Question about APC Back-UPS Pro 650 UPS System
Apc ups 650va no power when connctd to ac/bt wd power in on batry
My back ups cs(apc) 650 va has power if running on battery but when i plug it to an outlet power is cut off
    An expert who has answered 20 or more questions within one hour.
  • 91 Answers
Check the relay Circuit. the relay switch must be faulty
Posted on Aug 14, 2009
How can you tell if the system is bad on apc back ups es 650
plug something (other then a computer)into it, turn the gadget on, then unplug the UPS. If the gadget continues active the UPS is OK. Generally after you have punched every button (circuit breakers). After that put a Volt/Ohm meter on the batteries (and the charging wires to check the charging curcuit is OK.
Apr 29, 2014 | APC Back-UPS ES 350 - UPS ( external ) -...
My APC cs 650 is dead
try replacing the battery, if it does not at all. have to buy a new UPS because the control board is damage
Mar 18, 2014 | APC Computers & Internet
Pro 650va
hi i am rehan frm karachi 03312504748 ap k ups ki battari kharab he
Jul 24, 2013 | APC Back-UPS CS 350VA - UPS - 350 VA - UPS...
Apc 650 back-ups does not boot
try turning on the power connection
Mar 22, 2013 | APC Back-UPS Pro 650 UPS System
Our BX1500 cycles between "On Battery" and "On
This sounds like a battery issue, test the battery by itself....
Apr 02, 2011 | APC APS BackUPS CS 650VA 400W 230V DB9...
Hello sir, I don't actually know how to charge my apc cs 650... and And when the power is out, so does my computer.. low battery.. I just need a simple answer about this.. is it not charging? or do i need...
If you connect the control cable to a PC and install the PowerChute Personal Edition V3.0.2 f software you should be able to see if it is charging and what the percentage of charge held in the battery is.
On the CS 650 the lowest power connection is the surge only powerpoint.
To give the battery a full charge or to test it you can connect it to a car battery trickle charger, as it is a 12 volt battery, rthis will at least mean you can check that it holds a charge in the first place.
Dec 23, 2010 | APC APS BackUPS CS 650VA 400W 230V DB9...
We can charging for 100AH battery for in 650 APC UPS. its possible or not
Yes you can change the battery. All you need to do is ensure that the replacement battery has the right physical size to fit in the cabinet and meets the required spec. Simply having a larger AH rating means that it will last longer under load when it is required and will take longer to charge after it has been used.
Sep 29, 2009 | APC Back UPS 650 (APWBK650MC) UPS System
APC Back-UPS Pro 650 UPS System Logo
624 people viewed this question
Top APC Computers & Internet Experts
Jax Planet
Jax Planet
Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
