Question about Cfm Daikin R410a Split System Air Conditioner
Split Airconditioner I have 18000 btu split type airconditioner, with R22 ,due to leakage it has lost all refrigrant ,I have all equipment to insert r22 my question is this do i also need to put oil in unit if yes then how much and how to put oil,can i put oil from suction side or is there any other way to do so ,kindly explain it to me comprehensively,Thanks in advance,my email is , Comment posted on Feb 24, 2009Rank: GuruRating: 87%, 26 votes You shouldn't have to add oil. The little bit that leaks out with refrigerant isn't significant. I would be more concerned about the leak itself. Has it been located and fixed. If not it will no doubt leak out again. Also do you know how much refrigerant to put in the system? Have you vacuumed the air/moisture from the system etc. Is the system totally flat or is there still some refrigerant in it? Let me know so I can advise you correctly. Thanks for your kind attention and reply sir,I am a hobbiest and it is my passion to learn about things,I have fixed the leakage ,and amount of r22 to fill in unit is written on its tag its about 1.2 kg,i also have pressure meter and digital scale to check exact amout, but my question still remains that what is method to put oil in unit for future problems ,and what should be the amount ? can i put oil from suction side or anyelse method and when do a compressor really need oil?
    Problem Solver:
  • 5 Answers
You can add oil to unit from suction valve but you have to know how much == you have to remove the cmopressor drain it of oil and add the countity that wrighten on it between 500 and 750 cc appro
as i understand your question when you know that the comp needs oil change
its when it is over heated or work at high temp
so you can hear a noise or an usual motor noise
i wish it ok
Posted on Feb 24, 2009
I have a koppel split type airconditioner.my remote was deffective can i use a universal remote control chunghop.what is the code?
There is probably no code built into the Chunghop. If the Chunghop has a "Learn" function then you can teach it the commands using an original remote (hopefully you can borrow one).
Jun 08, 2016 | Universal Remote Control Televison & Video
WHAT IS REFRIGERANT SUCTION PRESSURE OF MY 1 TON SPLIT AC?
R22= 70-80psig
R410a=120-130psig
Depending on many variables such as blower speed, coils clean, indoor/outdoor temps.
Aug 05, 2015 | AMVENT 18000 Btu 1.5 Ton Ductless Mini...
Where can I buy a regas kit for my split unit airconditioner I live on the Gold Coast
I've never heard of a regas kit for a split a/c system. You need a declaimer, a vacuum pump, the designated refrigerant, gauges, and a digital scale. Evacuate the system, when system holds a vacuum, look up amount of refrigerant and type from mfg. tag on unit of spec book. Add specified amout of refrigerant and your done. If noy familiar with pressure on gauges you can use an amp meter to ensure unit is not over charged or has a restriction which would cause higher discharge pressure and therefore high amperage. Best to call a tech. Cheaper and safer.,
Jan 01, 2015 | Sanyo 33,000 Btu Ductless Airconditioner
Remote control required for airconditioner
Not too many units only work with remote control...try using Bing or Google to find your problem and solution to the answers that you seek.
May 18, 2013 | Heating & Cooling
Help me please have a R410a 12000 btu mini split airconditioner heat pump that lost gas how do l regas it have closed all the leaks and have the R410a refregerant with the adapter.i have not charged a...
Mini splits need to have the refrigerant weighed in. First, ( if the system is already empty ) pull a vacuum down to 500 microns. Second, add the amount of refrigerant listed on the mfg. tag. Hope this helps!
Jun 07, 2012 | Heating & Cooling
I i`ve got a haier split type air conditionner model HSU12XCA on R22 gaz which barely cools and freezes after a while. The suction pressure is at 120 PSI and it is freezing on the liquide line. I`ve clean...
The unit has a leak and is low on freon...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Jul 12, 2011 | Haier HSU12XCA Cooling Only Mini Split Air...
F8 error
F8 on tamashi ac
Jul 03, 2010 | LG Heating & Cooling
Art Cool LA181CNW Split System Air Conditioner: hi, i am using an lg split airconditioner. the sp...
Sound like a defective receiver board. Have this checked. Also check to see that your remote transmits. Hold the top part of the remote to your phone or digital camera lens. press a button and a light should appear on the screen of your phone or digital camera screen.
Hope this helps I take the time to answer your question so please rate me
May 18, 2010 | LG Art Cool LA181CNW Split System Air...
How to insert oil in outdoor of split type airconditioner
Feb 23, 2009 | Cfm Daikin R410a Split System Air...
Cfm Daikin R410a Split System Air Conditioner Logo
1,902 people viewed this question
Top Cfm Heating & Cooling Experts
Dan Webster
Dan Webster
David Payne
David Payne
Brett Duxbury
Brett Duxbury
Are you a Cfm Heating and Cooling Expert? Answer questions, earn points and help others
