Question about HP Pavilion dv6000z Notebook
Lan card not working
Sir i have second lan card connected and it is not working wen i connect net wire
  • Chris Hingee
    Chris Hingee May 11, 2010
    Have you installed the driver for the 2nd LAN card?
    Is the 1st LAN card and 2nd LAN card the same make and model?
    Run CMD and type ipconfig and give me the details of the network device setting/information as displayed.
  • 46 Answers
See if the lan card is disabled or if proper drivers are loaded and it has accepted it .
Posted on Feb 24, 2009
Sir I have vectron m 54 se laptop i lost wireless net work drivers please guide me from where i can download all this drive
connect to net with lan cable search net for Clevo MOBINOTE M540V or vectron m 54 se drivers download them then install each manually ,download most recent drivers for wireless network .otherwise get a copy of a program like drivereasy and get it to find them for you.other method got to device manager uninstall/remove device network card it will have yellow flag to say no driver /not installed in device manager . switch off laptop and let it restart and it should find driver when it re installs network card.
Aug 09, 2014 | Clevo MOBINOTE M540V LAPTOP LCD SCREEN...
I installed new XP on my comp. and cant get to the internet ... shows that there is connection but cant get in .... and internet explorer say what you can try ... Diagnose Connection Problem ... then it...
hi! I think u need to install drivers in your PCI internet/LAN Card or built-in LAN
Please check the brand of Motherboard if it is built-in or the PCI Card Brand. and browse it in the net with another PC with the NET connection, to the manufacturer websites. and search it with corresponding model of the motherboard or the PCI Card. and download the Driver's and save to USB and paste it to ur PC and install it.
if this tips is helpful. please rate it. thank you.
Feb 21, 2011 | Computers & Internet
Sir i lost my motherboard cd which is mercury board and by downloading of soundvgalan which are not installed in the system i used correct drivers but lan drivers are not installed because i have net...
first of all, internet does't require lan driver...... it is inbuilt in most of the operating systems..... if your lan is realtek rtl8139ethernet nic, you can download it from http://www.realtek.com/ under quick links in the right
okay???????? pls vote if you like this solution.......
Jun 26, 2010 | Biostar M7VIZ Motherboard
I am trying to setup a internet connection using yahoo what do i do
Sir,only using yahoo connection it will not provide to setup internet connection.
For internet connection you have to configure all the component which provides you to connect with internet.
These configuration requires LAN card,LAN driver,modem,NIC card,phone and internet service provider to assist the internet to activate the internet.
Apr 12, 2010 | Computers & Internet
One static IP has internet. how on a LAN?
You need two network adopters in your system.
Connect Internet connection in first Network card and from the other network card give it to your Switch or hub
If you are using XP system you can use Internet connection sharing to share the internet in your LAN systems.
Follow the steps to enable using ICS
1.Enable Internet Connection sharing in the LAN properties in the first network card.
2.Now your second network card automatically get an IP address in the range of 192.168.*.* series
3.Connect other systems in the LAN and make sure the system has selected Optain IP atomatically from DHCP.
You are all set.
There is also an advanced way to setup this .
Install IPCOP firewall in a system with two network cards and u can share the internet with the firewall settings
Aug 28, 2009 | Computers & Internet
ONE LAN CONNETION AND THREE COMPUTER
Sure you can
In fact the wireless router is your best bet for multiple systems to connect to the net.
As per crossover wiring you can interlace the computers via using their USB ports.
Jul 27, 2009 | NAD L40 CD Player
Onboard LAN detected , drivers properly installed but not responding
The Problem is in your onboard LAN, get PCI LAN card, plug into your PCI slot, install the driver of that PCI LAN Card..
Apr 27, 2009 | Computers & Internet
D-link cant accesed internet 4pc
Most of DSL modems are connected to PC with USB cable...
n if ur server is connected with other pc on lan .. you can use internet sharing option available in winxp.
Following are the steps to enable Internetsharing for other pcs.
How to use Internet Connection Sharing loadTOCNode(2, 'summary'); To use Internet Connection Sharing to share your Internet connection, the host computer must have one network adapter that is configured to connect to the internal network, and one network adapter or modem that is configured to connect to the Internet.
On the host computer loadTOCNode(3, 'summary'); On the host computer, follow these steps to share the Internet connection:
  1. Log on to the host computer as Administrator or as Owner.
  2. Click Start, and then click Control Panel.
  3. Click Network and Internet Connections.
  4. Click Network Connections.
  5. Right-click the connection that you use to connect to the Internet. For example, if you connect to the Internet by using a modem, right-click the connection that you want under Dial-up.
  6. Click Properties.
  7. Click the Advanced tab.
  8. Under Internet Connection Sharing, select the Allow other network users to connect through this computer's Internet connection check box.
  9. If you are sharing a dial-up Internet connection, select the Establish a dial-up connection whenever a computer on my network attempts to access the Internet check box if you want to permit your computer to automatically connect to the Internet.
  10. Click OK. You receive the following message: When Internet Connection Sharing is enabled, your LAN adapter will be set to use IP
    address 192.168.0.1. Your computer may lose connectivity with other computers on
    your network. If these other computers have static IP addresses, it is a good idea to set them
    to obtain their IP addresses automatically. Are you sure you want to enable Internet
    Connection Sharing?
  11. Click Yes.
The connection to the Internet is shared to other computers on the local area network (LAN). The network adapter that is connected to the LAN is configured with a static IP address of 192.168.0.1 and a subnet mask of 255.255.255.0
let me know if it helps.
best regards,
Nov 03, 2008 | D-Link DGS-1008D 8-Port Gigabit Ethernet...
Can,t connect to second computer getting a message network cable unplug.
is your computer connected to a network using a Local Area Network connection??
let me provide some solutions for windows XP users.....
first of check the LAN wire connected between two systems..
try to avoid any loose contacts. make sure the wire and jack are in good condition.. if the jack is loose please replace the wire or else tighten it using a crimping tool... also make sure that second system has a proper network device(ethernet card/Network Interface Card) and the corresponding drivers installed. if everything is correct bring both system into the same work group. then try to connect the second system
Sep 14, 2008 | Computers & Internet
Problem with net connection
please, i want to know how to solve this problem that my laptop is demanding for the updated driver for realtek adapter before i can be connected through wireless mode
Aug 30, 2008 | Zonet Fast Ethernet Adapter Realtek 8139D...
HP Pavilion dv6000z Notebook Logo
73 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
