your code.
Type 2
Press the "Auto" button and "Track up" on face of radio at the same time. The four dash lines ( . . . . ) should "disappear".
Type 3
Model# DPX-4020 and DPX-4030
Press
and hold the 1 then the 6 preset key (preset keys are the buttons on
face of radio for storing you "favorite" radio stations). "C" should
display.
Then using your remote, enter your code.
Enter your number from the remote control unit. Your code number is 5227 (KCAR)
* Press numeric key “5” ( 2 times ) and press the Track UP/Next Track key
* Press numeric key “2” ( 3 times ) and press the Track UP/Next Track key
* Press numeric key “2” ( 1 time ) and press the Track UP/Next Track key
* Press numeric key “7” ( 2 times ) and press the Track UP/Next Track key
The security is canceled and the set enters the TUNER mode!
SOURCE: RESET CODE FOR KENWOOD CAR CD PLAYER MODLE KDC-MP4033
Unfortunately KENWOOD codes are not available for free from anywhere on the Internet.
Main Dealer or a Decoding Service ( Try Google or Ebay )
SOURCE: Kenwood KDC-319 CD Player Code dont have a
dont put a code all those radio say that when first power up just push the source button to do what you want
