Question about IBM Infoprint 1532 Laser Printer
IBM Infoprint 1532 Tray Selection
I have an IBM Infoprint 1532 printer.
When it runs out of paper from tray 1 it will NOT automatically switch to tray 2.
Instead it just stops & beeps, message reads load paper in tray 1!
I have checked the configuration on the print server, I can't see a setting which allows me to set paper tray to Auto - it only allows me to set tray1 or 2 from the configuration menu\paper menu\default soure
can you help?
Russ
  • 13 Answers
For tray linking to work, both Paper Size AND Paper type must be configured the same for both trays. You probably have the paper sizes the same but types could be different. The is no setting to make tray linking work.. it will do it automatically if the above settings are correct.
Posted on May 19, 2009
  • Super8Ash Dec 08, 2010
    Sooo How do you change the types. Cause Mine at work as Asterisk beside them and I even downloaded the Manual and Still gettin nothing. Tray one is set at Letter with Plain paper and tray two is Universal with Plain paper. Had it the same once tried to print and tray two jammed up on us and its making me nuts!! Can you Help me out??
You also have to map the trays.
Map Tray1 to Tray2 and
Map Tray2 to Tray2
Submit and you are all set!
Posted on Mar 16, 2010
Paper jam in tray 2 but there is no paper jam?
check the pick roller from tray2.
try to change the pick rollers tire in the tray.
it worked for me many times
stefan
Apr 14, 2010 | IBM Infoprint 1532 Laser Printer
It will not pull from tray at all
Hi
The roller need cleaning up with some white spirits or need replacing
Jan 22, 2010 | IBM Infoprint 1532 Laser Printer
IBM 1532 2nd tray is installed but the printer isn';t seeing it
First of all, let's establish exactly what doesn't see the second tray - the printer or the computer?
Go to the printer's display, enter the menu and find a configuration sheet print option (or something to that effect). All printers can output a summary page with all relevant information, like memory, settings and also paper trays. If the second tray is not mentioned on the configuration sheet, then there must be some problem with electrical connection between the printer and the tray.
If however the printer sees the tray, only the computer doesn't let you print/select it, you must open the control panel, printers, properties for your printer and find an option like "installable accessories", "optional components" or something similar, where you will find an option to enable the second tray, thus informing the printer driver that the printer is equipped with 2nd tray.
Good luck
Nov 01, 2009 | IBM Infoprint 1352 Laser Printer
IBM 1532 makes a loud bang loading an envelope
That sound is actually the printer sucking the air out of the envelope to flatten it out. It is normal and there is no way to turn it off.
Aug 07, 2009 | IBM Infoprint 1532 Laser Printer
My printer is saying tray 1 paper jam but there is no jam and now its not printing. how do i fix this
I'm not sure how to fix it yet but I have two of these printers and if I use the tray from my other printer it works. I'm not sure what's wrong with the tray but it is the tray for sure.
Jul 15, 2009 | IBM Infoprint 1532 Laser Printer
Paper tray is in the printer,but the printer says missing tray 1
There are two possible solutions: The first is that the lugs on the side of the paper tray are broken, and the printer cannot "see" a paper tray. In this case you need a new paper tray. The other possibility is that the tray and paper size sensor inside the printer is faulty. Often just pushing the contacts can free them, and sometimes the metal prongs that sense the lugs on the side of the paper tray get unseated. Just use your finger to reseat them correctly. If that doesn't work, the sensor board is likely to have failed, and will need replacing
Jun 11, 2009 | IBM Infoprint 1120 Laser Printer
IBM Infoprint 1532
There is probably a small piece of paper in the back of the printer in the fuser. Shutdown the printer and wait a few minutes as this part is hot. You may need to remove a few screws to take off the back cover and check inside the fuser.
Jun 03, 2009 | IBM Infoprint 1532 Laser Printer
Tray selection issue: Documents may be setup to print to the MP feeder, (multipurpose feed, not manual feed), but the printer will only pull from tray 4. I'm not sure why, earlier this week it would o
The usual reason that the printer will ask you to load paper into the MPF is that the green paper guides in the paper tray is not clicked in the right position. It only needs to be slightly out of position to give the wrong paper size info to the printer. The easiest way to confirm if the guides are correct is to print the Menu Settings Page. Check that the paper sizes listed in that report are the same as the actual paper sizes in each tray. If it's different you need to adjust the guide correctly. It's remotely possible that the sensing switch is faulty but it's more likely that the paper tray guide isn't latched in it's correct position.
May 29, 2009 | IBM Infoprint 1532 Laser Printer
Tray 1 Low
How many input trays does this printer have?
Trays can be renumbered to allow for larger capacity input trays.
Please print out the menu setting pages and verify the correct paper tray numbers.
Don
May 15, 2009 | IBM Infoprint 1532 Laser Printer
Change tray 1 paper size
You need to adjust the green paper size sensor in the back of the tray to letter. This is connected to sensors on the side of the tray. If you set it directly to Letter, then the printer will read the tray as letter paper.
Mar 13, 2009 | IBM Infoprint 1352 Laser Printer
IBM Infoprint 1532 Laser Printer Logo
825 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
jasbo
jasbo
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
