Question about IBM ThinkPad 600E 2645 Notebook
600E model it show is ererr on the screen an after some time 173
There is some box in as selact the item how and hdd comw these message is after selact some colors sreen comes updated atomatically still 15 minet the scaning the memory and hdd disk and othere partd but there is
Shows an error 173
Error 173 is an upper heater temperature. It usually points to the fuser unit
Power the printer off, make sure the printer is plugged directly into the wall outlet not a surge protector also remove the fuser unit and reseat. If the error 173 message continues, the fuser unit will need to be replaced.
Apr 12, 2016 | OKI B4600 Printer
How to remove ask for genuine microsoft software
1. Restart your com­puter, hit F8 before win­dows load­ing screen to go into the safe mode menu.2. Select Safe mode (not with net­work­ing, and not with com­mand prompt)
3. Once your in win­dows, goto START>RUN> type "regedit" (with­out the qou­ta­tion marks) and hit ENTER.
4. Goto EDIT, select FIND
5. Search for wgatray.exe, delete any ref­er­ence found, (after it finds it the ini­tial first time, just hit F3 to con­tinue the search. Con­tinue to delete any­thing it stops on.
6. Scroll all the way back up inthe reg­istry edi­tor, and select My Com­puter (one click. not two) and start a new FIND, this time were look­ing for Wga­l­o­gon, again, delete any ref­er­ences found.
7. Lastly, again, click on My com­puter, and start a new FIND, search­ing for LegitCheckControl.dll , again delete any ref­er­ences found.
8. Reboot and your fin­ished, if not, you may have missed a reg­istry entry.
BTW you should be able to con­tinue to down­load Win­dows update (when set to auto­mat­i­cally down­load an install).
Aug 20, 2011 | Microsoft Windows XP Professional for PC
Error 163 173 ibm 600e laptop when turned on these errors occur
this error is the battery by the sound of things, you need to replace the cmos battery , then enter the configuation utlity and set date and time, hope this helps
Nov 29, 2009 | IBM ThinkPad 600E 2645 Notebook
How do i set up the channels in order bbc 1 bbc2 etc to match the buttons on the remote 1 2 3 ect its a LG 42 INCH TV
selact menu on remot cantrol and see on the screen tunig menu in chenal edit to selact .
frist selact ch for edit and set your chennal no 1 /2 or 3......after the selact no prees OK key to fix your fureat ch. in your selacting no.
EXP:
ch . pisesion 36 [BBC1]
edit ch No 1
then prees OK key and see your BBC! is ch no 1 on your remot.
Oct 30, 2009 | LG 42LC2D 42 in. LCD HDTV
Hand-me-down IBM Thinkpad 600E 2645 has blinking LCD video XP O/S
This sounds to me like either your flourescent lighting tube is beginning to go bad ,,, or the inverter is going bad ... or even both. :-)
The cheapest and easiest solution for you is to simply replace the LCD screen (replacing the inverter or the tube are actually a bit cheaper, but not quite as easy to do - most computer repair centers will try to talk you into a new screen anyway). This is actually very simple for either you or someone you know who is an avid "do-it-yourselfer". IBM makes ity very easy. You will find easy, detailed instructions in the ThinkPad 600/600E (2645) Hardware Maintenance Manual, IBM S10L-9619-03 June 1999 available for FREE downloading in .pdf format on IBMs website. Follow this link to some really sweet deals on LCD screens for your 600e on eBay for under $35.00. http://shop.ebay.com/items/?_nkw=ibm+thinkpad+600e+lcd+screen&_sacat=0&_trksid=p3286.m270.l1313&_sop=12&_dmpt=Vintage_Electronics_R2&_odkw=IBM+tube&_osacat=0
Remember you can always connect an external monitor to your ThinkPad until your new screen arrives if you have one. The manual should also give you instructions to change out the tube if you wish to save a few more bucks and try that route. Hope this will FIX-YA! Please leave your feedback and let me know!
Jul 27, 2009 | IBM Computers & Internet
Screen
Probably the display driver is messed up. Best option is to reinstall the operating system.
An alternative is to have a Linux-savvy friend try to boot it up
with a Linux-live rescue CD to see if that fixes the display problem and maybe to salvage your personal data from the hard drive.
Feb 14, 2009 | IBM ThinkPad 600E 2645 Notebook
How do I put new windows on the thinkpad I have got the cd
this is sometimes due to the boot sequence. identify the key to press so that you can access its bios at start up. a shot message is usually displayed for a short time at start up.
please go to the bios and change the boot sequence to start from HDD.
Dec 18, 2008 | IBM ThinkPad 600E 2645 Notebook
IBM ThinkPad 600E 2645 PC
the following data is from the hardware maintenance manual for the thinkpad 600 series and is readily available from http://www.lenovo.com/support
Symptom or error FRU or action, in
sequence
161
Dead battery.
1. Go to “Checking the
backup battery” on
page 12.
2. Backup battery.
3. System board.
163
Time and date were not set.
1. Set time and date.
2. System board.
173
Configuration data was lost.
1. Select OK in the error
screen; then set the
time and date.
2. Backup battery.
3. System board.
192
Fan error.
1. Go to “Testing the
computer” on
page 7.
2. Measure the voltage of
the backup battery. If
the voltage is not
correct, replace the
backup battery.
3. Fan.
4. System board.
Oct 03, 2008 | IBM ThinkPad 600E 2645 Notebook
Black box on top of screen during HDD playback mode
Problem solved! Thanks Panasonic Tech Support!!
In case anyone else has this problem, I'll tell you what I found out. This model DVD recorder does not have closed captioning functionality at all. So if this happens to yours, it is not the DVD recorder causing the problem. It is a setting on either your TV, cable box, or whatever else you have hooked up to it.
In my case, my daughter must have accidentally hit the "Text" option on our TV's caption menu. I changed that option back to its original setting, and the mysterious black box is gone.
Jul 29, 2008 | Panasonic DMR-EH50 DVD Recorder
Open Questions:
ibm thinkpad does not boot My IBM Thinkpad 600 (Type 2645-310) stops and hang during bootup. What happens is: 1. LED test, then green Power on and orange battery/charging 3. RAM OK (Responds when I take out /put in different amount of RAM and displays correctly. I have 128 + 32 removable, + 32 internal not possible to take out) 2. I can hear fan, CD drive and evt diskette drive. If I use diskette drive the LED wil give 1 blink, if I use CD drive it will give 14 blink. 3. No cursor seen, but this is displayed: Upper left show the amount of RAM present: 196032 KB OK Upper right IBMs logo in blue; IBM Lower left shows "ThinkPad(R)" in large letters and red dot over "i". 4. Then a "rrrrrr" sound from the loudspeakers after a while, this is in fact 28 clicks shortly after each other. Then nothing more happens. Diskette and CD drive is OK (But can not be used because bootup is never finished). I hear CD speed up and then down again but nothing more happens. No effect in booting with bootable diskette or CD, "Live Linux" CD or else. Backup battery OK (3V) and if I take it out I will be asked for correct date and time when Power on. I can then use keyboard or TrackPoint to set date and time, and after that hangup at the usual point. Starting without battery, HDD, CD drive and removable memory sticks makes no difference in symptoms. Pressing and holding F1 before and during poweron and startup (in order to enter BIOS and selftest) has no effect. I could not find help on IBMs home page, but maybe I did not look at the right place. Is somebody able to help me?
Feb 28, 2017 | IBM ThinkPad 600E 2645 Notebook
See all IBM ThinkPad 600E 2645 Notebook Questions
IBM ThinkPad 600E 2645 Notebook Logo
52 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
