Question about Daewoo DLT22W4T 22 in. LCD TV
DLT-32c3...... Mains light on but nothing else happens from remote or side controls... whats up?
  • 55 Answers
Common problem on power supply board, dried capacitors need replacing
Posted on Oct 06, 2009
Hi can anyone give me a 4 digit remote control code for a Daewoo DLT-32G1 flatscreen TV please? Cheers Ben
Go to the web site of the manufacturer of your universal remote for the code, if any.
Feb 29, 2016 | Televison & Video
Why doesn't the remote control the fan and lights?
It is possible that the receiver inside the fixture has failed.
Jun 04, 2015 | Hunter 52" Ceiling Fan With Light And...
Pioneer vsx-32 won't turn on with remote
Hi, since both remotes suddenly fail, I am assuming the problem is more than likely with the received rather than the remotes.
If you do wish to check your remotes, then point your mobile phone camera at the remote's Infrared lens and press one the remote's buttons. Your mobile phone camera is able to detect Infrared light and in case you remotes are working properly, you should see light coming out of your remote's Infrared lens.
Make sure that no direct sun light is on your receiver because that can effectively block out the signals from your remote controls.
Try the following method to reset your receiver. Unplug your receiver mains cable from the mains wall socket; power your receiver on by pushing the on/off button (nothing will happen obviously) and leave it like that for say 30 minutes. By that time all capacitors in your receiver will have discharged. Plug your received mains cable in the mains wall socket.Push the receiver's on/off button and see if it know responds to your remote controls.
If the problem still persists, you may have a failed Infrared receiver LED. That component can be found inside your receiver. It will take some basic elelectronics skills to get this component replaced. A service manual can help you. You can download it for free from this website: http://elektrotanya.com/pioneer_vsx-32_33.pdf/download.html
Good luck.
Jan 20, 2013 | Pioneer Elite VSX-32
I have a Hampton Bay Miramar 60 in ceiling fan, when you try to turn it on the upper light just blinks and nothing else happens. You can't even turn the blinking light off. HELP!!!
Turn off the breaker that controls power to the fan. Remove the batteries from the remote and press the buttons in case one is stuck. Reinstall batteries or new ones. Turn on the fan breaker and try using the remote again
Dec 16, 2012 | Universal Remote Control Hampton Bay...
My 50 inch Philips Plasma TV is normally connected to a Virgin Media HD Box in order to watch TV programmes. Tonight my TV is showing a box that is called Information, and it has the wording No signal or...
Unplug both the set and box from power for a while--either may have caused a glitch---power both back with everything already connected and see if the reboot that will happen helps or not--a lot of times the box causes this by confusing the set it is connected to.
Nov 06, 2012 | Philips Televison & Video
I HAVE A 50 INCH PLASMA TV THAT WAS GIVEN TO ME WITH NO POWER PLUG OR REMOTE . I WENT AND BOUGHT A POWER PLUG ,PLUG IT IN AND NOTHING HAPPENED . DO I NEED THE REMOTE TO OPERATE THE TV ON AND OFF/
Hi
If the set doesn't power ON, what is the use with a remote control? If it power ON properly, the power indicator light at its front panel will light up. Look for this. If it doesn't, make sure that you have got a set which has to be repaired. If it does power up, just get a remote control to operate it. OK.
Jul 11, 2011 | Hitachi P50H401 50 in. Plasma HDTV
I can't contol the volume on my t.v. with the dish remote. I am also unable to turn the t.v. off with the dish remote. Everytime I press the volume buttons, the mute button or the t.v. button to turn the...
Usually a remte can use the VCR or DVD set up to drive something else. Try switching the remote to VCR and emulate the codes as what the dish codes arw/ Pretty sure but just try promming one remote for every thpmg. My monet=y would be on the sat remote/
ash
Sep 26, 2010 | DISH Network IR Remote Control
SAT button not working on remote--volume controls work to the TV--screen is displaying Press Select to Contine--when pressed red SAT light does light up but nothing happens
Hello, there! My name is Becki Barned, with Dish Network customer service. You have probably already getten this resolved, but just in case it happens again, or you have questions, here is a link to our website, where you can take the steps to reprogram your remote, which is what is needed in this case. http://www.dishnetwork.com/SupportSection/remote-control I hope this helps in the future!!!
Jul 03, 2010 | DISH Network 142923 Remote Control
Light comes on but nothing happens
You need to replace the remote more than likely. Thanks for using Fix Ya.
Jan 29, 2010 | DISH Network 135899 Remote Control
Samsung remote control problem
Same issue as lisawrob
Check to see if there is another remote with something sitting on top of it. I had the same problem and found another remote transmitting (continously).
Jun 22, 2008 | Samsung RS105N Remote Control
Daewoo DLT22W4T 22 in. LCD TV Logo
189 people viewed this question
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
