Question about Rainbow E series Canister Wet/Dry Vacuum
How do I change the hepafilter on my Rainbow E series? Thanks judyc0293@netscape.net
  • judy p cheramie Mar 01, 2009
    Hello, This experience was fab! I never thought I would get the reply so quickly.But the best part is that the answer to the problem was right! The problem solver made it simple to do with his easy to follow exp[lanation. Thanks
  • Rainbow Expert
  • 324 Answers
You have to remove rear cover (on the opposite side than the intake is) There are 2 kinds of HEPA and 2 kinds of filter covers:
HEPA encased in black plastic - on the bottom of the unit you will see two latches and you can use a flat screw driver release them and filter cover just pops out.
HEPA older style (white filter with black plastic frame) - there are 2 Phillips screws on the bottom of the unit and 2 more under the cord caddy. Use flat screw driver to remove the cord caddy (put it in between the housing and the caddy and it would come off)
If you need filters - they are HERE.
Good Luck
Posted on Feb 26, 2009
The e series rainbow 2 speed works only on low speed. High speed will not run. What is srong?
It is either the switch or the controller. Call us and we can see if it is still covered under your warranty.
RainVac
www.rainvac.com
800-523-0510
Jul 23, 2012 | Rainbow E series Canister Wet/Dry Vacuum
I changed the hepafilter on my eseries Rainbow Vacuum cleaner, I rinsed it with water,put everything back and now it wont turn on.
please dry the hapafilter before putting it back
and then try switching on
thank you
with regards
Trilok
Jan 25, 2011 | Vacuums
RAINBOW E SERIES REPAIR MANUAL
Hi. I found it on amazon, here: Amazon com rainbow vacuum manual. I hope I have helped. cheers
Mar 31, 2010 | Rainbow E series Canister Wet/Dry Vacuum
How to replace belt on rainbow aquamate and locate repair manual on the net
click on rainbo vacuum in your area, and go from there. I am sure they have a toll free #.
Oct 18, 2009 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow E Series Vacuum
It's plugged!
If it happened suddenly, you have a jam somewhere. Unhook the hose to see if it's in the hose or the unit.
If it happened over time then it's likely dirty or full. Wet dirt can accumulate near the blower and inhibit suction. Cleaning the filter is almost always a good idea.
Best to you, Jidza
Jan 23, 2009 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow e series Canister vacuum
http://geeksquad.fixya.com/ThreadView.aspx?prdid=19674&thid=661549
Posted by tinyrose on Jun 10, 2008
I am looking for a repair manual for this vacuum. Just stopped working and will not turn on. Can you tell me where to get a manual? Thanks
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Rainbow E Series Canister Wet/Dry Vacuum. The best way to get a Rainbow E Series owner’s manual is to contact the Rainbow website and or factory and give them the model and serial # for the item and you may be able to download the manual from the website or the might have to mail it out to your home USPS. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
The Rainbow / RexAir Factory phone number is listed below:
http://rainbowvacuum.com Customer Service
1-248-643-7222 Monday thru Friday from 9:00 am to 5:00 pm EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 10, 2008 | Rainbow E series Canister Wet/Dry Vacuum
RE: Installing rainbow E series water pan latch
http://geeksquad.fixya.com/ThreadView.aspx?prdid=19674&thid=652000
Posted by bettyannsoto on Jun 06, 2008
Need to know how to install rainbow water pan latch and spring latch
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Rainbow E Series Canister Wet/Dry Vacuum. The Rainbow latch can be replaced but I believe it is a pop rivet that holds and replaces the old latch and to replace the new latch, I have seen it done but if you don’t have the right tools you may want to contact your local vacuum cleaner dealer in your area, it can be done. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
Go Ahead. Use Us.
Jun 06, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow E series
http://geeksquad.fixya.com/ThreadView.aspx?prdid=19674&thid=651990
Rainbow E series
Need to install rainbow side water pan latch and spring. How to do it?
Go Ahead. Use Us.
Changing the filter in Rainbow e series
Some of the e-series has a corrugated filter in the top section. To get to it, remove the clear plastic panels that are the sides. Most have 3 screws on each side to move, then the top half will come loose. There also is filter on the back, there is a door to remove to get to it.
Jun 03, 2008 | Rainbow 75th Anniversary Canister Vacuum
Rainbow E series Canister Wet/Dry Vacuum Logo
295 people viewed this question
Top Rainbow Vacuums Experts
Joseph Hoffmann
Jax Planet
Jax Planet
Are you a Rainbow Vacuum Expert? Answer questions, earn points and help others
