Need help setting the alarm
Anytime you lock the door with the key fob or press the drivers door lock the alarm is on. if someone opens the door without the key the alarm will sound. test it by locking the door with the remote with the window down then after a min open door with the inside door handle by reaching in through window
SOURCE: Alarm activated everytime I use the key to open the door.
very common issue with the vigor, it`s the power door actuator or something...there are 2 ways to fix it:
- the harder way (unless you`re half-decent at DIY car stuff, which I`m not), all you really are doing is cleaning the contacts..a detailed guide is here
http://www.acuravigorclub.com/Timely-Topics/Timely1202.htm
- OR the easy way is to just trick your car into thinking the hood is open so the alarm will never arm itself. Taken from another post:
You can effectively permanently disable the alarm (who actually bothers to respond when they hear a car alarm anyways?) by opening up the hood and finding the little switch that detects whether the hood is closed. Just bend this so that the alarm system always thinks the hood is open and the alarm system will never arm even if you lock the doors.
SOURCE: 1994 acura vigor has abs and brakes lights on while driving?
Check for brake fluids and make sure all the brake fluid container is closed tightly. Also, you make have to bleed the brakes.
SOURCE: Need the anti-theft code for stereo system in a 1992 Acura Vigor
The only place to get this code is from the dealership. They will enter the code as it maybe different for each car. This happens when the battery has been changed without the backup power supply. As you may have guessed this is to keep would be thieves from reselling your radio.
The front brake rotors are press fitted to the front wheel bearings and are removed from the car with a special tool (puller) or can be seperated by removing the whole assembly and placing it in a press to seperate them. You may damage the bearing if not done right.
SOURCE: car wont start after the alarm is disabled
is the alarm factory or after market need to know. very important..
