Question about Praktica DC Slim 520 Digital Camera
Slide back my power on/off cover on my DC SLIM 524 Digital Camera But thelens do not go back.
  • 423 Answers
Most of the time this is caused by dirt, grit or sand in the lens mechanism. The best way to fix this is to use an air compressor. Put the nozzle to the space between the lens and the camera and blow air into the space, you may have to do it a few time until its clean. Let me know if you have any more problems, and don't forget to rate my answer a fixya.
Rob
Posted on Feb 24, 2009
Who can repair a Gateway DC-T50
Refer to the manual page below - note the last 2 items
If you take the camera and the card to a sales outlet the assistants are usually helpful
Inserting an SD Memory Card(Optional)
All images and video clips taken by the camera can be stored in an SD (Secure
Digital) Memory Card. Even if the camera's power is OFF, the images saved in the
SD Memory Card are not erased. An SD Memory Card can be repeatedly read and
written. You may also expand the memory capacity up to 512MB so that you can
store additional images and video clips.
1. Make sure the camera is off.
2. Slide the battery/SD Memory Card cover in the direction of the [OPEN] arrow.
3. Insert an SD Memory Card :
The front side of the memory card (printed
arrow) should face towards the front side
of the camera.
If the card cannot be inserted, check the
orientation.
4. Close the battery/SD Memory Card cover.
To remove the SD Memory Card, make sure
the camera is off. Open the battery/SD Memory Card card cover. Press
lightly on the edge of the memory card and it will eject.
Note:
If the camera is powered-on without the card, the "NO CARD" message appears on
the LCD monitor.
To prevent valuable data from being accidentally
erased from an SD Memory Card you can slide the
write-protected tab (on the side of the SD Memory
Card) to "LOCK".
To save, edit or erase data on an SD Memory Card,
you must unlock the card.
MultiMedia Card (MMC) can not be used.
You need to format an SD Memory Card before using it in this camera
Feb 19, 2015 | Gateway DC-T50 Digital Camera
Camera wont turn on but when i take off thelens it turns on
Does the empty battery symbol flash in the top cover LCD when the lens is on? If so, then you may have to replace the bottom board. Pull the bottom cover and see if there are any empty screw holes in the bottom circuit board. As the bottom board contains the lens circuitry and also the flash circuitry, then a loose screw can short out parts of the board when it is also touching on of the flash 300 volt traces. Common problem on the 7D.
Sep 21, 2013 | Canon EOS 7D Digital Camera
How To Remove Battery
Is very simple: you must slip the cover, and then push inside and get the batteries.Clean the contacts batteries.
Gob bless you
May 11, 2012 | Praktica DC Slim 520 Digital Camera
Nokia n70 back camera not working
Go to Nokia Care.and see manual of your hand set
Jan 14, 2011 | Nokia N70 Cellular Phone
Just replaced my batteries and the green light flashed my lens would not come out i held down the power button then thelens came out now the screen wont come up and my camera is off and the lens is out
I have this same camera and had this problem once. Turns out the batteries I used were duds. Try changing out the batteries. I would suggest lithium or rechargeable batteries.
Nov 28, 2010 | Polaroid i733LP Digital Camera
My l200 camara lens is stuck
huSh now :( I remember my former camera.. XD
Lens errors are fairly common. Usually it's sand or grit interferingwith the lens extension mechanism. Or the camera's been dropped withthe lens extended. Or the camera has been powered on, but the lens hadbeen blocked preventing its extension. Or the battery ran down with thelens extended ...
Here's some things that you can do to try to correct it. They only seemto work for less than 50% of the lens errors, but if the camera is outof warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12...
hope this will help ya out
Jun 06, 2009 | Samsung L200 Digital Camera
Sony Cyber-Shot DSC-P72
It could be that the battery isn't holding a charge anymore if you are using rechargeable batteries in you camera. Most of them have a short life to them. If you can get a hold of another one, see if that solves that problem.
Aug 28, 2008 | Sony Cyber-Shot DSC-S40 Digital Camera
Praktica dc slim 315
how can i delete photos from my praktica dc slim 315 ive lost instruction book thank you
Aug 13, 2008 | Praktica SlimPix Digital Camera
Praktica DC Slim 520 Digital Camera Logo
70 people viewed this question
Top Praktica Cameras Experts
Are you a Praktica Camera Expert? Answer questions, earn points and help others
