Question about Bosch Classixx WFL 2066 Front Load Washer
I can't seem to get any power to my Bosch Maxx Classic washing machine yet it was working fine when I initially turned it on. I have tried using other points to no avail. Can anyone help?
  • Bosch Master
  • 19,396 Answers
If you are in UK, check the fuse inside the power cord.
If the power cord is not fused, then you need to replace the control board, or fix a wiring problem, since this machine does not have any fuse in control board.
If you need to call a technician you can use the phone number listed on the owner manual.
Posted on Feb 24, 2009
2 Suggested Answers
  • 250 Answers
SOURCE: Bosch maxx classic washing machine doesn't clean clothes
There are a lot of things to consider when trying to solve this problem. Obviously a front loader washes differently than a top loader. Top loaders tend to using a washing motion that is good for stains but wear out your clothes fast. Front loaders typically use less water and wash more gently, but in some ways still do better than top loaders. Anyway, think about any other variables that go into the laundry equation. Consider the distance the machine is from your water heater. This machine will use MUCH less water to fill than your old one, and, you know how when you turn a faucet on hot it takes a minute for the hot water to actually get there? It's the same way with your machine. If there's a sink next your washer, you should always turn on the hot water on the faucet until it gets hot right before you start the machine. The same goes for dishwashers. If there's not a sink close you can easily turn up the temperature for all hot water on your water heater, although that will use more energy.
Consider what detergent you're using. If you're using high efficiency detergent (like Tide he) maybe you should switch to your old brand. If you're using your old brand of detergent, try getting a high efficiency detergent.
Posted on Sep 20, 2009
How do I find clean the filter of our bosch maxx classic 900 rpn front loader? I cant even find the filter.
You don't. Washing machines don't have a handy accessible filter...
Check the owner's manual that came with the machine.
Feb 16, 2015 | Bosch Washing Machines
Bosch maxx 900 manual
It could be caused by a damaged heater element.. remove and check for damage. One way to check is to remove the two wires and tape up to prevent accidental short circuit. set machine to a cold wash if it does not trip you know what you have to replace. if it still trips then remove the motor and check carbons/ brushes for excessive wear. good luck..
May 10, 2014 | Washing Machines
My bosch washing machine Maxx classic wont turn on
Please check the main power from the power outlet the mains plug to the controller unit. If there is power then check within for the fuse, if fuse is intact then check for burnt items, if so the board could be damaged and needs a replacement. In most cases if the fuse has blown it is possible that the board has failed and so changing the damaged component could be difficult as the board is immersed in epoxy.
Sep 12, 2012 | Bosch Washing Machines
I have a Bosch Maxx Classic that leaks water that seems to be coming from the Solanoid/ Can anyone help with a fix.
Inspect back side of solenoid for cracked hose or cracked plastic body. If those look okay, unscrew the hose connection and replace the flat seal. It is the same size as a garden hose fitting, and will accept one of those as a replacement until you can find one that is approved for washing machine use, or jsut replace the hose, which should be done every few years as a precaution against a burst hose.
Feb 19, 2012 | Bosch Washing Machines
Hi I have a Bosch WFL226 MAXX. The wash programmes seem to work OK - the motor operates the drum and the pump works fine and drains the machine. The water level vacuum switch seems ok (it stops it...
Bosch WFL226 MAXX This video will show you how to change the pump washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Dec 21, 2010 | Washing Machines
Sep 20, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Drum not turning despite belt ok and motor ok, lots of sediment from drainage pipe
check the pump/impeller for blockage.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 26, 2009 | Washing Machines
Bosch Classixx WFL 2066 Front Load Washer Logo
664 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
