Question about Maytag 24" Built-In Single Gas Wall Oven - Stainless-Steel
F3 and f5 error codes on maytag gas wall oven
We have a gas wall oven that is getting f3 and f5 error codes. the unit still works we just have to push the cncel button and turn the oven back on again. we cooked ribs for 1.5 hours and the f3 code came up 3 times.
  • 6,784 Answers
(((F-3)))
This is a Shorted or open oven temperature sensor (RTD). Check the following.
Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
(((F-5)))
This is a Watchdog and hardware conflict.
This is not repairable. you will need to replace the control board or (erc)-(clock)
Posted on Jul 31, 2009
GodBlessU
  • 3513 Answers
SOURCE: My GE oven gives error code of F3 and F5
Thank you for contacting Fixya.
It's possible it could be the senser, just two screws hold it on and the wires unplug with a connector.
As to understand it in details whether the sesor is the bad part you can use a ohm meter to test the sensor, it should read about 1100 ohms at room temperature, if so, then your oven sensor is good.
You can get a cheap ohm meter at Radio Shack or any hardware store. If your oven sensor tests good, then your control board would need to be replaced.
That would help to resolve the issue.
God Bless.
Posted on Jul 13, 2009
SOURCE: kenmore wall oven keeps showing error codes f5 and f3
oven went into E2 F3 oven code while cooking a chicken and broil burner came on turned off oven but broil burner stayed lit, then had to unplug
Posted on Jan 12, 2010
  • 1314 Answers
SOURCE: F3 and F5 signals
could be a probe thats that brass looking rod you see when you open the oven f3 is oven probe code it controls the temp some of them you can take the two screws out on the in side and pull the probe out far enough to get to the connector to change some you have to pull the oven
Posted on Dec 29, 2007
localwonder
  • 6784 Answers
SOURCE: we have a gas maytag gas wall oven that is getting
F3
F5
Replace clock (ERC).
Posted on Jul 18, 2009
blueextc3221
  • 15935 Answers
SOURCE: Kenmore oven showing an F3 and later F5
All F3-E Codes - Oven Temperature Sensor (RTD) or Warming Drawer Defect - Replace oven temperature sensor (RTD).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 26, 2010
F3 and F5 errors when first trying to start oven or in the middle of cooking will also get them Mostly F3
F3 or F4 Shorted or open oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok. F5 Watchdog and hardware conflict Replace clock (ERC).
Aug 12, 2010 | Maytag CWG3100A Gas Single Oven
Tip
Whirlpool oven, stove and range fault codes (ERC and EOC display errors).
Here a list of Whirpool oven fault codes. The codes had been collected from different service manuals. This was a memo that I wrote for my own use. I think this can be useful to owners and technicians.
WHIRLPOOL - most models
Range/Stove and Oven Fault Codes, Common error codes.
F1 - Analog control board Failure
Disconnect for one minute - if error comes back, replace control board
F1 - Shorted control keypad
Replace keypad
F3 - Oven temperature sensor open
Replace oven temperature probe
F2 - Oven temperature sensor shorted
F3 - Oven too hot
F3 - Clean temperature too hot
Replace oven probe
F5 - Door latch switch fault
Test and replace the door switch.
Whirlpool with 4 Digit Failure Code:
F1 - E1 - Electronic control (flip flop)
Replace control board
F2 - E0 - Shorted control keypad
Replace keypad
F3 - E0 - Oven temperature probe open
Replace temperature probe
F3 - E1 - Oven temperature probe shorted
F3 - E2 - Oven temp too high
F3 - E3 - Clean temp too hot
Replace temp. probe
F5 - E0 - Check door latch
F5 - E1 - Check door latch
Replace switch if defective
WHIRLPOOL Polara models 5 digit codes:
F1 F0 - EEPROM communication error
Replace ERC
F1 E1 - EEPROM checksum error
Replace ERC
F1 E2:7 - UL A/D errors
Replace ERC
F1 E4:2 - Model ID error
Reinsert keytail.
