Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Windows cannot find "ssvichosst .exe" file at start up
Every time i log in to my computer there is always an error message that comes as above, how do i fix this.
    Problem Solver:
  • 12 Answers
Please mate if u have not find ssvihost.exe file please reinstall xp using updrade or using boot u can fix xp all...
Posted on Feb 24, 2009
Cant download skype, problem with toolbar, error 2738
Take a look in Event Viewer I looked in Event Viewer to find out what MSI-file that generated the error message and found:
Log Name: Application
Source: MsiInstaller
Date: 23.09.2010 21:58:26
Event ID: 1040
Description:
Beginning a Windows Installer transaction: C:\ProgramData\Skype\{D103C4BA-F905-437A-8049-DB24763BBE36}\SkypeToolbars.msi. Client Process Id: 6564.
2. Running MSIEXEC with logging options I started a "Command Promt" and used the command: "cd C:\ProgramData\Skype\{D103C4BA-F905-437A-8049-DB24763BBE36}" to navigate into the folder containing the MSI-file.
Now using the command: "msiexec /i SkypeToolbars.msi /lv log.txt" (msiexec options: /i = Install, /lv = Log + Verbose output).
After clicking away the error message I just wrote "log.txt" in my "Command Promt" to open the log-file. Near the bottom of the log-file I found this line:
DEBUG: Error 2738: Could not access VBScript runtime for custom action
3. DEBUG: Error 2738 After a quick search at Google I found out this error indicates that the VBScript engine is not registered on the computer.
The solution for a Windows Vista or Windows 7 32bit:
- Click Start -> All Programs -> Accessories
- Right click "Command Promt" and click on "Run as administrator"
- Write "cd %windir%\system32" and hit Enter
- Write "regsvr32.exe vbscript.dll" and hit Enter
- You should now get a message that says: "DllRegisterServer in vbscript.dll succeeded."
- Click "OK"
The solution for a Windows Vista or Windows 7 64bit:
- Write "cd %windir%\syswow64" and hit Enter
- Click "OK"
4. Try again... Now I tried once more to run "msiexec /i SkypeToolbars.msi /lv log.txt" (I kept the /lv log.txt option to look for changes if the installer would fail again).
If you still get the same Error than continue to step 5.
5. Cleanup registry first, then re-reg My installation still gave me the same error, so after some more searching and reading on Google I found a solution that explained what I tried before (with the regsvr32.exe) and also an alternative step if that one should fail. The alternative step was to remove the Registry Key pointing to vbscript.dll.
The alternative solution for a Windows Vista or Windows 7 32bit is then:
- Write "reg delete "HKCU\SOFTWARE\Classes\CLSID\{B54F3741-5B07-11CF-A4B0-00AA004A55E8}" /f" and hit Enter
- Click "OK"
The alternative solution for a Windows Vista or Windows 7 64bit:
- Write "reg delete "HKCU\SOFTWARE\Classes\Wow6432Node\CLSID\{B54F3741-5B07-11CF-A4B0-00AA004A55E8}" /f" and hit Enter
- Write "cd %windir%\ syswow64" and hit Enter
- Click "OK"
Now using the command "msiexec /i SkypeToolbars.msi /lv log.txt" the installer started perfectly, ran all the way thru and Finished.
Conclusion This message indicates that VBScript engine is not currently registered on the Computer running the installer.
Vbscript.dll must get registered to solve the problem.
Ref: http://community.spiceworks.com/how_to/show/1577
Apr 25, 2011 | Computers & Internet
Tip
Desktop Short Cut Missing
Hello,Some times your Desktop shortcuts or Start Menu Disappeared.It is happening due to Error Occurred in Explorer.exe. You can Clear this Error without Formatting.Just Do Following..
  1. Copy "explorer.exe" from other clean computer (from C:WINDOWS)
  2. And Paste it In your computer go to C:WINDOWS
  3. Show hidden files from (Tools - Folder Options - View - Show hidden files and folders)
  4. Delete existing 'explorer.exe' and any other files start with explorer...
  5. Put the new file (explorer.exe)
  6. Log off / Restart
  7. Log on
OR Just try this Solution.Close all your Opened Windows/Programs(OR Restart PC). Just Run this Dos File.It will Restore your Desktop Surely.. I/we need your valuable Feedback...Keep Using FixYa
Check this Link............. "Unable to Open Theme Corrupted" in Nokia 6300 Click here
on Apr 11, 2010 | Computers & Internet
I am getting error message for win32 generic host data executor prevention
Here is my resolution to the error
SVCHOST.EXE GENERIC HOST PROCESS OR
DEP ERROR
IT DOES NOT INCLUDE
DISABLING WIA
OR
DISABLING DEP (which is a good security feature)
I have tried it on upto 3-4 computers with success and complete software functionality
Turn the All in One Off
Uninstall the whole of the HP software on the computer
Run a level 4 uninstall
Start --> Run -->X:\Util\CCC\Uninstall L1.bat
Start --> Run -->X:\Util\CCC\Uninstall L2.bat
Start --> Run -->X:\Util\CCC\Uninstall L3.bat
Start --> Run -->X:\Util\CCC\Uninstall L4.bat
Restart the computer
Check the computer on the restart
Check if you still get an SVCHOST.EXE GENERIC HOST PROCESS OR
DEP ERROR on restart
Start --> Run
Type in Msconfig
Click OK
Click Launch System Restore
Run System Restore
Create a Restore Point named Hp
Click Start --> Run
Type in Regedit
Click OK
Open Registry Editor
Scroll to the following Registry Key
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentV
ersion\Explorer\
RemoteComputer\NameSpace\2227A280-3AEA-1069-A2DE-08002B30309D
Right click on this Key Click Export
On the Export Registry Window which comes up
Type Hpprinter as the filename and save it on the desktop
Get back to the same Registry Key
Right Click the Key and Click Delete to remove the key
THERE SHOULD BE NO DEP ERRORS THIS TIME
(IF you have any issues after deleting the above key <possibility is remote> restore the computer back to the Hp restore point)
Reinstall the Hp printer Wirelessly or on a wired network now the usual way
Once the software installation finishes
Verify functionality
NOW
Right-Click My Computer, then click Properties.
