Question about Car Audio & Video
My Boss Amp keeps cuts off when I play the music from my stereo when i play music and turn it up the amp keeps cutting in and out and i have to tap it and it will turn on
  • 80 Answers
Someting is busted in the amp! needs to be repaired or replaced !
make sure all wires are tight tied to the terminals first!
thanks
erik
Posted on Feb 27, 2009
Peavey problems
solder joint somewhere..
Jan 08, 2014 | Peavey Vypyr Tube 60 Amp Combo
Amp going into protect mode
The first thing I would check is how your speakers are wired to the amp. Multiple speakers wired in series or parallel will change the overall impedance that the amplifier "sees". If your impedance is too low (let's say 1 ohm) and your amp is only stable to 2 ohms, the amp will shut off to prevent over heating and damage. Hope this helps.
Jul 11, 2013 | Boss Car Audio & Video
My line 6 lowdown 750 keeps cutting out when i play a low b on my bass
Protective circuits kicking in. You may be overdriving the preamp to a clipping condition the amp sees as a problem. If it is under warranty, contact Line 6 and see if this is normal for this amp. It should not be, but you never can be sure.
Apr 26, 2012 | Line 6 Music
My amp keeps cutting out
If your ampliffier is cutting off even when it is not playing music or without load, it is possible that some errors are on in the protect circuit. Look for possible fault in capacitorrs in this circuit. If not the powering of the outputs can cause the intermittent failure due to overloading. So check you speakers, your speaker connections and also your main power inlets. Check for any spark marks on the plug top, if so use an emery paper to clean. Still if the fault is persisting then you will need som help to probe into the main board . Tap into the board for the fault to come up , in this case there could be dry points in the board. Look carefully into the boarrd and solder all suspect joints. Otherwwise you will need a good check on the cut off error amp, disconnect power amp and check. isolate and confirm the section in fault. Hope you try. Good day
Aug 01, 2010 | Yamaha AX-496 2-Channel Amplifier
Amp cuts off
sounds like you are overheating the amp, if the amp has a fan to cool it off, make sure it is turning on and working... if it is not then replace the fan to fix the problem...also turn the amp gain down a little bit and try running it again and see if it still shuts off...if it doesn't shut off then you have teh gain to high and are cutting out the amp with to much power going thru it...
Jun 13, 2009 | JBL BP300.1 PowerValve Series Car Audio...
When i play music loud the sound cuts out
i would try getting a new amp, the speakers may be blown.
Dec 30, 2008 | Audio Players & Recorders
check your ground wire and your remote wire, Wiggle them separately both at the amp and at the ground point. See if it cuts out then, and you;ll know which one. Also, does it have a light on it when it cuts out? if so, it could be going into protect mode, which wont allow it to turn on for a period of tine. Make sure the amp is not too small for the speakers you are pushing.
NGK
Sep 03, 2008 | Boss Car Audio & Video
Denon AVR 2802 - Unit Turning Off
If DIGITAL sign blink, this mean DSP board is defective. It will cut the sound on the AMP section. DSp is maybe defective.
Jan 12, 2008 | Denon AVR-2802
Car Audio & Video Logo
142 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
