Question about Cisco Catalyst 2948G-L3 Networking Switch
I have a problem with a cisco catalyst 2948G-L3. A have erase of mistake the bootflash. I have tried in some way to download a new IOS, i have the IOS bu i cannot download it in the flash because the switch doesn't know about the XMODEM command ot DNLDTFTP. What could i do to reinstall the IOS ???
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 80 Answers
Two ways to do that are xmodem (slow) or Tftp from rommon mode. (fast)
Place the IOS image in your tftp server directory and start tftp server.
Then enter the following in the switch exactly as below as all are case sensative:
rommon 1> IP_ADDRESS=xxx.xxx.xxx.xxx
rommon 2> IP_SUBNET_MASK=xxx.xxx.xxx.xxx
rommon 3> DEFAULT_GATEWAY=xxx.xxx.xxx.xxx
rommon 4> TFTP_SERVER=xxx.xxx.xxx.xxx
rommon 5> TFTP_FILE=full file name of ios as it reads
rommon 6> TFTP_CHECKSUM=0
this one is in lower case
rommon 7> tftpdnld
If you dont have a tftp server below is a link to a free one
http://www.solarwinds.net/Tools/Free_tools/TFTP_Server/
You will need the .bin IOS image for this and not the .tar file. The .tar file contains router cluster management files that you must issue the archive tar command to load all of the files. Can do that if needed after router is back online.
P.S.: If this information was helpful, please rate this solution.
Posted on Mar 12, 2009
How to reset catlyst 2948G swtich
get a console cable and and console to usb cable and plug it into the console port of the switch and type in the interface this:
- enable
- config t
- write erase
-(you should be promoted here type 'y')
- reload
-(should be promoted again type 'n')
-(should be promoted again type 'y')
This will rebuild config to factory settings.
Dec 17, 2013 | Cisco Catalyst 2948G-GE-TX (746320878614)
I forget the console password. i want to reset my password. How to do that? product: catalyst 2948G-GE-TX
You will have to reset the switch and intercept the boot into ROMON mode, then load the config file and change the console password, wright the mem and reload.
Sep 23, 2011 | Cisco Catalyst 2948G-GE-TX (746320878614)
How to reset the password for cisco 2948G-GE-TX.
In order to get your router back to the original settings, you must push in the reset button (usually on the back of the router) for somewhere between 10 and 30 seconds depending on the router. You may need a pin or something small to push in the button, because it can be recessed. Once you have reset the router, the username and password will be changed to the defaults, admin and password, respectively. One thing you must remember is that resetting the router will change all of the router settings back to the factory settings. This means you will lose all of the changes you made since you got the router. Make sure to write down any things you've changed, so you can change them back after the reset. Also, I recommend updating to the latest firmware after the reset.
If you need more help post back! Thumbs and testimonial are welcome!
Mar 25, 2011 | Cisco Catalyst 2948G-GE-TX (746320878614)
Dear Sir I have a CISCO WS-C2948G-L3 switch with me, when I power it up I get the following message :- ROMMON: Cold Reset frame @0x00000000 ROMMON: Reading reset reason register ROMMON: Valid...
It looks like the IOS is bad or not not there.
You need to instal a new IOS onto the switch.
For more help during installation you can refer
http://www.cisco.com/en/US/products/hw/switches/ps663/products_tech_note09186a00800949c3.shtml#cat4k
Dec 09, 2010 | Cisco WS-C2948G-L3 Catalyst 2948G-L3...
Corrupted Flash Catalyst 2948G
I have no idea if it will work on your switch - but I just looked in my IOS directory, and I have the following:
cat2948g-in-mz.120-25.W5.27.bin
I don't know where it came from, though - I tend to TFTP off the boot image on every piece of Cisco hardware I get just in case...
I just did a bit of Googling, and I found this - I guess from the filename it's newer than the version I have...
http://www.ti.net.ge/mrtg/ftp/cat2948g-in-mz.120-25.W5.27d.bin
Jul 11, 2009 | Cisco Catalyst 2948G-L3 Networking Switch
''!!! WARNING: The switch is not usable !!!''
Not enough info on this problem but you could always check the IOS version and upgrade it although the Cisco 3550 is end of life.
Apr 06, 2009 | Cisco Catalyst 3550-24 24-Port Ethernet...
How to reset the cisco switch to factory default?
When you say you were able to connect to the switch through hyperterm, were you able to login with the enable password? If not, you cannot reset the factory defaults without the enable password. If you do not have this then search on Cisco's site for password recovery for your model switch. If you did login with the enable password, the command to run for CATos is "clear config all". For Cisco IOS, you have the right command with "write erase". When you issue that command, do you get a "Erase of nvram: complete " or an error? Are you issuing the "reload" command after a successful erase? Be sure you answer No when it asks "System configuration has been modified. Save? [yes/no]:" as sometimes this seems misleading and some people think they mean to save the reloaded default. They are really warning you that you are about to loose the old configuration and attempting to prevent you from accidently erasing it. So answer "no". After a successful reload of the IOS you should also clear any VLAN information. To do this, issue "delete flash:vlan.dat" and then do another "reload".
Aug 29, 2007 | Cisco Catalyst 3560-24PS Switch
Problem with module WS-X4548-GB-RJ45V in Catalyst 4506
use software advisor in Cisco website to verify it.just follow the process.
console to it and show diag and see whether it detectable or not.
hope this help.
Dec 02, 2006 | Cisco WS-X4548-GB-RJ45V= Expansion Module
Cisco Catalyst 2948G-L3 Networking Switch Logo
1,009 people viewed this question
Top Cisco Computers & Internet Experts
Gopi Venkatesan
Gopi Venkatesan
Prashant M
Prashant M
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
