Question about Biostar M6VCG Motherboard
I am rebooting my system i dont the what its problem i am using biostar motherboard with intel celeron processor. Would upgrating bios will solve this problem if solves pls give a link of bios upgrate with free download
  • Anonymous Mar 01, 2009
    when i am installing xp2 it is not installing it is showing an error message disaldle the newly installed drivers and the disable the memory such as cacheing shadowing
    and it is also showing wrong info of hard disk my hard disk is of 40 gb but when xp installation is started it is showing only 6 GB and the showing message that installing may not be continue
    i am having and sysytem reboot problem what is these problemi am not understanding i have changed my old ram also i buyed a new ibm ram but more it is rebooting
    i am also exchanged the hard disk and also sawed but still the problem then i am thinking that it may the mother board problem or process problem.
    then how to solv ethis problems
  • Wayne Mineard
    Wayne Mineard May 11, 2010
    What exaactly is it doing?
    Error messages? Beeps?
    Comment back.
    President:
  • 1,223 Answers
What is ur problem tell me in detail there is no need to attempt the bios update it is a risky thing to do
pls clarify ur problem for help
Posted on Feb 24, 2009
I would like to know what type of motherboard does the intel celeron d 2.53 has?
the motherboard needs to have a socket 478 which supports Prescott rocessors and to support an FSB of 533MHz (4 x 133). There are many eg
biostar P4M80M4
and see
Intel Celeron 325 Compatible Motherboards
9.July.2015
Mar 14, 2014 | Intel Celeron D, 2.53 GHz (bx80547re2533c)...
WHAT IS MAX CPU SUPORT OF P4M800-M7A ( above 2.6GH )
Select the "Start Menu."
Click to select "Control Panel." This will open a new window with several clickable options.
Choose "System and Maintenance," typically located near the top left-hand corner of the Control Panel
Click to select "System" from the new list of options
Look for the CPU's stock speed as indicated under the "Processor" heading. This is a ballpark, relatively close estimate of your computer's CPU speed, as provided by the manufacturer.
Checking the Stock CPU Speed in Windows XP
Click the "Start Menu.
Right-click on "My Computer."
Select "Properties." By default the Properties window will usually be set to the "General" tab, but if the window is set to a different tab you'll need to click on the "General" tab located near the top of the window.
Check the CPU rating as listed underneath the "Computer" heading.
Determining Real-Time CPU Speed
Go to CPU Speed Professional's website (see Resources) and download "CPU Speed Professional."
While other free CPU clocks exist, many are beta programs with glitches and unwanted bugs. CPU Speed Professional is well-known and reputable, receiving the "Vista 5 Star Software Award" according to its website.
Install the recently downloaded
" http://download.cnet.com/cpu-speed-professional/3000-2086_4-10833139.html "
file by double-clicking on it and following on-screen prompts to complete the automated install procedure.
Open CPU Speed Professional.
Click "Test Your Speed" on the main program interface.
A real-time, active measurement of your CPU speed will appear numerically, and CPU Speed Professional will also display your CPU speed on a stylish meter for easy visual comprehension.
hope this helps
Oct 10, 2012 | Biostar P4M800-M7A Motherboard
What is a version of Biostar G31d-M7
Socket LGA 775
Supports Intel Core 2 Duo/Pentium Dual-Core/Celeron Dual-Core/Celeron 400 Series Processor
Supports FSB 800/1066/1333MHz
Support Intel Hyper-Threading Technology
FSB 533MHz is not supported by this motherboard. CPU TDP over 65W is not available. Please refer to CPU support for further information.
hope this helps
Mar 02, 2011 | Biostar G31D-M7 Motherboard
InteL D845GVSR MOTHERBOARD uses then system very slow
change your celeron processor into intel processor and upgrade your ram upto 1 gb.
it develops your speed, because i am user of same moterboard. by upgrating my pc it gives nice speed.
