Question about Dell Inspiron 2200 Notebook
Iam getting a beep sound....when i start my computer....when i click escape it will goes off....when i right click on any folder again the sound will starts...i didnt got the problem in sound drivers...i has checked that....could u plz give me solution as soon as possible
Blue tooth is not work
Posted on Feb 24, 2009
  • ashu36 Feb 24, 2009
    blue tooth
Sony vaio vgn cs 12gh b at start up there is a beep beep sound, pretty loud, and when the password box comes it's automatically filling wwwwwwwwww endlessly. when it's finally open there is this...
Clear the saved passwords
Sony VAIO Care, an application pre-installed on most Sony laptops, is designed to automatically check for computer updates and to assist you with troubleshooting and maintenance. The application is configured to start as soon as the computer powers on. Although Sony VAIO Care is helpful, it is not necessary for it to launch automatically, as having too many programs launch at startup can cause your computer to run slowly. You can disable VAIO Care so it does not run at startup.
Click on "Start," then click "All Programs." Click on the "Accessories" folder. Click on the "System Tools" folder and click "Task Scheduler." Type your Administrator password, if asked for one, and click "Continue." The Task Scheduler window appears. Click on "Task Scheduler Library" in the left pane. Click on "VAIO Care." Click "Disable" under the "Actions" heading on the right side of the window. Close the window. When you next start the computer, VAIO Care will not automatically run
Hope this helps.
Jan 06, 2013 | Computers & Internet
Startup fails to complete properly
When on the screen, and you have no icons hold control(ctrl) down and shift key and press escape(esc) your windows task manager should appear, goto the applications tab, at the bottom goto the tab New Task and left click, another window should appear with a text bar, type in the text bar explorer.exe and click ok, all the icons and your normal screen should reapear.
If your screen goes back to normal goto the start bar and goto run or search and type "regedit".
When the regedit window appears left click the " + " sign next to Hkey_local_mechine the the plus sign on software, scroll down to Microsoft folder and click the plus sign, scroll down to Windows nt folder and click the plus sign, the plus sign on Current version folder, then scroll down to winlogon folder and left click on the folder icon, on the right hand side of the screen look for "shell" double click on the icon and delete everything in the text bar and type explorer.exe and click ok and exit out of the window, restart the pc and everything should be back to normal.
pls post back and tell me what happens.cheers.
Jan 30, 2010 | Computers & Internet
Small screen goes blank when I click on "Start Recording" and I get "record error" I am trying to record to hard drive folder
Disconnect your dazzle then connect it again at the back of your computer. Click on Start>Control panel>system>hardware>device manager>sound and video games controller> right click on video capture device and uninstall it. Restart your computer. Wait for the new hardware found message comes out and then open your IDVDR again and then do the advance mode. On step number1 choose capture source click the pull down arrow and then choose dvc 100. Turn the power on on your camcorder and run it. Make sure that the video image showed on your preview screen. Try record it again.
Sep 28, 2009 | Pinnacle Dazzle DVD Recorder
Slow beeping sound without warning light on 2002 Escape
IF you do not show any Warning Lights. You may have a bad bulb. Pull the Frame from around the Speedometer Dash and then unplug the cables and then Get a meter and and check continuity on the bulbs. They are pretty easy to twist & pull out. I had a warning sound the same as yours . Metered it out and found the Airbag is Bad. Wich is also attached to the Horn. Bad way to do things. Anyways try that.Circuspyro
Apr 16, 2009 | 2002 Ford Escape
Beep sound
DEAR,
PL SEND INFORMATION OF BEEPS SOUND.
HOW CAN BEEP GENERATE .CONTINUOUS OR ONE BY ONE AND HOW TIMES.
IF U ARE GOING TO HP SITE CUSTOMER SUPPORT THAT GIVES PROPER SOLUTION FOR THAT.
Feb 24, 2009 | HP Pavilion dv2000t Notebook
Iam not able to view hidden folders
Click on "My Computer"
Click on "Tools" at top of screen
Click on "Folder Options"
Select "Show Files and Hidden Folders"
you're done!
Jan 08, 2009 | Computers & Internet
Hp Pavilion XT963 four beep startup and nothing
Since iam not sure about the beep noise that u get....becos there are different pattern for it.
so iam pasting this link and let me knw the pattern plz..
http://www.computerhope.com/beep.htm
or else it could be the power supply which is not placed in properly try unplug and placing it back again.
or let me knw the exact noise that u get is it a beep noise or clunking sound or very, quiet jet taking or Noisy fans.
Thank you.
Oct 01, 2008 | Computers & Internet
Tomtom one starts then goe's to tomtom one picture
This solution is for jrhsr57 and cherryd90 connect your tt device to your computer. It should boot up and connect to your computer. After it has connected go to "My Computer" and open the drive of your tt. Make sure on your computer you have selected to show all files. To make sure all files are being displayed in Win XP go to "Control Panel" then open "Folder Options". Then click on "View". Scroll down and make sure "Show hidden files and folders" is checked. Next make a "New Folder" on your desktop (right click anywhere on your desktop and select "folder"). Go back to "My Computer and open the drive of your tt. Click "edit" then "select all" Go back to "edit" and select "copy". After doing this go to the "New Folder" you made previously and right click and select paste. You have just made a backup of your tt device (DO NOT DO THIS USING TT HOME). This will take a little time so be patient. After making a complete backup of your tt device go back to "MY Computer" and right click on your devices drive and select "Format". Format it in "Fat 32". This will erase everything on your tt's drive. After formatting your tt's drive open tt home. Home will then tell you you need an application, click OK and let tt home install the application for you. After tt home has installed the new application go back to the "New Folder" where you made a backup of your tt device. Open the folder and right click on the map of your device and select "Copy", then go to "MY Computer". Do NOT open the device drive but simply put your arrow on the drive of your tt and right click and select "paste". You may have to do the same to the "Voices" folder. After doing this open tt home again and it will more than likely tell you, you need a application update, again let tt home install the application. This will update your tt to the most up to date application for your device. After doing this and everything is working go back to the "New Folder" where you made a backup of your device. Open the folder and delete everything there. Now make a backup of everything on your working tt. Keep this backup in case something goes wrong on your tt again. I can not express strongly enough NOT to do this using tt home.
Aug 25, 2008 | Tomtom ONE GPS Receiver
Dell Inspiron 2200 Notebook Logo
46 people viewed this question
Alun Cox
