Question about Poulan Garden
Operators Manual for WCI Outdoor Product Inc 22V Petrol Weed Eater Blower Ser No 95108 N
3 Suggested Answers
KMusselmann
  • 247 Answers
SOURCE: starter rope on bv2000 weed eater blower needs to be replaced.
Hi, Try the following, But make dure you can wind the spring. If not the spring is broken.
Kurt
This usually happens at the most inopportune time. You go out mow the lawn, pull the rope and it comes out in your hand. Here's how to fix it yourself.
First, we'll talk about a simple rope replacement. In most cases you will have to remove the blower housing from the engine to get to the underside of the rewind starter where the rope is. We'll assume at this point that the spring is ok and you can just wind it back up again. You can check the spring by turning on the hub in a counter-clockwise direction and see if the spring gains tension. Do not try to remove the spring from its holder or you may end up having to take the mower in for service.
1. Remove the rope from around the hub. Since there is no tension, it should come right out. If you are lucky and it broke near one end, you can probably just re-use it. If it is badly frayed or too short, you will need to find a replacement at a local hardware store.
2. Attach the handle or tie a knot in one end of the rope so it will not wind all the way into the hub. You also may want to burn the rope ends to keep them from fraying and causing a problem in the future. Set the rope aside where you can grab it once you wind up the spring.
3. Wind the hub in a counter-clockwise direction using your thumb to keep it from unwinding, until the spring is tight. Then let it come back slightly so the rope hole in the starter housing lines up with the rope hole in the hub.
4. Stick the rope through both holes while holding the hub from unwinding. This is tricky because you don't want the hub to unwind on you before you have the rope secured in it. A pair of needle nose pliers or a small screwdriver or pick may help get the rope through.
5. Tie a half hitch knot in the rope after you have it through both holes. While holding the rope, release your hold on the hub and let the rope slowly pull itself back into the starter.
6. Put the blower housing back on and your ready to start the engine & mow.
Posted on Mar 23, 2009
#1 Taper
  • 1040 Answers
SOURCE: what is the gas and
40:1 which is 3oz. of 2 Cycle Oil to 1 Gallon of gas.
Jim
Posted on Aug 16, 2011
What is the spark plug gap for 18cc weed eater?
search
What is the correct spark plug gap?
The spark plug gap on all products is .025-inch.
What type of spark plug does the unit take?
The size of the plug varies from unit to unit. On trimmers, blowers and hedge trimmers is RCJ-8Y or RCJ-6Y. Follow the spark plug recommendation and replacement procedures in the operator's manual if you are doing the work yourself.
Jun 07, 2015 | Weed Eater Featherlite 18cc 2 Speed Gas...
Need to switch weed eater barricuda from blower to Vacuum but no manual
http://lawnandgarden.manualsonline.com/manuals/mfg/weed_eater/2500_series.html?idRes=15826113
Here is where you can find the manual to download for the 2500 series Weed Eaater blower/vac
Aug 29, 2011 | RTO Weed Eater Electric Barracuda 2595...
What is the gas and oil ratio for Weed Eater leaf Blower GBI 22V? please
Jim
Aug 15, 2011 | Weedeater Gas Blower
What type of oil does the poulan pro BVM 200 EL use and is the gas:oil ratio 40:1?
use - husqvarna , sthil brands high quality 2 stroke oil
as directed on bottle 50:1 that is 20 mils of oil for every 1.0 litre of petrol that you use
if you want 2 litres mix put in 40 mils of oil into petrol container
then put in 2 litres of petrol only and give good shake and fill the blower
cheers
Sep 01, 2010 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
I can't find my owner's manual for my FL1500 blower. Where can I get a free one?
You can find the Poulan and Weed Eater instructions and manuals at InstructionSheets.com.
Here is a link to the page where you can download the Weed Eater FL 1500 Featherlite Gas Blower Manual.
Apr 15, 2010 | Poulan Featherlite Gas Blower, with Low...
Ryobi petrol weed eater
SOUNDS LIKE YOU MAY NEED TO REPLACE THE FULE LINES THAY DO GET BAD OVER TIME
Dec 08, 2009 | Ryobi Garden
How do I get the engine cover off of my gb1 22v weedeater so that
You have to take the one side off to access the fuel tank and lines
you will need a hex head wrench or allen wrench some would call and some patience and note that every hole has a hex head.
Even if you are mechanically inclined it is a pain as you need to know and watch how it comes apart and goes back is crucial to your and its success.
Hope this helps?
May 24, 2009 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
I have a Weed Eater Barracuda leaf blower but don't have the manual. How do I attach the vacuum bag?
http://72.3.225.179/manuals/545117523e.pdf
Copy and paste. It will take you to .pdf for your Barracuda
Apr 30, 2009 | RTO Weed Eater Electric Barracuda 2595...
How to you repalce a fuel line on a weedeater gb1/22v leaf blower
When replacing fuel line, make sure that you have the correct size lines. Depending on the size of your engine, the lines may vary in size. The primer bulb line will sometimes be larger in diameter than the fuel line to the carburetor. The primer bulb line will be the shorter of the two. When replacing the fuel line, make sure you have enough line to go from the bottom of the tank up to the carburetor. Give yourself a couple extra inches to work with. Cut one end at an angle, this makes it easier to feed down through the hole. Continue feeding the line until it comes out of the gas cap hole. Then cut the end of the line square again and attach the fuel filter that goes on the end of the line. Place the filter back in the tank, then adjust the line so that the fuel filter lays comfortably at the bottom of the tank. Then attach the other end of the line, (where you inserted it), to the carburetor, cutting off any extra line you may have.
Mar 27, 2009 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
Garden Logo
74 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