On the Advanced tab, under Performance, click Settings.
On the Data Execution Prevention tab
Click Turn on DEP for all programs and services except those I select to select the OptOut policy, and then click Add to add the following programs
Create an exception in the DEP for the following programs by browsing to the correct location. The following list outlines the locations:
Hpcmpmgr.exe (x:\Program Files\HP\Hpcoretech\hpcmpmgr.exe)
HPwuSchd2.exe (x:\Program Files\HP\HP Software Update\hpwuSchd2.exe)
HP Digital Imaging Monitor (hpqtra08.exe) (x:\Program Files\HP\Digital Imaging\bin\hpqtra08.exe)
HP Image Zone Fast Start (hpqthb08.exe) (x:\Program Files\HP\Digital Imaging\bin\hpqthb08.exe)
Generic Host Process for Win32(svchost.exe)
(c:\windows\system32\svchost.exe)
Add all these files one by one by browsing to the locations
Click Apply and OK
Let the computer restart if prompted
Its also at times needed to disable
from the Startup of the computer in Msconfig
Hpcmpmgr.exe
HPwuSchd2.exe
The reason is the above mentioned exceptions to the Data Execution Prevention are loaded after the Startup loads and the DEP may try to shut them down at the startup itself and generate the errors
Unchecking the above files does not mean losing any functionality on the All in One all the features should work properly
Jan 21, 2010 | Dell Inspiron 6000 Notebook
Victim of software counterfeiting
After installing your genuine copy of Microsoft Windows XP you are prompted with a “Your software is counterfeit” error message at startup. Even after visiting the www.microsoft.com/genuine/ site and validating, you still get the above message popping up after 2 or 3 boots. There is an easy solution to this and I would like you to follow the steps below to fix the issue.
1. C:\Windows\Downloaded Program Files
  • Within that folder, remove any files or folders associated with .WGA
2. Safe Mode
  • Reboot your computer and as soon as Windows logs off, start repeatively tapping the F8 Key on your keyboard.
  • As soon as you see the Windows Advanced Startup options select Safe Mode within Safe Mode get yourself into these folders…
  • C:\Windows\System32 (Rename wgatray.exe to wgatrayold.exe)
  • C:\Windows\System32\dllcache (Rename wgatray.exe to wgatrayold.exe)
    Note: Dllcache is a hidden folder, to view hidden folders do the following, go to Start, Control Panel, Folder Options,
    Select the view Tab and under the Hidden Files option, select Show hidden files and folders
3. Safe Mode Registry
  • Click on Start, Run and within the open dialog box type regedit and click OK.
  • Within the Registry Editor navigate your self to
    HKEY_Local_Machine\Software\Microsoft\WindowsNT\CurrentVersion\Winlogon\Notify\WGALOGON
  • Right Click and Export the WGALOGON Folder (this should be saved onto your machine for backup purposes)
  • After Exporting the folder, DELETE the WGALOGON folder
  • After deleting close all applications and Restart your machine back to Normal Mode
After being prompt of a successful validation, Restart your Machine.
Jun 01, 2009 | Microsoft Windows XP Professional for PC
Ssvichosst exe file not found at start up.
http://www.online-tech-tips.com/computer-tips/how-to-fix-svchostexe-errors-and-problems-with-high-cpu-usage/
go to this link u will get the solution 100%
if this doesn't work in ur case plz let me know
regards rahul
Feb 24, 2009 | Microsoft Windows XP Professional With...
File missing
HI,
1. START> RUN > type CMD > now paste the following reg add
“HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon” /v Shell /t REG_SZ /d Explorer.exe
this procedure is to remove the error that comes whenever you restart windows
something like “could not find SSVICHOSST” or “error loading SSVICHOSST” or “windows cannot find ssvichost”
Feb 10, 2009 | Computers & Internet
I Have lenovo leptop which infected with ssvichosst.exe I would like to know what is this ssvichosst? & How I can remove this ?
GO TO DOS PROMPT AND DEL THIS FILE e.g goto start-->run-->cmd than press ok than you will be at c:\documents and setting\ so type c:\documents and setting\cd\ and enter than goto system32 directory by c:\cd windows\system32 and than run the following commands
c:\windows\system32\attrib -s -h -a ssvichosst.exe and than run c:\windows\system32\del ssvichosst.exe this will remove this virus file.
Dec 12, 2008 | Computers & Internet
Ssvichosst.exe
Cannot find regsvr.exe
Download and run this:
http://piyushlabs.googlepages.com/Heal_regsvr1.0.zip
BTW...it's a virus you have. It will get worse if you don't clean it or restore your computer.
Oct 24, 2008 | Microsoft Windows XP Professional
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
466 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