F1 E6:0 - Latch signal mismatch error
Replace ERC
F2 E0:4 - Shorted key error
Replace keypad assembly
F2 E1:3 Keytail unplugged
reinsert the keytail
F3 E0:5 Top oven sensor open
Test and replace top probe.
F3 E1:6 Top oven shorted
Test and replace temp probe
F3 E2:9 Bake range over temperature
F3 E3:8 Clean range over temperature
Test and replace temp probe.
F3 E4:10 Bottom oven sensor open
F3 E:15 Bottom oven sensor shorted
F5 E0:14 Door switch errot
Test and eventually replace door lock switch
F5 E1:16 Door latch not operating
Test and eventually replace door latch
F8 E0:17 Refrigeration error
Test the cooling module.
PF Power failure - Does not indicate a fault.
PF occurs when power is disconnected.
WHIRLPOOL
Models SF3, 30'' and 24"
F2 - Oven temperature above specifications
Check 8-pin connector from temp. probe to Electronic Oven Control
F3 - Open oven temperature probe failure
Check wiring, replace oven probe if necessary
F4 - Shorted oven temperature sensor failure
Check wiring harness, replace oven temperature probe if necessary
F5 - Push button stuck or faulty
Check for binding of pushbuttons and control panel glass. If OK, replace touch panel
F6 - Electronic control logic error (timing)
Replace Electronic Range Control (ERC)
F7 - Electronic control logic error (lock motor)
Replace ERC.
F8 - Electronic control logic error
Replace ERC.
on Jan 31, 2010 | Whirlpool RBS305PDS Electric Single Oven
Maytag 24 " wall oven gas trouble code F5
Hi ngwhite,
The trouble code F5 is a Watchdog and hardware conflict. You need to replace the clock (ERC).
Hope it helps.
Thank you for using FixYa.
Aug 02, 2010 | Maytag 24" Built-In Single Gas Wall Oven -...
Kitchen aid wall oven Model YKEBS2780B1 SHOWS
Hello,4 Digit Failure Code F0 - E0 Analog to Digital Failure Disconnect for 30 seconds - if display re-appears - replace control F1 - E1 Safety flip flop Replace Electronic Range Control/Clock(ERC) F2 - E0 Shorted keypad Replace Electronic Range Control/Clock(ERC) F3 - E0 Oven temperature sensor or oven temperature sensor fuse opened Replace oven temperature sensor or fuse F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace component 2 Digit Failure Code F0 or F1 or F5 Failed transistor Replace Electronic Range Control/Clock(ERC) F2 - E0 Oven temp too high 1. Test operation of door lock on self-clean models
2. Test relay contact operation
3. High resistance in oven temperature sensor F3
Thanks
May 26, 2010 | Ovens
Error code F3 and F5
Hello there:
Here is the code for these 2 codes hope they are very helpful for you
F3
Open or shorted oven temperature sensor Replace oven temperature sensor F5 Hardware and watchdog circuits disagree Replace clock assembly (also called the ERC)
Feb 04, 2010 | Maytag CWG3100A Gas Single Oven
My maytag oven has a function error. F5 and F3
Hi sorianocynth,
Maytag error F5 and F3 do have different indications. Error F5 means watchdog and hardware conflict. The only way to resolve this is to replace clock (ERC). On the other hnd, F3 means you have shorted or open oven temperature sensor (RTD). Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
For replacement part you may contact Sears at 1-800-252-1698; M-F 6:30 AM-10:30 PM - Sat 7:00 AM-9:30 PM - Sun 7:30 AM-9:30 PM - All times Central. When they send out the part detailed instruction will be provided.
Hope this helps.
Jan 19, 2010 | Maytag 30 in. Electric Single Wall Oven...
