Question about Minolta Office Equipment & Supplies
SAGEM MF 5461 HSYNC printer error and Fuser Temp error
After the exchange of cards is hsync printer error.
What is the hsync or priner error ? In other machine there is a problem fuser temp, fusing unit has changed but machine does not work Thank you for your help... This machine is sale ,konicaminolta 1600f =SAGEM MF 5461
  • 51 Answers
SAGEM 5401 / 5461 “PRINTER ERROR FUSER TEMP”
According to SAGEM this fault is caused by an incorrect operation of the fuser unit – the
machine did not heat up in time.
Solution:
Follow the keystrokes set out below, do not worry about what is on the display unless
stated to check. All letters referred to are for the keys on the alpha key pad to the right of
the control panel, under the plastic flap.
For the 5461:
Press down arrow, *, #, ok, 1, ok, stop (red button),
Press down arrow, #, T.
The machine returns to the error code. Switch the machine off for 10 seconds, switch
back on. If successful the machine will warm up and come ready.
Press down arrow, *, #, 0 (ZERO), ok, stop.
For the 5401:
Press down arrow, *, #, ok, 1, ok, stop.
Press down arrow, #, look on the display, press up arrow until “T>>PRINTER” is
displayed. Press ok. The machine returns to the error code. Switch the machine off for 10
seconds, switch it back on. If successful the machine will warm up and come ready.
Press down arrow, *, #, ok, 0 (ZERO), ok, stop.
If this is a recurring problem the firmware on the board may need to be upgraded, or there
is a physical fault with the fuser unit. Low voltage / power surges in the supply power to
the machine may also play a part in the occurrence of the error.
The firmware needs to be version 1.10.
To check the firmware version do the following:
5461:
Press down arrow, *, W
Firmware version is displayed. Press stop to clear screen.
5401:
Press *
The trace lists will be printed, firmware version is after PRT, as in example below.
In this example, the printer firmware is: PRT V 1.5
It is older than V 1.10 and the printer firmware need to be upgraded.
The firmware can only be upgraded at Copy Type Electronics or at SAGEM in France.
Therefore the entire machine will have to be returned to us for the upgrade.
Posted on Apr 15, 2009
I am very greateful for the advise provided, this was very helpful.
Molefe - South Africa
Posted on Jan 04, 2010
Got a fusing error on sagem MF5461 .. have checked fuser lamp and thermal breaker and both are ok. Is there any other solution?
Posted on Mar 18, 2010
Printerhead error code 931.01
Please click on the link to see instructions on how to go about the procedure.
http://bit.ly/peHEBg
For further assistance, please call Lexmark Technical Support.
Jul 09, 2011 | Lexmark X342n All-In-One Laser Printer
Lsu hsync error cycle power
give back cover of the printer, which is located Fuser Fuser is carefully removed after it opened by pressing the two side screws to remove out.Se Fuser notice printed contacts are clean and in particular an electric tab located somewhere in that cloud right des.Reinstall Fuser ... success!
Apr 12, 2011 | Samsung ML-3051ND Laser Printer
LSU HSYNC ERROR
mensaje de error hsync en impresora ML-2550
Sep 19, 2010 | Samsung ML-3051ND Laser Printer
I have a Minolta QMS Print System 2650. When I turn it on, Im getting 'Fatal Error: HSYNC Detect Abnormal'. Im not sure what to do.
Hi Mine did this too and minolta said it was the fuser assembly but they wanted a few hundred for the repair, was cheaper to get a new laser, did you solve your issue yet?
Aug 25, 2010 | Konica Minolta Office Equipment & Supplies
Have lsu error also.
Hi ...
LSU stands for Laser Scanner Unit ... you normally get 2 different kind of errors with LSU ...
LSU Hsync or LSU Motor Error ...
If you get this error, it means that the Laser Scanner Unit has gone bad and the only way to get it fixed is to get the printer repaired ...
Cheers ....
Jul 28, 2009 | Samsung SCX-4100 All-In-One Laser Printer
Xerox 3100 mfp error code (HSYNC)
xerox phaser 3100 mfp error HSYNC
What can i do to solve ?
Nov 24, 2008 | Office Equipment & Supplies
Blank papers comes when the print given
D ear team, Blank papers comes when the print given. Meanwhile it shown the error msg is: LSU Hsync error cycle power pls give me the solution NHPC Ltd.
Feb 03, 2008 | Samsung ML-3051ND Laser Printer
3,850 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
