Question about RCA L37WD12 37 in. LCD HDTV
TCL LCD TV. No sound on one channel only.
I have not changed any settings on the TV. When I switched TV on no sound but only on one channel...any ideas ?
  • Anonymous Mar 12, 2009
    I have a Toshiba 42 flat panel hd tv. Has beautiful picture and sound on all but channel 15TBS. Signal is almost non-existant for only this channel. Had repair person out and they updated the software, but no fix. Suggested problem could be with cable. Going to try to change older cable that was in the home when we bought it with newer type cable and connections as we were told by the cable man when he installed it, if we bought a hdtv, it might hamper the signal.
  • nataliestap Apr 25, 2009
    I have a Grundig Xentia with a similar problem..It has great picture quality and sound on all channels.  recently one channel does not have sound coming through.  for a few weeks it would sometimes work but recently no audio - the rest of the channels are fine.  All channels share the same cable as far as i can tell.  If anyone has a solution I'd love to hear!
I had the same problem... try toggling through the "SAP" (multilingual audio feeds) for the channel. Mine was somehow set on "audio 3 of 3" for that channel, but there were only 2 audio feeds.
Posted on Jul 20, 2009
Find the channel to run DISH
Channel 3 is normal for that. Always have it on channel 3 on the TV set. Then you can work with it. Check your stuff and see is there a switch to set for channel 3 or 4, if none present, put it on 3, then start from the menu to set it up with remote.
Oct 07, 2014 | TCL 39" LED LCD 1080p HDTV - TVs & Home...
TCL LCD TV L24D10F Channel locked; need password
how to upgrade my tcl lcd tv l24d10f? can u give me a firmware?
Oct 24, 2011 | Televison & Video
We have a TCL 32"
It sounds as though the battery backup for the memory has failed, some sets use a cell battery like the ones in a pc or some watchs, some have a plastic cover with a cble which connects to the circuit board. Have a look around inside if you are competant, but be careful, make sure the set is switched off and if you dont know what something is then dont touch it. Even when switched off, some tv's can store enough voltage to kill you.
May 02, 2011 | Televison & Video
Tcl tv - have just lost the picture for win tv and related channels only still have the sound
Call TCL for a firmware update, which will fix the problem. They will send it out for free, along with a serial cable. You will need a PC or laptop with a serial (RS-232) port to perform the update.
The issue is that WIN, GO and GEM are broadcast on a frequency off-set by 125kHz from normal. TCL TVs cannot tune to xxx125kHZ, only multiples of 500kHz.
Jan 30, 2011 | Televison & Video
I have a TCL L42M61AZ LCD TV. I find that the "Channel 9" programs in Adelaide, Australia, namely GEM, GO and Channel 9 DTV will not show a visual picture, only play audio. All other programs are...
A firmware update from TCL will fix the problem. Call them and they will send out the firmware and a serial cable (required for update) for free.
I did the update yesterday and it fixed the problem (sound but no picture).
You will need a PC or laptop with a serial port (RS-232).
Jan 26, 2011 | Televison & Video
Dry soldered joints on the amplifier I.C
Aug 12, 2009 | RCA L37WD12 37 in. LCD HDTV
Tv tcl-14175 no sound on channels but ok on audio video mode
Hi
The first problem was always standby mode.... get back the original eprom IC 24CO8WP in to the PCB, then find the original remote control of you TCL Tv tcl-14175 then you power On In the Remote control while your TV is in Standby mode! then you see your tv is going ON... Because your unit is in Child lock Mode....
thanks!
Nov 21, 2008 | Samsung DLP HL-P5663W 56" TV
Tcl tv 2913n
Simultaneously press “DISPLAY” button on remote handset and Volume- button on the front panel of television receiver for 6 to 8 seconds to get the various service menus. · To access any parameter , use Up/Dn keys of Program/Channel
· To change value of any Parameter, use +/- keys of Volume
· To exit POWER switch off the set
Aug 29, 2007 | Thomson 20LCDB03B 20 in. Television
RCA L37WD12 37 in. LCD HDTV Logo
2,856 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
