Question about Alestron OpticSlim M12 Path-Through Scanner
Plustek wont scan
Working perfectly and in the middle of scanning docs last week it suddenly sent a message cannot find path after scanning. It scans ok and once I have click finish to save the doc to PDF it says the path cannot be found. Is it a driver? Which seems strange that it happened whiled scanning.
    President:
  • 1,223 Answers
No the problem is check the path u mentioned in the scanner preferences and settings i mean the folder mentioned to store the scanned images after the scan , scanner is given a path to store these images by default check and change that path to other location on hard drive and everything will be ok if the problem persists then update ur driver from plustek website
Posted on Feb 24, 2009
Word docs sent as email attachments are arriving in my inbox as png files - useless. How do I change this please
.PNG stands for "Portable Network Graphics". Sounds like the sender may have scanned the document, and sent the scanned document to you? Scans will come out as either .png, .jpg, or .pdf formats.
If the file is a .png, you won't be able to edit in MS Word.
Another thing to check - Make sure when you are working on a Word Document, you are saving it as a .doc file.
  • Open MS Word Document
  • Do your editing
  • Click on the "Fille" button, and then select "save as" option
  • In the window that appears, next to the "save as type" wording click on the down triangle to see different formats to save. Select ".doc"
Bottom line... tell whomever is sending the emails with attachments, to send you the MS Word file, not a scanned file.
Jul 26, 2014 | Dell Inspiron Computers & Internet
Have scanned several plans put in pdf format and sent them to a folder. Now I doing my next group and although I can see on the screen that the plans are being scanned they are not going to the folder....
When you select the user or the path for the folder you can view it on the screen. Simply type in your PC the path to see where you are sending.
On your PC click the start button, then RUN. Write the Path you see in the machine. At last ENTER
Hope this helps!!!!!!!!!!!!!!!!!!!!
reply any questions ok?!
Jan 25, 2011 | Gestetner A045 Wide Format Copier
My scanner/faxer won't scan for my mfc-490cw brother product. I always have to reset it and push 20 buttons so I don't remember how to do it. Can you help?
I have the same problem. It was working fine, then after not using it for a few weeks, all the sudden I couldn't scan. I'm hooked up wirelessly through my router. I can initiate a scan both from my PC and from the scanner itself, when initated from the scanner my PC responds and shows the progress bar, and the scanner actually scans. However for some reason no data is being sent back to the PC. And after a few minutes I get an error message saying that communication was lost (or something like that) error TW007. Yesterday I called into brother support and was on the phone for an hour and a half. they walked me through verifying connectivity, uninstalling and reinstalling the software and drivers, but to no avail. In the end we made no progress. I can print without a problem, and fax and photocopy. But for some reason it seems that the scanner is not transmitting the information back to the computer, even through the connection was established and the computer is waiting for the data.
Nov 29, 2009 | Brother MFC 490cw Color Inkjet...
Cannot access scanned document
Go into settings and find anyplace it says email. Change it to C: or destination change to C: then click OK
Jun 25, 2009 | HP DeskJet F380 All-In-One Printer
Negatives scan as negatives and not as pictures with the plustek 7300
In the Twain driver for your intellscan, there should be a selection for the type of scan. It should be set to "black & White Negative" or "Color Negative". The program you use to edit the scanned file should be able to change it to a positive if the scanned result is still negative. Programs such as Photoshop, Paint shop Pro etc can use Twain to have the scanner scan directly into them. There the phot (negative) can be edited and saved.
May 30, 2009 | Plustek OpticFilm 7300 Film Scanner
Cannon capture perfect 3.0
Check the location where you are directing the scanner/computer to store the scanned image. If it is full, obviously it cant store. Change the location where there is space.
S. Mohan
Oct 14, 2008 | Canon DR-9080C Path-Through Scanner
DR-2050C Scanner all sheets feed thru only one scans
Do you get an error message after the first scanned image? If not, check your software settings to see if you have the option of single page /multipage scanning. Some software lets the customer choose a single page scan when the SCAN button is pressed.
Check the "Feed Select Lever" to make sure it is in mutifeed position. If not, it will grab all of the docs at once.
Jul 05, 2008 | Canon DR-2050C Path-Through Scanner
Software hangs
Tell Plustec this seems a common problem- perhaps there is a patch
Jun 22, 2007 | Plustek OpticFilm 7200i Film Scanner
Scanner will not scan
Various things[as usual] can affect the performance of a USB device, so check these out. 1.Too many USB device hooked up drawing power from the system - So if it is not in use -unplug it. 2. The driver and or software for the device has corrupted.- Re install 3.Too many programs of a similar nature [graphics in this case] running and confusing resources.- shut down those not in immediate use. Do check the Plustek website for the latest driver[s] A Golden Rule for clean and simple computing is if you are not using it - shut it down. Come back with this one let us all know how it goes.
May 19, 2007 | Alestron OpticBook 3600 Flatbed Scanner
Alestron OpticSlim M12 Path-Through Scanner Logo
128 people viewed this question
Top Alestron Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you an Alestron Office Equipment and Supply Expert? Answer questions, earn points and help others
