Question about Freezers
Whirlpool sbs fridge freezer - freezer stopped working
Motor had been getting louder over some time (cutting in&out as usual). Motor stopped working one day & so did freezer. Ice maker still works & lights come on, fridge not working as well as it should. Frame of fridge & freezer where door seals close against are very hot while power is on?? Icemaker was replaced a few weeks ago with success.
  • 410 Answers
There are 2 or 3 things that would cause this. first make sure the condenser coils are not plugged with dust (vacumn or blow them out) next check to make sure the fan that cools these coils is running, (this is the most likely problem). if both of these check out ok then you would need to check to make sure your interior lights ar going off when the doors are closed as these will add extra heat and cause the center rails to run hot. last and most uncommon would be a freon system problem.
fyi there is a hot gas freon line that runs in between the doors to prevent exterior sweating. when poor or no air flow problems for the condenser coil exist it causes this area to become hotter.
One more thing. if you do determine that the condenser fan motor is bad you can put a normal house fan blowing on to the coil to help cool this area down until you can get the unit repaired.
If you need any further assistance leave me a comment here and I'll gladly get back to you. Thanks Peyton
Posted on Feb 24, 2009
Freezer in unheated garage stops working
Check connections from your power outlet to your fridge. If the motor is not running check your thermostat. if not working check your compressor motor.
Feb 10, 2014 | Whirlpool 19.6 cu. ft. Upright Freezer...
Fridge freezer stopped making ice digital display has gone off at the front of appliance, when you open door lights flicker and it makes a noise.
I have seen this a few times on whirlpool refrigerators. There is likely a high voltage board mounted inside a grey or white box mounted next to the compressor. The noise is usually eminating from this box, and replacing the board will solve all of your problems most likely.
Sep 23, 2010 | Whirlpool Freezers
We get clicking noises when water is dispensed. also the fridge compartment is not cold at all - the freezer is working (at the moment). model SB540W/SAL2027GBB. Service code 85951051500 / 110738001758....
the clicking sound is normal it sounds like valve operating or you may have the water pressure up to hgh for the unit. for your second problem is the fan operating inthe fridge this stops the cold air to transfer from the freezer, also check the operation of the damper this is the flap the controls the amount of air into the fridge this is uasualy controled by a by metalic thermostat or motor. thirdly which mostly common is the defrost heater is not working signs are frozer evaperator in freezer and air duct the checks are defrost timer, heater element terminatinion thermostat and someunits have thermofuses goodluck
Aug 23, 2010 | Whirlpool Freezers
Whirlpool side by side fridge not cooling
Yes, only part that gets could is in the Freezer. If block by ice (usually) this will not allow the cold air to go into the ref., if so, defrost problem. Check amount of ice on coils in back of Freezer. Should only be a thin frosting.
May 02, 2009 | Whirlpool 19.6 cu. ft. Upright Freezer...
Motor goes on/off every few second.
You have problem with the motor compressor,it is trying to start, but cannot for one reason or another, could be siezed motor, sticking start relay.etc'
It is stopping and starting due to the motor overload device cutting in and out. it acts as a safety device.
This is usually associated with a serious malfunction..Plz rate my solution.
Thanks.
Dec 28, 2008 | Engel Freezer 22 Qt. Fridge/Freezer
Whirlpool 20RB D4 Fridge Freezer clicking
Hi the reason for your noise coming from the fridge freezer is the plastic that is used in the design of your product is of a low quailty which reacts to the temp change and then as they get cold again they start to crack inside the frigde! Nothing to worrry about........
Hope this helps.....
Dec 23, 2008 | Freezers
Fridge freezer upright
Replaced the thermostat
Jun 22, 2008 | Freezers
Freezers Logo
158 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
