Question about Sony VAIO NS Series Notebook
Not staring up-sony vaio
Hi,i have a sony vaio vgn-ns11m and after standing overnight,when switched on,the green power light turns on but the screen remains blank,i have switch off,then restart,it does a repair and system restore then all is ok until the next morning.
Chris
  • Anonymous Mar 22, 2009
    When I power on, the green power light comes on but nothing appears on the screen. The orange battery light also flashes.
What would be the probable cause of a sony vaio fs830/w of starting up & the 3 green leds on top stayed lit
You were FORMATTING it? Meaning... you were erasing the operating system? If that's the case, then... you have no operating system and the computer cannot boot up because it has no operating system to boot into.
Jul 30, 2014 | Sony VAIO VGN-FS830/W Notebook
My Sony Vaio VGN NW225F laptop won't start up.
First thinkg I'd do is to connect an external monitor to the laptop to see if you can get an image, any image, during booting. If you can't see anything, either using the laptop's screen or external monitor, then you have a hardware failure in the laptop that's probably beyond the abilities of a novice to repair. Get somebody who knows about how to clear the CMOS of the laptop.
Nov 08, 2017 | Sony Computers & Internet
Vgn-ns11m wireless device needs a driver where can i get one?
*You can download the driver here. Also includes drivers for windows Vista, Windows7 and preinstalled drivers.
*Chose which driver you want to install and download.Thanks for using Fixya.
Jul 26, 2010 | Sony VAIO NS Series Notebook
Sony vaio mod. PCG-7T1L will not turn on. power supply ok.
Have power supply checked with digital multi meter as they can still be faulty with green light on.
Mar 16, 2010 | Sony VAIO VGN-N320E Notebook
My sony vaio vgn -T350P , when I turn it on, I
hi, it may be a ram or processor problem you may need to replace one of them
Jan 17, 2010 | Sony VAIO VGN-T350P/T Notebook
My sony vaio vgn-fs285e will not switch on since this morning. Even if the AC adapter is plugged-in it still won't come on. None of the lights come on, it won't run with the battery pack or just AC power....
To check if the problem is the power adaptor or the Vaio, just have a look at the charger itself and see if the green light on the adaptor itself is on?If yes, then more likely it is working fine. If no light, change the fuse in the plug and try again.
You can also try a static discharge on the Vaio. Please remove all external devices, unplug the adaptor and remove the battery. Put your finger on the power button and hold it for about 30 seconds. Then connect the power adaptor again and try to boot.
Regards,
Purito
Oct 17, 2009 | Sony VAIO NR Series Notebook VGNNR460EP
VAio VGN-FS742 Screen does not display
Try to remove the battery, remove AC adapter, and press and hold power button for 45 sec. reinsert battery, and Plug and try again, if that doesn't solve it, you may need to try to change memory first, (cheapest) or the motherboard or CPU.
Please give good rating if this helps your issue, Thanks
Apr 12, 2009 | Sony VAIO VGN-FS742/W Notebook
Black screen
how brave are you ?
is it under warranty ?
Oct 30, 2008 | Sony VAIO VGN-N250N/B Notebook
Sony vaio vgn-n250e laptop microphone problem
You can download what ever Vista driver required for your VGN-N250E Sony Vaio at Sony Vaio Support.
Good Luck.
Oct 24, 2008 | Sony VAIO VGN-N250E/B Notebook
Sony VAIO NS Series Notebook Logo
176 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
