Question about Ricoh Aficio AP2000 Laser Printer
Error sc_320, nothing print out - Ricoh Aficio AP2000 Laser Printer
Nothing prints out? You mean blank page?
I don't have manual for this older machine, but SC320 is always related to a laser problem or BICU. Regardless, you're going to need a tech for sure if you want this fixed.
Posted on Feb 24, 2009
How do I solve SC: 320 Error in Ricoh 161L
SC320 is the laser polygon mirror motor error. It does not reach the right speed. repair or replace laser unit.
Sep 11, 2017 | Ricoh Office Equipment & Supplies
MY GESTETNER 3218 AFICIO FUNCTIONAL PROBLEM SC 320. HOW CAN I SOLVE THE PROBLEM
SC 320 - Polygon motor error.
The polygon motor does not reach its operating speed within 10 sec. after the polygon motor on signal,or the lock signal is not detected for more than 40 ms continuosly during operation.
Possible causes polygon motor defective,poor conection of the interface harness which connects the polygon motor driver and the IOCSS board, IOCSS bboard defective.
The SC can be reset by turning the main switch OFF and ON if the SC was caused by a sensor error.
To reset SC press yellow key 1 - 0 - 7 and STOP ( red ) key for 3 seconds,enter in the SP mode, enter SP 5-810 ( SC code reset) and select "1".Then hold down the Photo mode key and the # key at the same time for at least 3 seconds(this does not require the main switch to be turned off and on).
Aug 22, 2012 | Ricoh Aficio 250 Copier
Error code sc 320
polygone motor error in laser unit change it possibe causes cutting wires between polygone motor and ld unit
Jan 06, 2011 | Ricoh Office Equipment & Supplies
Aparece el error SC 320 que puedo hacer??
320
Symptom
Polygon motor error
The polygon motor does not reach its operating speed within 10 seconds after the polygon motor on signal, or the lock signal is not detected for more than 200 ms continuously during operation.
Possible Cause
• Polygon mirror motor defective
• Poor connection between the polygon mirror motor driver and the SBCU board
• SBCU board defective
Nov 13, 2010 | Ricoh Aficio 2022 All-In-One Laser Printer
Can i reset the error code sc 320
sc 320 is the laser error. the polygon mirror motor is faulty in laser unit and it can only be solved by replacing the polygon mirror motor. there is no other solution.
Oct 12, 2010 | Ricoh Office Equipment & Supplies
Ricoh Aficio error code sc 320 what is this and how can I fix it.
Polygon mirror motor error/lock. Unplug the copier. Wait 20 seconds. Plug it back in. See if that makes it go away.
Otherwise you should get a hold of a service technician but getting parts for a 250 is very tough. It could be the polygon motor, the power supply, a cable, or a board. It will take some time to troubleshoot.
Oct 30, 2008 | Ricoh Aficio 250 Copier
Got problem with aficio250
Another thing that can happen to cause a jam when you are printing on there is to make sure that the paper size if correct and matches the trays you are printing to. That condition will happen if the printer tries to print a legal size page and you only have letter paper installed in the trays.
Check your settings in the printer control panel to make sure that the trays match and are correct.
Make sure that the green paper setting knobs match the correct tray size as well.
Jun 19, 2008 | Ricoh Aficio 250 Copier
LANIER 5618 COPIER ERROR CODE SC-320
Yes this is a Polygon Mirror motor error it is reasonably common in the Lanier digitals. The mirror motor can be ordered separtetly to the laser unit.
Feb 11, 2008 | Office Equipment & Supplies
Ricoh Aficio AP2000 Laser Printer Logo
108 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