The oven isn't working and it says FO in red letters
GE / Hotpoint / RCA
Oven Fault Codes
Display Condition Remedy
F0 & F1 Failed Thermistor Control Replace ERC
F2 Oven Temp Exceeds 590 with unlocked door High resistance in Sensor, likely a bad sensor
F3 Open Sensor circuit Open (blown) sensor fuse or bad Sensor
F4 Shorted wire or Sensor locate short and correct it
F7-A Function pad button stuck Clean and unstick
F7-B Bad Clock Replace Clock
F8 Electrical component failure Replace ERC
F9 Program with door circuit Check wiring
Frigidaire / Westinghouse / Tappan / Gibson
Oven Fault Codes
F0 & F1 EOC failure Replace EOC
F2 Oven over heat Defective Sensor or EOC
F3 Oven Sensor Open Replace Sensor
F5 EOC failure Replace EOC
F6 EOC failure Replace EOC
F7 EOC failure Replace EOC
Maytag / MAYCOR / Magic Chef / Jennair / Admiral
Oven Fault Codes
F0 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F1 Defective Touch Pad or Membrane Replace Touch Pad or Membrane
F2 Oven over heat defective Relay Board or (if present) or defective Sensor
F4 Shorted wire or Sensor locate short and correct it or replace Sensor
F5 Hardware, safety circuits disagree Replace Clock
F6 Missing AC (power) signal Check for proper voltage (plug, breaker, etc.)
F7 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F8 A/D Warning Replace Clock
F9 Door Lock Warning Check door lock circuit or Replace Clock
Amana / Caloric
Oven Fault Codes
Type with display - glass link ERC
F0 No Safety Signal Replace adapter board
F1 No Safety Signal Replace ERC
F2 Oven over heat Replace defective Sensor
F7 Shorted Touch Panel Replace Glass Panel
F9 Door Latch Error Check latch
FF Lock Error Check switch and motor
ERC III - Relay board with separate board/push buttons
F0 Shorted Push Pad Replace Push Pad
F1 Defective ERC Replace ERC
F3 Oven Sensor Open Check/Replace Sensor
F5 Defective ERC Replace ERC
F6 Defective ERC Replace ERC
F7 Shorted or sticking button Clean button or replace touch pad
F8 Defective ERC Replace ERC
The following diagnostic chart Does not apply to Whirlpool 'Y' line products. If the model number contains a Y near the end of the number, DO NOT use this chart.
Whirlpool / KitchenAid / Roper
Oven Fault Codes
Ovens with 4 digit displays
F0-E0 Analog to Digital failure Disconnect panel for 30 seconds. if error re-appears then replace control
F1-E1 Defective ERC Replace ERC
F2-E0 Shorted Keypad Replace Keypad
F3-E0 Sensor or Sensor Fuse Open Replace Sensor or Fuse
F3-E1 Shorted wire or Sensor locate short and correct it or replace Sensor
F3-E2 Oven over heat Replace Sensor
F3-E3 Cleaning Temp over heat Replace Sensor
F5-E0 Door Error Check Door
F5-E1 Door Latch Check Latch
F5-E2 Door Switch Check Switch
Ovens with 2 Digit Displays
F0 Defective ERC Replace ERC
F6 Problem with time keeping circuit Reset Time or cooking operation and check for proper ground
F7 Shorted or sticking button Clean button or replace ERC
F9 Door Latch Error Check latch and latch circuit
Dec 18, 2009 | Ovens
Kenmore wall oven keeps showing error codes f5 and f3. Unit will not say on.
Nov 13, 2009 | Kenmore 47702 / 47704 / 47709 Electric...
We have a gas maytag gas wall oven that is getting f3 and f5 error codes
F3
F5
Jul 17, 2009 | Maytag 24" Built-In Single Gas Wall Oven -...
F3 and F5 errors that shut off oven
F3 *Open Temperature Sensor Controller not receiving data from temperature sensor.
F5 *Control Output Disabled No control output.
Sorry you will have to replace oven sensor and oven control...
May 22, 2008 | Maytag CWG3100A Gas Single Oven
Maytag 24" Built-In Single Gas Wall Oven - Stainless-Steel Logo
4,820 people viewed this question
Top Maytag Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Mack Baxter
Are you a Maytag Oven Expert? Answer questions, earn points and help others