Feb 04, 2011 | Computers & Internet
ASUS CUSI-M ACPI BIOS Revision 1007 run very slow when i wana use 1024 by 768 pixel.how i can solve this problem.my processor speed is 700 MHz. 2.is it possible AMD 1.3 processor connect with this...
Getting you're system to display 1024 x 768 resolution depends on the graphics card. If you’re using the onboard VGA you will have poor display.
Suggest you use a PCI (White slot) graphics card with its own memory onboard. You will also need to make a bios setting change so the system boots to the PCI card and not the VGA.
Asus no longer provides support for this MB including drivers and bios.
You're board also supports slot A (For AMD), processors.
Only Intel Celeron and Intel Pentium III. Socket 370
see link provided;
http://www.cpu-upgrade.com/mb-ASUS/CUSI-M.html
Max CPU supported (With out over clocking);
http://www.cpu-world.com/CPUs/Celeron/Intel-Celeron%201100%20-%20RB80526RY005128%20(BX80526F1100128).html
In order to run this CPU you would need to update the bios to rev 1009. You'll find rev 1009 at the next link; http://www.userdrivers.com/BIOS/Asus-CUSI-M-BIOS-1009-With-LAN/
From what I've read it is possible to Get an AMD slot A CPU into a socket 370 MB. (Don't hold me to this though. This is a first for an old dog.
Any one of these PCI graphics cards should function on you're MB; http://www.tigerdirect.com/applications/Category/guidedSearch.asp?CatId=28&sel=Detail;55_158_2872_2872
Hope you find this helpful
Mike
Jun 04, 2010 | ASUS SiS Chipset CUSI-FX Motherboard
F672cr(m1610)and intel core duo?
The Acer M1610 was available with the following processors: Intel Core 2 Duo, Intel Pentium Dual-Core, Intel Pentium D/4, Intel Celeron D/4 2.0GHz.
Based on this information, It is likely that you can support a Core Duo or a Core 2 Duo, however may be limited to the 2.0GHz models due to clock and multiplier limitations on the BIOS. This may be different if there is BIOS upgrades to support faster processors.
Your best option of the above listed processors will be the Core 2 Duo, however their system specifications report that only the Core 2 with 800MHz or less Front Side Bus are supported.
Also note that the Celeron 430 is a 64bit processor, so it is not likely to work on this system either.
Sep 05, 2009 | Acer Computers & Internet
I have lost the manual to my biostar M6TWC motherboard and was just wondering what is the highest processor i can put in it as its running on a intel celeron at the moment many thanks daniel
Here is a link to Biostar USA and the user manual is in a PDF for you to donwload.
http://www.biostar-usa.com/mbdownloads.asp?model=m6twc
I hope that I have provided the correct information that will assist you in the resolution of this issue. If you have any questions, please post back with a comment to this thread.
If I have helped you with your question and/or solved the problem, please take just a moment to rate this post. Thank you!
May 09, 2009 | Computers & Internet
Cannot use intel pentium processor
you can only use socket 370 (Intel Celeron/Intel Pentium III) processors on that motherboard. Your maximum cpu speed is set by the bios.
Feb 19, 2009 | Gateway PGA370 E139761 DIMM Motherboard...
Not optimal clock speed
Problem most likely is in bios. Hit the Del key when rebooting to enter bios setup. Check the settings there for the cpu. Asus has an automatic setting for overclocking for this board. Make sure it is set to auto. Save then reboot. Hope this helps.
Dec 16, 2008 | Biostar motherboard I945GZ-M775 Socket 775...
Does it support intel & amd?
Hi aventae, the P4SXQ motherboard will only support Intel Pentium 4 or Intel Celeron processors 400MHz CPU's.
Biostar's link for the P4SXQ MB.
http://www.biostar-usa.com/mbdetails.asp?model=P4SXQ
Mike
Jul 28, 2008 | Biostar P4SXQ Motherboard
Biostar M6VCG Motherboard Logo
Top Biostar Computers & Internet Experts
Jayburt
David
David
Jerry Umali
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
